pkats
Need script that will pull information from simple queue
Thu Feb 06, 2014 9:59 pm
I want to get "target-address" with "bytes" for each line in simple queue saved to a file. How do I start.
c0d3rSh3ll
Long time Member
Long time Member
Re: Need script that will pull information from simple queue
Thu Feb 06, 2014 11:31 pm
maybe this is a start point for you
ros code
foreach i in=[queue simple find] do={
local ip [queue simple get value-name=target $i]
local byte [queue simple get value-name=bytes $i]
put "$ip has $byte"
then you can save to a file.
nothing
chechito
Sat Jan 06, 2018 9:36 am
ros code
put "$ip has $byte"
thx you very much
your code help me a lot
Users browsing this forum: reman6110 and 22 guests
