MBAGA
remove entry in walled garden [PHP]
Wed Nov 12, 2014 6:55 pm
I added "www.example.com" in walled garden with
$addRequest = new RouterOS\Request('/ip hotspot walled-garden add dst-host=www.example.com');
$client($addRequest);
now how can i remove it in php ?
boen_robot
Re: remove entry in walled garden [PHP]
Wed Nov 12, 2014 7:51 pm
How would you remove it from CLI?
My guess is with a "find" subcommand on "remove", so...
$util = new RouterOS\Util($client);
$util
    ->setMenu('/ip hotspot walled-garden')
    ->remove(
        RouterOS\Query::where('dst-host', 'www.example.com')
(this is with 1.0.0b5; Last time we talked, you used b4, where it's "changeMenu" instead of "setMenu"; I recommend that you upgrade to b5)
PEAR2_Net_RouterOS(1.0.0b6) - My API client in PHP
(Rate my posts? If you want... no pressure...)
MBAGA
Wed Nov 12, 2014 8:15 pm
I tried this
$util
    ->changeMenu('/ip hotspot walled-garden')
    ->remove(RouterOS\Query::where('dst-host', 'www.example.com')
$client($util);
but i get
Fatal error: Call to a member function remove() on string
boen_robot
Thu Nov 13, 2014 1:16 pm
Oh... In b4, changeMenu() returned the last menu... I forgot.
Change it to:
$util->changeMenu('/ip hotspot walled-garden');
$util->remove(RouterOS\Query::where('dst-host', 'www.example.com'));
MBAGA
Sat Nov 15, 2014 10:30 pm
Thanks aand if i want to print entries where comment="something" ?
I tried
$printRequest = new RouterOS\Request(
'/ip hotspot walled-garden getall .proplist=dst-host',
RouterOS\Query::where('comment', 'something')
echo $client->sendSync($printRequest)->getArgument('dst-host');
but Prints only th first result
i guess i need a for / foreach , Right?
boen_robot
Sat Nov 15, 2014 10:45 pm
Yep.
MBAGA
Sat Nov 15, 2014 10:48 pm
Like?
boen_robot
Sat Nov 15, 2014 11:38 pm
Like?
Damn it! You had me so hopeful there, that you finally get the overall flow and didn't need further instructions. :D
foreach ($client->sendSync($printRequest)->getAllOfType(Routeros\Response::TYPE_DATA) as $response) {
    echo $response('dst-host');
MBAGA
Sat Nov 15, 2014 11:50 pm
I'm twenty & I'm Italian : have patience :roll:
Thanks!
boen_robot
Sun Nov 16, 2014 12:02 am
That doesn't mean anything... Usually, older people have harder time learning, and you're younger than me (and I'm in my 20's right now), and I think I still learn stuff OK.
Oh, I have. You have no idea :lol: .
MBAGA
Sun Nov 16, 2014 12:11 am
:D yes are apologies but a month ago I did not know what mikrtik was
Respect! :')
Stillhard
Sun Nov 16, 2014 2:40 pm
what's mikritik? :lol:
MBAGA
Sun Nov 16, 2014 9:00 pm
indeed XD
last 2 questions (hope) :
1 ) i tried to concatenate Query parameters like e.g.
$util->remove(RouterOS\Query::where('dst-host', 'something') && ('comment', 'something'));
unsuccessfully
how you Doing?
2 ) is it possible to modify session timeout ofa hotspot user profile (php) ?
boen_robot
Sun Nov 16, 2014 9:44 pm
how you Doing?
What?
jk. :lol:
Yeah, creating more complicated queries is unfortunately a little more complicated currently.
The Query object (the thing that's returned from Query::where()) collects all the different conditions you want, and you can chain more by invoking either orWhere() or andWhere(), depending on whether you want the next condition to be OR-ed or AND-ed with everything up to this point.
So, in your case:
$util->remove(RouterOS\Query::where('dst-host', 'something')->andWhere('comment', 'something'));
There's no brackets - you have to artificially arrange your conditions so that the conditions can be correctly evaluated from left to right. That's not important for your current scenario, but if you go any more complicated than two conditions, you may start seeing what looks like "anomalies", created due to this tricky part.
In general, ask yourself how would you do it from a console.
I'd also recommend you get yourself a nice PHP editor like Eclipse PDT for example - it would tell you those things while you're typing the code, in the form of list of methods you can invoke, and with docs, from which point you should be able to intuitively guess which one you need.
In this case, since you're modifying, you need set(), e.g.
$util->changeMenu('/ip hotspot user profile');
$util->set(
    'default',
    array(
        'session-timeout' => '20m'
MBAGA
Sun Nov 16, 2014 10:00 pm
fantastic
Users browsing this forum: No registered users and 33 guests
