Mike
Adding hotspot users with a script. Automating a hotel hots
Sun Sep 26, 2004 9:51 pm
I am looking at making some sort of scripting tool that will allow a hotel front desk to enter a form and add a user ti their hotspot users, with en expiration time also from the form. Something that the front desk person can fill out and create an account without having them get into the MT command line interface or Winbox. Is their a way to have a script uploaded to the MT box and then executed?
Thanks for your help
Mike Delp
edzix
Mon Sep 27, 2004 12:09 pm
we are working on such a project. Soon will be available for public use. It will allow the administrator of the hotspot gateway to manage the clients, give them time access and a lot of other features.
Edgars
Mike
Tue Sep 28, 2004 1:27 am
Do you have a time frame for this functionality? WIll it be implemented with the radius work you mentioned in other posts, or will it work with the users table inside of the MT box?
Thanks for the reply
Mike Delp
edzix
Tue Sep 28, 2004 2:11 pm
there is no concrete date when it will be accomplished. But i think it will take a month or two at the worst case.
This system will use radius server not the router's resources .
Edgars
lgl007078
wonderful !!!!
Sun Oct 03, 2004 4:44 pm
ha ha !!! :D :D
cmit
Sun Oct 03, 2004 8:15 pm
What exactly was so funny in this topic?!
Best regards,
Christian Meis
ilero
Wed Oct 06, 2004 5:48 am
Edzix,
You stated in July that it would only be a couple months before this software was available... When should we expect it?
edzix
Wed Oct 06, 2004 12:12 pm
Edzix,
august and september are a couple of months, even less, isn't it so?:)
In one moth will be ready. Now we're working on final features and doing active testing.
Edgars
ilero
Wed Oct 06, 2004 11:14 pm
Edzix,
Thanks... And yes, you are correct - It is just now been two months.
Just a quick question: Will this software interface with a Radius server or directly with a Mikrotik?
edzix
Thu Oct 07, 2004 9:36 am
it will be like a bridge between RouterOS and radius server .
Edgars
lastguru
Trainer
Trainer
Thu Oct 07, 2004 9:57 pm
Translation: it will work on and with a FreeRadius server.
International MikroTik Certified Trainer and Consultant form Latvia.
I do RouterOS Training and Certification worldwide!
skype: lastguru
bjohns
Fri Oct 08, 2004 12:48 am
Sounds great, I'd rather something more solid than the dodgy system I tossed together using a hacked to bits dialupadmin interface.
I'd be happy to beta test etc
smoker
Fri Oct 08, 2004 10:10 am
Will it be possible to manage several hotel hotspots with one centrally managed radius server but with no roaming?
Meaning if I sell a subscription in HotelA the user cannot use it in HotelB?
edzix
Fri Oct 08, 2004 10:39 am
you will be able to manage several hotspot gateways, roaming will not be possible at the start version. But we can think about adding such a feature.
Edgars
ofasa
Sun Oct 10, 2004 4:06 pm
I use quick-r for my mikrotik hotspot administration:
http://www.q-linux.com/software/quick-r
evert
Fri Nov 12, 2004 4:36 pm
Edgars
Any news on this project? 8)
Regards,
Evert
normis
Fri Nov 12, 2004 4:53 pm
It is ready, but we are making the documentation now. Will keep you updated
evert
Tue Nov 16, 2004 3:51 pm
BTW, who has gotten quick-r to work 100% with FreeRadius/Mikrotik? I'm having some trouble getting the authentication to function the way it should. Quick-R uses %w, but Freeradius doesn't... :?
Regards,
Evert
sarky
Wed Dec 01, 2004 11:11 am
I am using Freeradius to do such a thing, but it works on activation process i.e: user logs in if the account is new then the user needs to activate the account using a php script when the account is activated then the user can log on and all the user account details will be copied to the right path.
Seems to work well the only disadvantage using free radius, if you restrict a user for 3hours internet time, the user can come in as many times as he wants until the account expires or the 3hours are up..
Sarky
edzix
Fri Dec 03, 2004 2:21 pm
Sarky, you can wite some script to make this work a bit different. Have you tried Mikrotik HotSpot Manager. We have, for example, timeout that starts decreasing stage only after the first login and sets immediately a deadline for the user. And it doesn't matter wheter the user is online or not after 1st login.
Edgars
sarky
Fri Dec 03, 2004 3:10 pm
Hi Edgars
Yeah i know that Hotspot manager works in a different way, i have been trying for a while to do that via radius but i had to settle for activation style due to restriction with radius.
Can you give me an example of using a script to make it work another way?
Thanx
sarky
edzix
Fri Dec 03, 2004 3:25 pm
sorry, i have no rights to do that!
I can tell you that you have to use DB for this. When the user is trying to authenticate, call that script eith radius attribute. And there do the necessary collations with current time.
Edgars
Users browsing this forum: No registered users and 7 guests
