Previously we were using a Microtik HapLite Router and it was not possible to "see" or print from a mobile phone to a WiFi printer connected to the same WiFi network. I posted to the forum and was advised to enable all port forwarding and that solved the problem.
Now we have upgraded to a Microtik Hap AC2 router and have experienced the same problem with the WiFi printer. I can't find the setting that allows all port forwarding. I need help please with step by step instructions to enable all port forwarding. Your advice would be appreciated.
Kind regards
Chris
