lobzik
how to get log records for last 5 mins?
Wed Oct 09, 2013 3:06 pm
Hello.
Is there a way to print log records for last, say, 5 minutes? I can't find how to compare time in routeros...
/log print where time > ...
skot
Long time Member
Long time Member
Re: how to get log records for last 5 mins?
Wed Oct 09, 2013 6:41 pm
Try this:
ros code
/log print where time>([/system clock get time] - 5m)
I don't need any karma... I have Ιησους Χριστος!
lobzik
Wed Oct 09, 2013 6:45 pm
Wow, it works, thanks a lot!
nishadul
Thu Oct 10, 2013 10:42 am
skot
Long time Member
Long time Member
Thu Oct 10, 2013 6:42 pm
YW :D
brg3466
Sun Nov 15, 2020 6:05 am
ros code
The above code seems doesn't work on 6.47.7 , anyone have the solution ?
Thanks!
Jotne
Sun Nov 15, 2020 8:25 am
Works fine on my 6.47.7, but if there are no log last 5 min you do not get anything.
PS this will not work 4 min past midnight, since date/time format changes for events.
MT should change to use RFC-3164 time format everywhere.
PS2, to handle lots of log, see mye Splunk fro Mikrotik, see my signature.
How to use Splunk to monitor your MikroTik Router(s)
MikroTik->Splunk
brg3466
Sun Nov 15, 2020 8:53 am
Hi Jotne, Thanks for the reply !
This is weird ! See below. It doesn't work on mine.
nov/14 21:09:57 system,info,account user brg3466 logged in from 192.168.3.25 via telnet
nov/14 21:16:04 system,info,account user brg3466 logged out from 192.168.3.25 via telnet
nov/14 21:18:14 system,info changed script settings by brg3466
nov/14 22:29:03 interface,info ether3 link down
nov/14 22:29:32 system,info,account user brg3466 logged out from 192.168.3.25 via winbox
nov/14 22:29:32 system,info,account user brg3466 logged out from 192.168.3.25 via telnet
nov/14 22:36:46 dhcp,info defconf deassigned 192.168.3.25 from FC:AA:14:DA:E1:62
nov/14 22:44:44 interface,info ether3 link up (speed 1G, full duplex)
nov/14 22:44:49 dhcp,info defconf assigned 192.168.3.25 to FC:AA:14:DA:E1:62
nov/14 22:46:37 system,info,account user brg3466 logged in from 192.168.3.25 via winbox
nov/14 22:46:37 system,info,account user brg3466 logged in from 192.168.3.25 via telnet
nov/14 22:47:05 system,info,account user brg3466 logged out from 192.168.3.25 via telnet
[brg3466@MikroTik] > /log pr where time>([/system clock get time]-15m)
[brg3466@MikroTik] > :put [/system clock get time]
22:51:21
jvanhambelgium
Sun Nov 15, 2020 11:41 am
Works fine on my RB3011 running 6.47.7 "Stable" too !
Jotne
Sun Nov 15, 2020 5:39 pm
22:51:21
Not sure why you see month data in front of the log.
This only work on current day when line logs in this format: ( current day)
10:40:27 dhcp,warning DHCP-Guest offering lease 192.1168.20.171 for 0C:2F:B0:95:BC:D6 without success
So add RFC-3164, and it will be solved.
MikroTik->Splunk
brg3466
Sun Nov 15, 2020 8:12 pm
The routerOS acts funny. The problem yesterday was the format of the log. This morning, when i run the CLI again, it works. And as you said, the current day log only shows the time.
No idea what happened yesterday. :-)
nov/14 23:24:47 system,info,account user brg3466 logged out from 192.168.3.25 via winbox
nov/14 23:24:47 system,info,account user brg3466 logged out from 192.168.3.25 via telnet
00:10:40 interface,info ether3 link down
00:19:50 dhcp,info defconf deassigned 192.168.3.25 from FC:AA:14:DA:E1:62
03:10:43 interface,info ether3 link up (speed 1G, full duplex)
03:10:44 interface,info ether3 link down
10:01:25 interface,info ether3 link up (speed 100M, full duplex)
10:01:41 interface,info ether3 link down
10:01:44 interface,info ether3 link up (speed 1G, full duplex)
10:01:50 dhcp,info defconf assigned 192.168.3.25 to FC:AA:14:DA:E1:62
10:07:40 system,info,account user brg3466 logged in from 192.168.3.25 via winbox
10:07:43 system,info,account user brg3466 logged in from 192.168.3.25 via telnet
brg3466
Mon Nov 16, 2020 4:34 am
Hi , I found something else.
As long as the today's date/time format includes date, the script doesn't work. If the today's log only show time, then it works.
Question: why today's log sometimes show date and sometimes not ? below it shows date again. But this morning, there was no date, only time.
[brg3466@MikroTik] > :put [/system clock get date]
nov/15/2020
18:29:35
[brg3466@MikroTik] > log pr
nov/15 18:25:02 system,info,account user brg3466 logged out from 192.168.3.25 via winbox
nov/15 18:25:33 system,info,account user brg3466 logged in from 192.168.3.25 via winbox
nov/15 18:25:35 system,info,account user brg3466 logged in from 192.168.3.25 via telnet
nov/15 18:26:15 system,info,account user brg3466 logged out from 192.168.3.25 via telnet
nov/15 18:26:31 system,info,account user brg3466 logged in from 192.168.3.25 via telnet
nov/15 18:27:20 system,info log action changed by brg3466
nov/15 18:27:29 system,info,account user brg3466 logged out from 192.168.3.25 via telnet
nov/15 18:27:37 system,info log action changed by brg3466
nov/15 18:27:49 system,info,account user brg3466 logged in from 192.168.3.25 via telnet
nov/15 18:29:16 system,info log action changed by brg3466
Users browsing this forum: karlisi and 30 guests
