resnik
[SOLVED] fetch url problem / sms api
Mon Oct 21, 2013 3:11 pm
Hi, I'm trying to write a working script to send me SMS via API, the manual for API service can be found here
The script I tried and following error (personal data omitted):
/tool> fetch url="http://rest.nexmo.com/sms/xmlapi_key=KEY&api_secret=PASS&from=Gatekeeper&to=NUMBER&text=test_msg"
  status: failed
failure: closing connection: <404 Not Found> 173.193.199.22:80 (4)
or
/tool> fetch address="rest.nexmo.com" mode=http src-path="/sms/xmlapi_key=KEY&api_secret=PASS&from=Gatekeeper&to=NUMBER&text=test_msg"
  status: failed
failure: closing connection: <302 Moved Temporarily> 174.37.245.36:80 (4)
any idea how to get this working?
boen_robot
Re: fetch url problem / sms api
Mon Oct 21, 2013 7:48 pm
Try to clear your DNS cache with
/ip dns cache flush
before you make the request.
It appears nexmo recently changed their server, but are still keeping the old one to redirect to the new one, before they eventually take it down. "/tool fetch" doesn't cope well with redirects. Clearing the cache should point it to their new server.
PEAR2_Net_RouterOS(1.0.0b6) - My API client in PHP
(Rate my posts? If you want... no pressure...)
resnik
Mon Oct 21, 2013 10:07 pm
Did not help much, for now I resorted to PHP nexmo library that's running on my server, and fetch is working normally there, maybe at some point add lighttpd server on Metarouter, and put scripts there.
resnik
Tue Jun 10, 2014 3:22 pm
found the solution today. Changed all "?" to "\?"
ros code
fetch keep-result=no url="http://rest.nexmo.com/sms/xml\?api_key= ... ER=MESSAGE"
otgooneo
Trainer
Trainer
Wed Feb 17, 2021 7:59 am
ros code
It helps. Thank you.
Want to learn more and more...
Users browsing this forum: No registered users and 35 guests
