Angel83
Script Ping (Host To IP) to the variable.
Sat Oct 11, 2014 2:58 pm
Hi, I do not know how to write a script. Please help.
I would like to use ping to the domain.
Then assign the host IP to a variable.
:local PingResult
:set PingResult [ping www.google.com count=2]
:put $PingResult
:log info $PingResult
result
:log info "2"
How to do that resulted in the IP:
:log info "213.241.87.25"
smileymattj
Re: Script Ping (Host To IP) to the variable.
Tue Oct 14, 2014 12:10 am
google is probably not the best example, since it returns multiple ips. It has many servers that can respond.
I used msn because it returned one address.
ping msn.com
:put [/ip dns cache get value-name=address [find name="msn.com"]];
First ping the domain you wish to find.
Then extract the IP from the DNS cache.
Make sure that you use the same exact domain in each command. http://www.msn.com and msn.com are two separate DNS entries. So each command has to match.
c0d3rSh3ll
Long time Member
Long time Member
Tue Oct 14, 2014 1:11 am
there are some ways to do it.
you can use resolve command, something like this
ros code
local host1 [resolve google.com]
put $host1 }
or
ros code
log error $host1 }
nothing
Users browsing this forum: regae and 18 guests
