tekrondo
Dynamically attach a firewall rule by matching a device name (or mac address) prefix
Wed Jul 29, 2015 5:46 pm
Hi all,
I need to match devices with a specific name prefix (or mac address prefix) and then attach a firewall rule to them.
E.g all Android devices have android- prefixed to their names (and all devices have specific OUI attached to them i the mac-address), I want to be able to go through the DHCP leases and match all devices with this prefix and then attach a firewall rule to the device or alternatively, add the devices to a list and attach the firewall rule to the list.
I'm of the impression that the Routers do not have the mac-address-list option.
If this is possible I would like some help with it because currently I am manually going through the process and it's pretty painful to say the least.
I am using a CCR1036.
Any other info that is needed to help me with this, I would provide.
Thanks.
jarda
Fri Jul 31, 2015 8:07 am
Everyone can freely change the hostname and mac address of wifi module on his android phone/tablet. This is not the secure way.
oxigeno20
Re: Dynamically attach a firewall rule by matching a device name (or mac address) prefix
Fri Aug 07, 2015 4:23 pm
May be, you would search the list of dhcp-server-leases with a loop, and attach the rule to the bridge filter, or firewall filter, or directly block-acccess in the dhcp-server without firewalls.
check it out.
http://www.tech-nico.com/blog/script-mi ... -con-dhcp/
http://www.tech-nico.com/blog/script-mi ... -firewall/
http://www.tech-nico.com/blog/script-mi ... -efectivo/
Users browsing this forum: No registered users and 17 guests
