leeroyb
Get Wireless Sniffing results via API
Thu Sep 05, 2013 4:40 pm
Is there a way to get the wireless sniffing results from the API ?
I would like to be able to gather probe requests to use them in an external application which will be used to generate some statistics.
My final goal is to be able to generate statistics like Euclid Analytics (http://euclidanalytics.com/product/) and Cisco Meraki Presence Analytics (http://meraki.cisco.com/solutions/presence).
Thanks for your help.
Leeroy
leeroyb
Re: Get Wireless Sniffing results via API
Fri Sep 06, 2013 9:51 am
I've found a way using the streaming parameters, I redirect packets to a Node.js application who proceed them.
Is it possible to filter packets sent to the streaming server (as it is possible with Tools/Packet Sniffer) ? If I only want probe requests, or only packets with protocol "may only no ip" ?
janisk
Fri Sep 06, 2013 10:21 am
leeroyb
Fri Sep 06, 2013 10:47 am
Thanks !
Does this apply to the Wireless Sniffer too ?
Because I can't see these options when I'm in "Interfaces/Wireless/Sniffer". I only see these options when in "Tools/Sniffer" but this one seems to not catch probe requests and other specials packets.
janisk
Fri Sep 06, 2013 12:09 pm
in wireless sniffer there is limit filtering capabilities under settings. However you can sniff beacons and probe requests etc. data
if you require only sniffing on data, you can use regular sniffer from tools section.
helectro
Fri Sep 06, 2013 3:15 pm
(http://meraki.cisco.com/solutions/presence).=WiFi with Facebook Login
this would be great if you could do with mikrotik
TheWiFiGuy
Fri Sep 06, 2013 5:12 pm
Hi Leeroy
Ive been working on such a system too, do you care to share your work (outside of forums if required) as ive also got quite a few working protoypes using different platforms and hardware. Would be good to compare results.
richedav@gmail.com
Mikrotik Consultant.
MTCNA, MTWCE, MTCTCE, MTCRE, MTCINE
Jaggl
Thu Sep 12, 2013 6:33 pm
iam also interesed in such a Thing!
Mit freundlichen Grüßen / Yours sincerely
Roland Steger
+43 (0) 664 333 7393
Kontakt [AT] Hosters.at
www.Hosters.at
EA Ranked Server Partner
Pragmatic Preferred Provider
Teamspeak Authorized Hoster
Users browsing this forum: No registered users and 19 guests
