plisken
netwatch email script
Tue Apr 15, 2014 5:26 pm
I have try different email scripts as see at the forum but don't work
I have routeros 6.12
I want routerboard send me a email if a host is down
How must i setup this.
rickfrey
Trainer
Trainer
Re: netwatch email script
Tue Apr 15, 2014 5:59 pm
Simply configure the email tool and test to make sure it is working. Then use netwatch to monitor the host and send the email. How far have you been able to get?
Launch your company forward with professional training!
http://rickfreyconsulting.com/product-c ... raining-2/
plisken
Tue Apr 15, 2014 6:18 pm
My email setup is done in tools email.
But i want a working script if the host if down.
Thanks for your reply
rickfrey
Trainer
Trainer
Tue Apr 15, 2014 7:13 pm
/tool netwatch
add down-script="/tool e-mail send to=youremail@gmail.com subject=\"Host is D\
    own\" from=youremail@gmail.com port=587 start-tls=yes user=youremail@g\
    mail.com password=`123456 body=\"Host Down\"" host=192.168.88.1 up-script="\
    /tool e-mail send to=youremail@gmail.com subject=\"Host is Up\" from=\
    youremail@gmail.com port=587 start-tls=yes user=youremail@gmail.com passwo\
    rd=123456 body=\"Host Up\""
plisken
Tue Apr 15, 2014 7:52 pm
Hello, rickfrey i don't need g-mail i send email via port 25
Can you help me?
rickfrey
Trainer
Trainer
Tue Apr 15, 2014 10:04 pm
If you take the above script and enter in your email info, what happens?
plisken
Tue Apr 15, 2014 10:14 pm
No email receive
rickfrey
Trainer
Trainer
Tue Apr 15, 2014 11:46 pm
Then there is something wrong with the email settings you are using or the email service is incompatible with what the MikroTik can do. Why don't you try to create a Gmail account and test it using the above script. You might also want to verify the settings that email clients should use for your service.
plisken
Tue Apr 15, 2014 11:57 pm
I will try and let you know.
Many thanks to you.
rickfrey
Trainer
Trainer
Wed Apr 16, 2014 7:00 am
No problem. Hope you get it working :D
onowojemma
Sun Jun 01, 2014 2:10 pm
/tool netwatch
Hi all tried the above script but don't work show error connecting to server on my log is there any other setting i have to so some were?
kind regards
Mikrotik! making networking easy
marizo
Sun Jun 01, 2014 2:32 pm
first configure e-mail tool:
/tool e-mail set address=173.194.77.108 port=587 from=RB@MT user=yourmail@gmail.com password=yourpass start-tls=yes
then try to send test mail:
/tool e-mail send to=toyourmail@gmail.com subject="test" body="test"
onowojemma
Sun Jun 01, 2014 2:35 pm
Thanks work perfectly well
kind regard
rickfrey
Trainer
Trainer
Mon Jun 02, 2014 4:57 pm
Glad to hear it!
itsmekadek
Wed Apr 18, 2018 5:47 am
Hello Marizo,
I am very new to mikrotik, please tell me more regarding this syntax here address=173.194.77.108 from=RB@MT. What are their meaning ? For me to be able to adjust them with my condition here.
Thank you very much
Kadek
Users browsing this forum: No registered users and 16 guests
