rohaantje
New Routerboard sector antenna/device
Fri Sep 04, 2015 4:04 pm
Are these to-be-released sector antennas from mikrotik??
If so, Very good idea :D
mAP | hAP lite | hAP ac lite | hEX lite | RB2011 | SXT 5 ac | CRS109-8G-1S-2HnD-IN
jarda
Fri Sep 04, 2015 5:08 pm
Looks like it should be active integrated device more than just simple antenna.
paoloaga
Re: New Routerboard sector antenna/device
Fri Sep 04, 2015 6:35 pm
In the picture it looks like those are 120 degrees sectors. Hope there will be a 60 degree version with the vertical lobe more open, useful for installation on mountains which cover valleys for both near and far customers. SXT-SA are very good in this scenario.
honzam
Fri Sep 04, 2015 10:12 pm
+1
LAN, FTTx, Wireless. ISP operator
HaQs
Sat Sep 05, 2015 12:19 pm
+1 for sector with:
- SFP and DC connector :)
- MU-MIMO support
- good shielding
bajodel
Long time Member
Long time Member
Sat Sep 05, 2015 1:16 pm
- good shielding
+1
InoX
Sat Sep 05, 2015 2:50 pm
I've never seen a round back sector till now...
sonny
Mon Sep 07, 2015 1:34 pm
it seems not to be any shielding on this Sectors.
Hence they are all plastic and only dual 5GHZ "N"
very cheap.....
Karl Sonnleitner
Senior Wireless-Expert
Restlesspowerbox - managed powersupply for Routerboards
HaQs
Tue Sep 08, 2015 9:12 pm
With this cheap then I was not so sure.
See price QRT5 (should be at least $ 30 cheaper)
I think that the market small ISP expects innovative product.
(at least something like airfiber X, preferably also in other bands than 5GHz)
OR QRT / dynadish with dual radio (rx / tx)
pukkita
Trainer
Trainer
Thu Sep 10, 2015 2:33 pm
come on, mikrotik, you already teased us with the pic in the newsletter, give us some more info! :)
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
normis
Thu Sep 10, 2015 2:34 pm
Will everybody be super sad, if I say it is only a render :) ?
HaQs
Thu Sep 10, 2015 3:54 pm
Nice render ;)
jarda
Thu Sep 10, 2015 7:32 pm
Super sad...
paoloaga
Fri Sep 11, 2015 8:45 pm
Super sad here too!
pukkita
Trainer
Trainer
Thu Sep 24, 2015 7:51 pm
:D
Teasing, Teasing!
honzam
Tue Oct 06, 2015 5:15 pm
It is true, not renderer. :) Name sector on picture is mANT 15s
a bigger model is mANT 19s
marekm
Tue Oct 06, 2015 9:23 pm
1. Availability date? Winter is coming soon.
2. Frequency range? Would be nice if it works with acceptable SWR up to 6100 MHz.
ronniee
Wed Oct 07, 2015 9:00 am
Yesterday at Turkish MUM was presented some slides about new sector antennas, but nothing about availability or prices.
Maybe they will give more info in 2 days at Indonesia MUM.
RogerWilco
Mon Oct 12, 2015 5:24 am
Has anyone else noticed MK doesn't like 2.4 GHz with their antennas?
chechito
Mon Oct 12, 2015 6:52 am
yes have to buy another brands antennas because that
Max416
Wed Oct 14, 2015 4:09 pm
Interesting products...
One stupid question: since these antennas are the natural companions of BaseBox, NetMetals, etc... is there a housing place on the back of the antenna for such kind of boards?
Do we have to install the electronics on the pole and go to the antenna with coax cables? Is there the possibility to install a BaseBox on the back of the antenn and THEN go to the connectors with coax?
Thanks...
honzam
Thu Oct 15, 2015 12:14 pm
normis
Fri Oct 16, 2015 5:37 pm
Thanks...
no, since the antenna is for any device, not just BaseBox, you will need to mount basebox with it's own pole mount, no special bracket. Antenna is universal, you can use it for any device.
jarda
Fri Oct 16, 2015 6:49 pm
You should build antennas that could enclose the routerboards inside.
normis
Re:
Fri Oct 16, 2015 6:58 pm
we also have that coming:
jarda
Fri Oct 16, 2015 7:10 pm
Ok. Interesting. Waiting for specifications...
chechito
Re:
Fri Oct 16, 2015 7:18 pm
looks like rb922 with some kind of sectorial
i hope some 2.4ghz sectorial products
honzam
Fri Oct 16, 2015 9:17 pm
Make narrower sector antennas. 120 degrees is too wide.
Ideal for environment with interference is 60 degrees and less.
w0lt
Re: Re:
Fri Oct 16, 2015 9:52 pm
Uh, yea...When? After the RB3011? :?
MTCNA - 2011
" The Bitterness of Poor Quality Remains Long After the Sweetness of Low Price is Forgotten "
RogerWilco
Re: Re:
Sat Oct 17, 2015 2:09 am
I hope for a 2.4 GHz version too.
pukkita
Trainer
Trainer
Sun Oct 18, 2015 5:10 pm
Had a closer look at the "renders" :D In Madrid's MUM.
15dBi models looks suitable for close range, check the PDF...
SXT5 and 5ac SA models are already 90 degrees...
There is already RBSXTG2HnD which is a L4 60 degree 2.4GHz version, on most urban areas 2.4GHz is unusable for WMAN, we all want disruptive prices and economy of scale applies, guess that's why Mikrotik isn't manufacturing more 2.4GHz devices for that but focused for WLAN duties.
Integrated models have RB921 inside.
Regarding integrated sectors for high interference scenarios, Mikrotik has already partnered with RF-Elements, there's a "Simper Integrated Radio" line of Twistports with custom mikrotik 921 boards, with a shielded version (the red one I believe) designed and manufactured from the ground up with shielding in mind for high interference scenarios, had the chance to inspect them at the MUM and look really promising for this usage, specially when coupling them with RFE new 30,45,60,90 degree horn sector antennas.
Users browsing this forum: No registered users and 26 guests
