MUM Europe 2020
Tw_
Port Forwarding
Fri Jun 09, 2006 6:45 am
need Ure help Urgent ....Pals
does anyone know how to port forwarding for mikrotik 2.9
for reference
http://www.portforward.com but theres not available for mikrotik
ex:
for 192.168.11.1 I need to forwarding port 6500
192.168.11.2 I need to forwarding port 6501
192.168.11.3 I need to forwarding port 6502
and so
thanks for da help
Gerard
Trainer
Trainer
Fri Jun 09, 2006 6:58 am
add chain=dstnat in-interface=wlan1 protocol=tcp dst-port=6500 action=dst-nat \
to-addresses=192.168.11.1 to-ports=6500 disabled=no
add chain=dstnat in-interface=wlan1 protocol=tcp dst-port=6501 action=dst-nat \
to-addresses=192.168.11.2 to-ports=6501 disabled=no
add chain=dstnat in-interface=wlan1 protocol=tcp dst-port=6502 action=dst-nat \
to-addresses=192.168.11.3 to-ports=6502 disabled=no
Make sure you replace wlan1 with the correct name of your WAN(internet) interface.. If you need to forward udp instead of tcp them change that also.
Hope that helps..
-Gerard
Tw_
Fri Jun 09, 2006 8:08 am
Its about a game(warcraft) that required forwarding port to enable creating room.
I have
chain=dstnat dst-address=219.83.12.146 action=dst-nat
to-addresses=192.168.11.5 to-ports=6500 << its run well
but when I added more configuration
to-addresses=192.168.11.6 to-ports=6501 it doesnt work at all
thanks 4 gerard
l've tried Ure Config but still doesnt worked
maybe any else suggestion...!!@#@!$$???
djape
Fri Jun 09, 2006 12:00 pm
Ok,
first rule was to forward everything that is coming from 219.83.12.146 to 192.168.11.5 port 6500
so firewall rule was accomplished and it will not go to second rule! Understand?
The only way it can work is like this
chain=dstnat dst-address=219.83.12.146 dst-port=6500 action=dst-nat
chain=dstnat dst-address=219.83.12.146 dst-port=6501 action=dst-nat
You can't tell router to forward same port to two different addresses!
Cheers...
I drink like a pirate and smoke like a hippie...
Tw_
Sun Jun 11, 2006 8:31 am
no im not sir .!!
Good config Mr djape
but aint worked :(
djape
Mon Jun 12, 2006 5:11 pm
but aint worked :(
I know, it ain't gonna work as server is serving on port 6500. I was just giving example...
Tw_
Tue Jun 13, 2006 7:27 pm
sorry folks case should be closed...
'cause when I tell the ISP they said that my 219.83.12.146 was broken :(
and now everything work well :D
thanks for concern :lol:
Users browsing this forum: No registered users and 13 guests
