vasilaos
elif statement
Wed Oct 08, 2014 11:52 am
can i use elif statement in mirkotik scripts?
Deantwo
Re: elif statement
Wed Oct 08, 2014 3:49 pm
Not according to the wiki at least.
http://wiki.mikrotik.com/wiki/Manual:Sc ... _statement
Putting another IF statement inside the ELSE statement seems to be the only way.
No ELSE IF and no SWITCH CASE, it sure makes the scripts look more messy.
I wish my FTP was FTL.
mrz
Re: elif statement
Wed Oct 08, 2014 3:52 pm
else if and switch case are not implemented at the moment
Jotne
Re: elif statement
Fri Sep 06, 2019 8:03 am
So you are working on it? I am waiting with high expectation :)
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
SiB
Re: elif statement
Fri Sep 06, 2019 10:31 am
WorkARound, mutch better then if else if else....
local myFunc do={put $1}
if ($n=1) do={$MyFunc "A"}
if ($n=2) do={$MyFunc "B"}
if ($n=3) do={$MyFunc "C"}
if ($n!=1 & $n!=2 & $n!=3) do={$MyFunc "Other"}
MTCNA + MTCRE + MTCINE | ~600 users at ~150 RouterBoards in EMEA | Telegram: @SiB_PL | WebChat: Tokonda
Users browsing this forum: No registered users and 5 guests
