Davis
Reading log on ROS 6.2/6.3
Mon Sep 09, 2013 12:15 pm
How to read log on RouterOS 6.2+?
Till ROS 6.1 (including) the following code worked:
:global a ""
:foreach le in=[/log print as-value] do={
:set a "$a$[:tostr [:pick $le 3]]\r\n"
:put $a
But starting with 6.2 it just outputs many empty lines.
Is this a bug or log should be retrieved otherwise?
janisk
Re: Reading log on ROS 6.2/6.3
Mon Sep 09, 2013 1:03 pm
on 6.4rc1 I get log entry topics. If that is what you require, then this will work this way in 6.4
Davis
Mon Sep 09, 2013 2:12 pm
Great! Thanks! Then it's fixed in 6.4 :)
mrz
Mon Sep 09, 2013 2:34 pm
Correct script would be:
ros code
  :global a ""
    :set a ($a . [:tostr [($le->"time")]] . "\r\n")
  :put $a
It is wiser to use the name of element to get the value since order of the elements may change.
Davis
Tue Sep 17, 2013 2:09 pm
ros code
  :global a ""
    :set a ($a . [:tostr [$le->"time"]] . "\r\n")
  :put $a
Thanks! But looks like this code fragment doesn't work...
ros code
[demo@demo.mt.lv] > {
{...   :global a ""
{...   :foreach le in=[/log print as-value] do={
{{...     :set a ($a . [:tostr [$le->"time"]] . "\r\n")
syntax error (line 4 column 30)
mrz
Tue Sep 17, 2013 2:42 pm
ros code
Davis
Sun Sep 22, 2013 6:09 pm
ros code
Thanks for helping to improve my script Send email about reboot.
Users browsing this forum: No registered users and 23 guests
