armandfumal
store result in variable
Fri Mar 07, 2014 9:35 pm
could anyone help me
:local output [/ip neighbor print count-only]
:put ("result: $output")
in this case value is stored into $output
but
:local output [/ip neighbor print]
not this command, the content of print is not stored into the variable?
What I'm missing ?
thanks
Armand
Armand Fumal
________________________________________________________________
MikroTik & Ubiquity
rextended
Re: store result in variable
Fri Mar 07, 2014 10:03 pm
You can not storage directly print output _as file_ to variable.
Also you can not storage directly "ping" results inside a variable, except for count of positive response.
ros code
/ip neighbor print file=tmpWork;
:local output [/file get tmpWork contents];
:put ("Results: ".$output);
If you like, add Karma, please.
I'm Italian, not English. Sorry for my imperfect grammar.
armandfumal
Fri Mar 07, 2014 10:53 pm
ros code
:local output [get tmpWork contents];
just missing the /file in line 2 before the get command
many thanks
Armand
Armand Fumal
MikroTik & Ubiquity
rextended
Fri Mar 07, 2014 10:59 pm
ros code
many thanks
Armand
Thanks, I correct my original post.
I am working on /file folder when I try the script on my RB :lol:
Users browsing this forum: No registered users and 21 guests
