rpra
Empty array initialization
Mon Mar 31, 2014 1:54 pm
I want to use a global assoc array in my script for storing some host->ip pairs, and I've encountered a problem:
when I first time define variable, it has type = "nothing", and can't be used as an array.
I have to check it's type and push some value to it, and then I can use a construct like
:global IP;
:if ([:typeof $IP] = "nothing") do={:set $IP {""};}
:set ($IP->$hostname) $ipaddress
It could be much easier to explicitely define type during init.
rextended
Re: Empty array initialization
Mon Mar 31, 2014 11:17 pm
Try first to use right syntax:
:global IP; --> :global IP value=;
:if ([:typeof $IP] = "nothing") do={:set $IP {""};} --> :if ([:typeof $IP] = "nothing") do={ :set $IP value={""} }
And now think about possibilities:
:global newEmptyArray value={""};
or
:global newEmptyArray value=[:toarray ""];
I'm Italian, not English. Sorry for my imperfect grammar.
A9691
Tue Jul 26, 2016 1:06 pm
The second solution is the right one: [:toarray ""] is a zero length array.
{""} is an array with one element which is a zero length string.
boen_robot
Tue Jul 26, 2016 4:54 pm
Also, one can use
to have an empty array literal.
PEAR2_Net_RouterOS(1.0.0b6) - My API client in PHP
(Rate my posts? If you want... no pressure...)
Frozer
Tue Oct 25, 2016 12:07 pm
Also, one can use
Thank you, man!
Chupakabra303
Wed Sep 26, 2018 4:28 pm
I found out incorrect work for syntax :local Array1 ({})
Works correctly :local Array1 [:toarray ""]
:global fArrayTest do={
# correct work :local Array1 [:toarray ""]
#  :local Array1 [:toarray ""]
# BUG, incorrect work :local Array1 ({})
  :local Array1 ({})
  :set ($Array1->([:len $Array1])) [:len $Array1]
  :put "len(Array1): $[:len $Array1]"
  :put "Array1:"
  :put $Array1
Test sequence for :local Array1 ({})
[admin@MikroTik] > $fArrayTest;
len(Array1): 1
Array1:
0
len(Array1): 2
Array1:
0;1
len(Array1): 3
Array1:
0;1;2
Test sequence for :local Array1 [:toarray ""]
len(Array1): 1
Array1:
0
len(Array1): 1
Array1:
0
len(Array1): 1
Array1:
0
Users browsing this forum: Google [Bot] and 16 guests
