c0d3rSh3ll
Long time Member
Long time Member
how to get only ip from queue simple from script
Fri May 09, 2014 7:59 am
Hi.
I am working in a script to get only the ip address from queue simple, but I have a bit problem
the script what I am trying for get only ip address without the netmask is
ros code
foreach i in=[queue simple find ] do={
	local tmp [/queue simple get value-name=target $i]
local ip [pick $tmp 0 [:find $tmp "/"]]
 put $ip}
192.168.88.2/32
192.168.88.3/32
I need only this output
192.168.88.2
192.168.88.3
if I execute this command, is working:
ros code
local tmp 192.168.88.2/32; put [pick $tmp 0 [:find $tmp "/"]]
192.168.88.2
I am wrong but where?
nothing
rextended
Re: how to get only ip from queue simple from script
Sat May 10, 2014 5:05 pm
I suggest you to read all my post with script... :)
I'm Italian, not English. Sorry for my imperfect grammar.
rextended
Sat May 10, 2014 5:11 pm
:local fullIP value="123.45.67.89/10";
:local onlyIP value=[:pick $fullIP -1 [:find $fullIP "/"]];
DO NOT PLACE SPACE BETWEEN "-" AND "1" on "-1"
And if you want, remember Karma....
EDIT: this is one example, remember to pass STRING variable inside fullIP, not a IP variable....
c0d3rSh3ll
Long time Member
Long time Member
Sat May 10, 2014 6:46 pm
not work...
ros code
foreach o in=[queue simple find] do={
{... :local fullIP value=[queue simple get value-name=target $o]
{... :local onlyIP value=[:pick $fullIP -1 ([:len $fullIP] - 3)];
{... put $onlyIP
[admin@MikroTik] >
ros code
{... put $fullIP
192.168.88.2/32
192.168.88.3/32
nothing
rextended
Sat May 10, 2014 11:52 pm
Try to use correct syntax in your script, this solve the problems...
:foreach o in=[/queue simple find] do={
 :local fullIP value=[:tostr [/queue simple get $o value-name=target]];
 :put $onlyIP;
And remember: not all the time the target are one IP, can be also pppoe-client or another interface...
rzirzi
Fri Oct 05, 2018 4:35 pm
rextended - how to change Your script for:
1) change all SimpleQueues from 192.168.xx.1 to 192.168.zz.1 (all queues from 100 to 200)
2) change all PPPoE secrets addresses like SimpleQueues
Tahk You.
Users browsing this forum: Google [Bot] and 16 guests
