jayd2k
[SOLVED] How to iterate only through interfaces that have a comment set?
Sat Feb 14, 2015 8:56 am
I need a little help here - how to iterate through the list of interfaces that have a comment set?
Here's the list of interfaces I use for testing on an RB2011:
[admin@MikroTik] > interface print
Flags: D - dynamic, X - disabled, R - running,
S - slave
 #     NAME                                TYPE
 0     ether1-gateway                      ether
 1  RS ;;; test123
       ether2                              ether
 2   S ether3                              ether
 3   S ether4                              ether
 4   S ether5                              ether
 5   S ether6-master-local                 ether
 6   S ether7-slave-local                  ether
 7   S ether8-slave-local                  ether
 8   S ether9-slave-local                  ether
 9   S ether10-slave-local                 ether
10   S sfp1                                ether
11  R  bridge-local                        bridge
Trying to iterate only through interfaces that have a comment set:
[admin@MikroTik] > :foreach IF in=[/interface ethernet find where comment] do={ put $IF };
Using the negation operator I can at least get a list of interfaces which do not have any comment set:
[admin@MikroTik] > :foreach IF in=[/interface ethernet find where !comment] do={ put $IF };
*2
*4
*5
*6
*7
*8
*9
*a
*b
*1
The expected result is to list only ether2 as it is the only interface with a comment.
By 2016 total internet traffic will be 3x 2011
boen_robot
Re: How to iterate only through interfaces that have a comment set?
Sat Feb 14, 2015 3:12 pm
Since recent versions, I think you need to use "any", i.e.
find where any comment
PEAR2_Net_RouterOS(1.0.0b6) - My API client in PHP
(Rate my posts? If you want... no pressure...)
jayd2k
[SOLVED] Re: How to iterate only through interfaces that have a comment set?
Sat Feb 14, 2015 4:36 pm
Yes, that works. Thanks! Seems like the scripting guide in the wiki could use a little updating.
petrn
Sun Feb 15, 2015 3:23 pm
I wonder where is documentation for this, can Mikrotik enlighten me?
Petr
boen_robot
Sun Feb 15, 2015 4:14 pm
It's in the change logs for 6.19, and only there for now.
Users browsing this forum: No registered users and 20 guests
