Beko0ol
Scripting Sum Count of bytes Out
Thu Sep 25, 2014 11:00 am
what's wrong with this script
:local gigabyte
:local name
:foreach name in=[/ip hotspot user find ]
             do={:set gigabyte[$gigabyte+ /ip hotspot user get $name bytes-out] }
:put $gigabyte
c0d3rSh3ll
Long time Member
Long time Member
Re: Scripting Sum Count of bytes Out
Thu Sep 25, 2014 8:55 pm
check this, may be is the solution for you
ros code
global gigabyte
:foreach name in=[/ip hotspot user find ] do={
global byte [/ip hotspot user get $name bytes-out]
:set gigabyte [($gigabyte + $byte)]
:put $gigabyte
nothing
psamsig
Thu Sep 25, 2014 9:17 pm
/ip hotspot user {
    :local gigabyte 0
    :foreach i in=[find] do={
        :set gigabyte ($gigabyte + [get $i bytes-out])
    :put $gigabyte
Beko0ol
Fri Sep 26, 2014 11:46 am
Thanks i used this and work fine
ros code
:global gigabyte 0 ;
:global byte 0 ;
do={:set byte [/ip hotspot user get $name bytes-out];:set gigabyte [($gigabyte + $byte)] };
:put $gigabyte
Thank you for quick respond and attention.
Users browsing this forum: No registered users and 15 guests
