Denuro
Getting wireless interface rx signal-strength
Thu Jul 17, 2014 10:28 pm
Hi all,
is there any possible way to get the rx signal-strength in a script?
I've tested the attributes in the [ /interface wireless registration-table get ], but couldn't find it.
Kickoleg
Re: Getting wireless interface rx signal-strength
Fri Jul 18, 2014 9:50 am
/interface wirelles registration-table get <number> <value-name>
number - number of item
value-name - in your case rx-signal
MTCNA, MTCUME, MTCRE, MTCWE, MTCTCE certified
ovdeathiam
Fri Jul 18, 2014 9:51 am
You mean like /interface wireless registration-table get value-name=signal-strength?
Kickoleg
Fri Jul 18, 2014 11:22 am
Yes you right - my mistake ... sorry
Denuro
Fri Jul 18, 2014 3:07 pm
You are right, the signal-strength is exactly what I need!
I thought it was the same as the tx-signal-strength, but looks like I was wrong :lol:
plisken
Mon Sep 15, 2014 12:36 pm
Where can you read the result?
c0d3rSh3ll
Long time Member
Long time Member
Tue Sep 16, 2014 6:50 am
paste this in the terminal
ros code
put [/interface wireless registration-table get value-name=signal-strength 0 ]
this read the signal strength for the station 0
nothing
plisken
Tue Sep 16, 2014 8:44 am
Thanks c0d3rSh3ll
hulitolku
Sun May 24, 2020 1:40 am
Why this work ok in Terminal:
:global dbm [/interface wireless registration-table get value-name=signal-strength 0]
But dont work in script?
Global dont get value.
nichky
Long time Member
Long time Member
Sun May 24, 2020 1:50 am
ros code
Can you please give me more details about this rule
in my case i got
0 wlan1m.vl101 DC:D9:16:9A:FD:F4 no -39dBm@1Mbps 57.7... 9h37m4s
1 wlan1m.vl101 D4:F5:47:27:FC:33 no -43dBm@1Mbps 72.2... 4h35m11s
2 wlan2v.vl100 AC:D1:B8:84:F5:13 no -59dBm@HT20-7 72.2... 1h2m7s
3 wlan2v.vl100 38:CA:DA:D2:E0:EF no -50dBm@1Mbps 72.2... 3m14s
with your rule im getting resault..... -41dBm@1Mbps
So does it calculate?
RouterOS does not have a random function. Many has tried to make script to make random text, but all seems to be flawed.
viewtopic.php?f=9&t=160183
!) Safe Mode is your friend;
Jotne
Sun May 24, 2020 10:17 am
To get better detail about the field, use as-value. Try cut/past this script.
Its part of my Splunk script to monitor all wifi clients. (see signature)
	:if ([:len [/interface wireless find ]]>0) do={
		:foreach logline in=[/interface wireless registration-table find] do={
			:local output "$[/interface wireless registration-table print  as-value from=$logline]"
			:set ( "$output"->"script" ) "wifi"
			:put "$output"
Output
.id=*8;ap=false;comment=;interface=wlan-2g;mac-address=04:79:70:xx:xx:B3;signal-strength=-52dBm@5.5Mbps;tx-rate=1Mbps;uptime=00:00:08;script=wifi
Why do not use Splunk to monitor your MikroTik Router(s)? Look at this page in how to set it up.
MikroTik->Splunk
nichky
Long time Member
Long time Member
Mon May 25, 2020 7:34 am
			:put "$output"
it would be great if you can make it work from system script. which it does not at the moment
Output
Jotne
Mon May 25, 2020 8:05 am
@nichky
Use the "Post Reply" button to reply someone. If quote is needed, only quote some part, not the whole post.
Here you quoted the post without writing anything :)
MikroTik->Splunk
plisken
Fri Dec 25, 2020 2:51 pm
I know this is an old topic but no less important for that.
I would like to email the signal from my point to point link daily. Can you make a script for this?
regards
Jotne
Fri Dec 25, 2020 7:33 pm
Every thing you get an output from can be sent as an email. I have not worked with email sending, so cant help you with that part. Have seen various post here on the forum on how to setup email, so should be possible.
I do use Splunk to monitor this. There I can look at any give time period. If you have paid version it can also send email for any triggered alert you setup. Here is an graph of strengt from two wifi devices.
MikroTik->Splunk
Users browsing this forum: Baidu [Spider] and 31 guests
