KBoris
Tagged abd Untagged VLAN on same port RB250GS
Thu Sep 03, 2015 7:56 pm
Hi guys,
I know how to confgure access port (Untagged VLAN) on RB250GS, and I know how to configure Trunk port (Tagged VLANS), but can anybody tell me how to configura on por one Untagged VLAN (100) and for example 5 Tagged VLAN's (501,502,503,504,505) ?
Tab VLAN:
Vlan Mode :
Default VLAN ID:
Force VLAN ID:
Vlan Header:
Tab VLANs:
VLAN100:
VLAN501:
VLAN502:
VLAN503:
VLAN504:
VLAN505:
Thank you
Boris
becs
Re: Tagged abd Untagged VLAN on same port RB250GS
Fri Sep 04, 2015 9:41 am
There is no way to configure it with RB250GS.
But just to mention - it is possible with RB260GS/RB260GSP.
marrold
Fri Sep 04, 2015 10:50 am
Is it possible in RouterOS? I have seen mixed information.
becs
Fri Sep 04, 2015 2:36 pm
It is possible in RouterOS and CRS switches.
So called hybrid VLAN port configuration is described in CRS Port Based VLAN example #2
http://wiki.mikrotik.com/wiki/Manual:CR ... Based_VLAN
Here is hybrid port example using RouterOS bridges and VLAN interfaces.
The setup is similar to CRS Port Based VLAN example #2:
//ether1 is Trunk port
//ether2 is Hybrid port with vlan200 untagged
//ether3 is Hybrid port with vlan300 untagged
//ether4 is Hybrid port with vlan400 untagged
/interface vlan
add name=ether1-vlan200 interface=ether1 vlan-id=200
add name=ether1-vlan300 interface=ether1 vlan-id=300
add name=ether1-vlan400 interface=ether1 vlan-id=400
add name=ether2-vlan300 interface=ether2 vlan-id=300
add name=ether2-vlan400 interface=ether2 vlan-id=400
add name=ether3-vlan200 interface=ether3 vlan-id=200
add name=ether3-vlan400 interface=ether3 vlan-id=400
add name=ether4-vlan200 interface=ether4 vlan-id=200
add name=ether4-vlan300 interface=ether4 vlan-id=300
add name=bridge-vlan200
add name=bridge-vlan300
add name=bridge-vlan400
add bridge=bridge-vlan200 interface=ether1-vlan200
add bridge=bridge-vlan200 interface=ether2
add bridge=bridge-vlan200 interface=ether3-vlan200
add bridge=bridge-vlan200 interface=ether4-vlan200
add bridge=bridge-vlan300 interface=ether1-vlan300
add bridge=bridge-vlan300 interface=ether2-vlan300
add bridge=bridge-vlan300 interface=ether3
add bridge=bridge-vlan300 interface=ether4-vlan300
add bridge=bridge-vlan400 interface=ether1-vlan400
add bridge=bridge-vlan400 interface=ether2-vlan400
add bridge=bridge-vlan400 interface=ether3-vlan400
add bridge=bridge-vlan400 interface=ether4
KBoris
Sat Sep 05, 2015 11:00 am
Huh... good answer after I spend hours to find solution. Never mind, I am satisfied with answer and explanation how to do that on RouterOS.
Thank you all for your time
Regards
Users browsing this forum: janzziii and 37 guests
