normis
v6.32.1 released
Tue Sep 08, 2015 9:31 am
What's new in 6.32.1 (2015-Sep-07 13:03):
*) RB911/912 - fixed lock-up;
*) RB493G - fixed reboot loop;
*) firewall - do not lose firewall mangle rules on start-up;
*) defconf - fix default configuration for routers without wireless package.
What's new in 6.32 (2015-Aug-31 14:47):
*) trafflow - added support for IPv6 targets;
*) switch - fixed port flapping on switch ports of RB750, RB750UP, RB751U-2HnD and RB951-2N (introduced in 6.31)
*) ipsec - added compatibility option skip-peer-id-check;
*) flash - fix kernel failure (exposed by 6.31);
*) bridge firewall - add ipv6 src/dst addr, ip protocol, src/dst port matching to bridge firewall;
*) RB911/RB912 - fix SPI bus lock after fast led blink;
*) ipsec - fix potential memory leak;
*) bridge firewall - vlan matchers support service tag - 0x88a8;
*) ippool6 - try to acquire the same prefix if info matches recently freed;
*) crs switch - allow to unset port learn-limit, new default is unset to allow more than 1023 hosts per port;
*) x86 - fixed 32bit multi-cpu kernel support;
*) chr - add hotspot,btest,traffgen support;
*) revised change that caused reboot by watchdog problems introduced in v6.31;
*) ipsec - use local-address for phase 1 matching and initiation;
*) ipsec - fix transport mode ph2 ID ports when policy selects specific ip protocol on initiator;
*) certificates -fixed bug where crl stopped working after a while;
*) ip accounting - fixed kernel crash;
*) snmp - fix system scripts get;
*) hotspot - ignore PoD remote requests if no HotSpot configured;
*) hotspot - fix kernel failure when www plugin aborts on broken html source;
*) torch - add invert filter for src/dst/src6/dst6 addresses ;
*) bonding - add min_links property for 802.3ad mode;
*) snmp - get vlan speed from master interface;
*) hotspot - fix html-directory path on small flash devices;
*) mipsbe - make system shutdown work again;
*) lcd - fixed parallel port LCD display support on multi-cpu x86;
*) bridge - fixed use-ip-firewall-for-vlan in setups with multiple bridges;
*) ipv6 - fixed DHCP-PD client skips some steps when renewing lease;
*) upnp - fixed protocol port selection for upnp protocol comunications;
*) firewall - fixed limit and dst-limit options.
*) winbox - fixed wireless interface l2mtu (VirtualAP and WDS interface creation in winbox)
*) winbox - fixed multiple firewall rule moving in Winbox 2
*) simple queues - restrict all changes in dynamic simple queues
nkourtzis
Re: v6.32.1 released
Tue Sep 08, 2015 11:35 am
What about these other bugfixes of the latest .33 RC? They are not present in .32.1. Will they be included in a future .32.x release?
*) RB532/RB564 - fixed no link after ethernet disable/enable;
*) tile - fixed occasional deadlock on module unload;
*) ipsec - fix sockaddres buffer size on id generation for ipv6 address;
*) mesh - fix router lock-up when interface is added/removed;
Passionate about networks
Enthusiastic about Mikrotik
MTCNA | MTCRE | MTCINE
No trees were killed to send this message,
but a large number of electrons were terribly inconvenienced.
normis
Tue Sep 08, 2015 11:36 am
they will be in v6.33 as the RC name suggests.
Only critical issues were backported to 6.32.1
Ansy
Tue Sep 08, 2015 11:48 am
In addition to the closed topic http://forum.mikrotik.com/viewtopic.php ... 65#p498465
I happened to notice in System - Resources that one of the spare RB750UP devices has 250MHz CPU frequency instead of the normal 400MHz.
I do remember that just loaded ROS (twice) and upgraded firmware, but did not change CPU frequency manually.
Somehow it decreased itself, which led to a noticeable increase in the configuration file saving time and increased loading CPU by everyday Simple Queues/Firewall payload.
But I still can't believe that this strange CPU frequency self reduction will result in congestion device by management process or provoke a reboots or crashes when creating supout.rif -- that was a real bug, IMHO.
Please look if somebody noticed this issue too.
normis
Tue Sep 08, 2015 12:27 pm
Ansy, if the Kernel has crashed in a specific way, the CPU could be lowered.
You can just set it back. We will fix this issue so that it goes back to the original value. Thank you for reporting it.
nkourtzis
Tue Sep 08, 2015 2:42 pm
Are the ones below not critical? The first may require a reboot or site visit to fix, the second speaks for itself.
Besides, you said the point releases are to include bugfixes, not features. Bugs are not only the critical ones, right? How hard is it to backport these fixes anyway?
macgaiver
Tue Sep 08, 2015 2:48 pm
Are you sure that those changes doesn't break any other boards or feature?
have you tried them in ALL possible configurations?
fixes that breaks other stuff happened too many times before, you do not have to look too far - latest example was v6.31 and v6.32 release.
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
nkourtzis
Tue Sep 08, 2015 3:13 pm
If this is the case, then you are right.
mandrade
Tue Sep 08, 2015 3:59 pm
The torrent file PLEASE......
Please, understood, not all routerboard need or have internet access to do an auto update...
BR
IPANetEngineer
Trainer
Trainer
Tue Sep 08, 2015 4:20 pm
Just want to make sure I understand the release cycle...does this mean no new fixes will be added to 6.30.4 and that 6.32.1 is the latest bugfix?
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
cdiedrich
Forum Veteran
Forum Veteran
Tue Sep 08, 2015 4:24 pm
I can confirm this.
CCR1036, multiple site2site tunnels. The point where I upgraded from 6.31 seems obvious :-)
Thanks!
-Chris
Christopher Diedrich
MTCNA, MTCUME, MTCWE
Basel, Switzerland
Bremen, Germany
There are 10 types of people: Those who understand binary and those who don't.
There are two types of people: Those who can extrapolate from incomplete data
normis
Tue Sep 08, 2015 4:37 pm
No. Version name does not indicate the release chain. v6.30.4 is still the bugfix release.
v6.32.1 is the current one, because it includes also a lot of other changes (see v6.32 section of the changelog)
RouterOS will start showing the package chain in v6.33 so you will know what you have installed
Will
Tue Sep 08, 2015 4:50 pm
my RB450G has below warning, is it normal or bug?
ether2-master-local excessive broadcasts/multicasts, probably a loop
previous v6.30.4 doesnt have such problem.
pls help to solve it. thanks
w0lt
Tue Sep 08, 2015 5:01 pm
previous v6.31 doesnt have such problem.
I'm having the same issue. It stops when I revert back to v6.30.4
-tp
MTCNA - 2011
" The Bitterness of Poor Quality Remains Long After the Sweetness of Low Price is Forgotten "
IPANetEngineer
Trainer
Trainer
Tue Sep 08, 2015 5:32 pm
Good to hear....We have had a lot of success and stability with 6.30.x bugfix so far and hope to see it around for a long time as the most "stable" production version of RouterOS in the 6.x release family.
jarda
Tue Sep 08, 2015 6:07 pm
Please, put all the fixes of errors that occur in 6.30.4 to 6.30.5. Especially the RB532/RB564 - fixed no link after ethernet disable/enable
Make at least one version that will safely work! Let it be 6.30.
Thank you.
vortex
Forum Veteran
Forum Veteran
Tue Sep 08, 2015 6:25 pm
It could happen that some fix to 6.30.4 implies a significant change, so it does not belong in Bugfix directly.
jarda
Tue Sep 08, 2015 6:30 pm
So does it implies that there will never be stable ros version? Right?
lekozs
Tue Sep 08, 2015 7:51 pm
-tp
+1
...the same here... on my home router (RB 2011UAS-2HnD)
Since it was flooding my log I reverted back to 6.30.2.
... and YES I am absolutely sure I have NO loop in my network...!
vortex
Forum Veteran
Forum Veteran
Re:
Tue Sep 08, 2015 8:54 pm
6.30.x would be stable, but for certain fixes you would have to move to 6.32.x when it is stable and in Bugfix too, then 6.30.x could be abandoned.
At that point 6.33.x would be Current.
I guess the stable branches would not have to be abandoned too soon to ensure that the following one is really good and provide certainty to people who otherwise had no problem staying on the "broken" stable branch.
Note that it would even be possible that 6.32 is deemed unfixable in some other way and never enter Bugfix, so you would either have to wait in 6.30.x until 6.33.x enters Bugfix, or if your problem is too critical, try Current.
I think that for backporting of difficult fixes, rc versions not tagged as Bugfix on the stable branch would be needed. This would actually be a good idea for every release on the stable branch.
I guess for simplicity they would not have to be labeled rc, just not tag them as Bugfix immediately, but there should be a way of easily but safely seeing them on the upgrade page.
scampbell
Trainer
Trainer
Tue Sep 08, 2015 9:42 pm
+1 on various routers running 6.31 or greater. I revert to 6.30.4 and the message goes away.
MTCNA, MTCWE, MTCRE, MTCTCE, MTCSE, MTCINE, Trainer
___________________
Mikrotik Distributor - New Zealand
http://www.campbell.co.nz
vortex
Forum Veteran
Forum Veteran
Tue Sep 08, 2015 9:49 pm
I think Mikrotik needs to keep statistics of how many units are running each version to properly assess when it's not worth to continue maintaining a branch.
jarda
Tue Sep 08, 2015 9:52 pm
I am not ready to go forward the new bugs to get corrected the old ones. Let all bugs are corrected in 6.30.x and when all bugs will be corrected in 6.50.xx I will rethink if I need to update or not.
yurispb
Tue Sep 08, 2015 10:35 pm
Hello, I've just upgraded my RB951G-2HnD from 6.31 up to 6.32.1 and it went to reboot forever. That's funny, because your bugfix was addressed to fix that issue.
But that fact I got a brick is less funny. Would anybody please help me to unbrick my device?
vortex
Forum Veteran
Forum Veteran
Tue Sep 08, 2015 10:45 pm
Feature to think about: On detection of reboot loop, try to automatically downgrade to latest Bugfix release.
pbr3000
Tue Sep 08, 2015 11:22 pm
Good idea, but remember that not all devices have internet access. At least on my network.
vortex
Forum Veteran
Forum Veteran
Tue Sep 08, 2015 11:26 pm
Hence 'try'.
So configuration options:
- download location parameters
- version to downgrade to
- static IPs
plus standard fallback if those fail
Ivoshiee
Wed Sep 09, 2015 12:08 am
That release is useless for my RB911, as you can not upgrade/downgrade the device at all from the v6.32. The device will crash as soon as you try to reboot it. As upgrade does require rebooting then you'll never get off that version.
Is there a way to upgrade the software without requiring a reboot? Some command to make it just start the upgrade process?
pbr3000
Wed Sep 09, 2015 5:30 am
Hence 'try'.
- static IPs
You're right. I have not read that "try".
MTeeker
Wed Sep 09, 2015 5:35 am
I think the only remaining option for you is doing a Netinstall to cure any remnant of broken codes of RB911 at start up.
I suspect that it will fix the issue and allow subsequent rebooting.
pbr3000
Wed Sep 09, 2015 5:39 am
netinstall? Normis pointed to the instructions post (I guess) a few days ago. But if you don't have physical access to the device, forget it. I don't know commands to reboot a routerboard besides from... "system reboot" and "system package downgrade" :(
jarda
v6.32.1 released
Wed Sep 09, 2015 8:00 am
Before any update it is smart to make copy of partition to the failover partition if the device supports multiple partitions. It should boot automatically when the first updated partition doesn't boot or other problems with ros config occurs. Than you can easily revert back. But you need to be prepaired before otherwise the netinstall is the only option.
freemannnn
Long time Member
Long time Member
Wed Sep 09, 2015 8:48 am
how u do that ????
czjpczr
Wed Sep 09, 2015 9:11 am
you disable ip/neighbors in all devices connected to ether2-master-local
normis
Wed Sep 09, 2015 9:24 am
We already have such feature. It is called Partition:
http://wiki.mikrotik.com/wiki/Manual:Partitions
yurispb
Wed Sep 09, 2015 9:58 am
OK, but what about my bricked device?
normis
Wed Sep 09, 2015 10:08 am
Netinstall will fix it http://wiki.mikrotik.com/wiki/Manual:Netinstall
1. Power off
2. plug cable from Ether1 directly to your PC
3. Run Netinstall app
4. Hold RESET button on the RB and turn it on
5. Keep holding the button, until the PC Netinstall app shows the router as found
6. Specify version 6.32.1 packages and click "INSTALL"
vortex
Forum Veteran
Forum Veteran
Wed Sep 09, 2015 10:20 am
Which home users mostly will not use. It is the first time it attracts my attention.
normis
Wed Sep 09, 2015 10:23 am
Why not? Simple to use.
I did not say Partitions is an exuse to make bugs. I just pointed out how to avoid disaster by configuring a simple backup solution.
Kraken2k
Wed Sep 09, 2015 10:39 am
I see no sense doing this - besides, disabling this interface in ip/neighbor/discovery does not help the issue.
I have the same issue on RB1100AHx2 - second one, connected to the same network with VRRP interfaces on backup, disabled IPsec/EoIP tunnels and the same config shows no "probably a loop" messages
vortex
Forum Veteran
Forum Veteran
Wed Sep 09, 2015 10:45 am
Yes, it is relatively simple to use, but most home users just won't know. I think you should ship your devices already partitioned (maybe you already do).
normis
Wed Sep 09, 2015 10:50 am
Most home users don't upgrade 20 minutes after release. As you know, we pulled the release 20 minutes later.
marting
Wed Sep 09, 2015 11:24 am
How can I change my device to stay on the stable branch?
I use System > Packages > Check for Updates and it shows 6.32.1
Do I have to install stable branches by hand? I think concept of stable and beta/testing branch is fine. But I think it is the wrong way to provide the unstable releases by the common update function and provide stable updates only by the much more effort way.
normis
Wed Sep 09, 2015 11:29 am
Branch support was added only in 6.31
So you will only be able to do this starting from the next bugfix release, whenever this is released. For now, you can only update it manually.
marting
Wed Sep 09, 2015 11:41 am
Okay, got it. Great. Thanks for this feature.
yurispb
Wed Sep 09, 2015 12:43 pm
Wow. Normis, so I need to purchase a Windows license, install Windows,install Netinstall, use it just once (I hope so) and wipe that Windows out from my HDD?
Does any Linux software exist?
Regards.
marting
Wed Sep 09, 2015 12:47 pm
I´m quite sure it will also work with Wine as Winbox does so.
yurispb
Wed Sep 09, 2015 1:35 pm
Ok, I'll see what Netinstall can do under Wine.
yurispb
Wed Sep 09, 2015 1:40 pm
1. Power off
One more question - what will happen to my RouterOS License?
normis
Wed Sep 09, 2015 2:23 pm
Nothing. Netinstall will not touch it
w0lt
Wed Sep 09, 2015 4:19 pm
It appears that ROS v6.33rc4 still has the "excessive broadcast/multicasts probably a loop" error. Once again, reverting to
ROS 6.30.4 remedies it.
Back to the drawing board, eh? :shock:
-tp
MTCNA - 2011
adyb76
Trainer
Trainer
Wed Sep 09, 2015 5:36 pm
We are again experiencing FCS errors when using Ubiquiti AirFibre 24 point to point links.
This does not occur when we are using RoS 6.7
We experienced this previously and the engineers at Mikrotik fixed the issue.
Ade
glucz
Wed Sep 09, 2015 7:14 pm
X86 still shows 1 CPU on a multicore system. The changelog says that this problem had been fixed. Can anyone else see this problem with 6.32.1 ?
czjpczr
Wed Sep 09, 2015 7:38 pm
-tp
Older RouterOS versions did not have such warning logs about probable loops. 6.31=>
Ivoshiee
Wed Sep 09, 2015 10:29 pm
Last time I tried it with no success and it was quite recent attempt. Mikrotik should make a native netinstall for Linux or make contributions to Wine to make it working. Will they do it? Nope.
normis
Thu Sep 10, 2015 10:25 am
Netinstall works fine in Wine. It works in Mac, Linux of all flavors. If you need help to run it, email support or make a new topic.
santa
Thu Sep 10, 2015 12:58 pm
Are there any chances for native Linux ports of WinBox and Netinstall ?
normis
Thu Sep 10, 2015 1:00 pm
Since Wine works so well, and that we have Webfig (browser) for config, very low chance.
105547111
Thu Sep 10, 2015 2:45 pm
Hi Normis,
Can we please get 64 bit versions of winbox and net install. In case your not aware Redhat 7 and Centos 7 now have no 32 bit libraries these are pure 64 bit OS.
Means wine is only 64 bit there's no 32 bit so winbox and net install can't run...
Surely a 64 bit compiled version be easy? I'm forced to keep a Centos 6 notebook since it's the last to have 32 bit libraries.
You can read about it on wine HQ there is no way to run 32 bit windoze programs in wine64...
Mazutti
Thu Sep 10, 2015 2:48 pm
Same here on RB2011UiAS-2HnD. Shows ether4 (which is switch 1 master port) probably has a loop, but router/switch is still stable.
Issue started after upgrading from 6.31 to 6.32, and still exists in 6.32.1.
Thanks,
Mazutti
Janosch
Thu Sep 10, 2015 5:08 pm
I had the same Issue with a CloudSwitch CRS125-24C-1S-RM in 6.31 with two WAN uplinks (WiMax & DSL)
After I had configured the second interfaces (I think the critical step was to a DHCP client on ether5 (my DSL uplink) it stopped.
It was in the whole network. Maybe a packet is misinterpreted since 6.31 causing this error-message.
Hope this will help to bring some light into this mystery..
It took me hours...
Janosch
vadimbn
Fri Sep 11, 2015 11:53 am
You can have a problem with netinstall in the Wine environment. In this case You can use one of official microsoft Virtual Machines for linux. Oracle VirtualBox is included in the linux repositories and free for use.
Veni. Vidi. Feci.
RBSXTLTE3-7, CRS326-24G-2S+RM, RB850Gx2, RBMRTG, RB1100AHx4, RB750Gr3, RBD52G-5HacD2HnD-TC, Woobm-USB
vortex
Forum Veteran
Forum Veteran
Fri Sep 11, 2015 12:48 pm
Moving from 32-bit to 64-bit in a not-really-high-level language like C++ is not necessarily easy.
TonyJr
Sat Sep 12, 2015 10:24 am
Has anything to do with PIM been fixed? After upgrading all of my devices from 6.2 to 6.2.1 I notice that for the first time, BLF buttons are working on my local IP phones, for phones that are at a site connected by a SSTP tunnel with PIM setup. Also group paging works to that site now, which uses multicast too.
I am happy that nothing else has broken, and now my IP phones work correctly.
Tony
105547111
Mon Sep 14, 2015 9:06 pm
Yes but all Tile routers are full 64 bit OS :)...........
zervan
Mon Sep 14, 2015 11:03 pm
I had the same Issue with a CloudSwitch CRS125-24C-1S-RM in 6.31 with two WAN uplinks (WiMax & DSL)h
The same here on CRS212-1G-10S-1S+ - just one interface (all ports switched - the same master port). Another problem - SFP modules (OEM) temperatures are not available.
The 6.31 was without this issues. What's wrong?
Dusan Zervan from Slovakia
MTCNA, MTCRE
antwal
Tue Sep 15, 2015 1:24 pm
Report a bug: http://prntscr.com/8gjtre , because it has been aligned all right?
Thanks.
w0Lf
Wed Sep 16, 2015 9:53 am
After upgrading to version 6.32.1, stopped working some OID. Example of snmpwalk:
Board: 2011UAS-2HnD-IN
[admin@MikroTik] > system health print oid
             active-fan: .1.3.6.1.4.1.14988.1.1.3.9.0
                voltage: .1.3.6.1.4.1.14988.1.1.3.8.0
            temperature: .1.3.6.1.4.1.14988.1.1.3.10.0
  processor-temperature: .1.3.6.1.4.1.14988.1.1.3.11.0
                current: .1.3.6.1.4.1.14988.1.1.3.13.0
      power-consumption: .1.3.6.1.4.1.14988.1.1.3.12.0
             psu1-state: .1.3.6.1.4.1.14988.1.1.3.15.0
             psu2-state: .1.3.6.1.4.1.14988.1.1.3.16.0
0 debian ~ # snmpwalk -c public -v2c 192.168.1.1 .1.3.6.1.4.1.14988.1.1.3
SNMPv2-SMI::enterprises.14988.1.1.3.8.0 = INTEGER: 241
SNMPv2-SMI::enterprises.14988.1.1.3.9.0 = STRING: "n/a"
SNMPv2-SMI::enterprises.14988.1.1.3.10.0 = INTEGER: 360
SNMPv2-SMI::enterprises.14988.1.1.3.14.0 = INTEGER: 600
I am interested in OID with the temperature of the processor.
0 debian ~ # snmpget -c public -v2c 192.168.1.1 .1.3.6.1.4.1.14988.1.1.3.11.0
Error in packet
Reason: (noSuchName) There is no such variable name in this MIB.
Failed object: SNMPv2-SMI::enterprises.14988.1.1.3.11.0
strods
Wed Sep 16, 2015 11:26 am
w0Lf:
This device does not have CPU temperature monitor. Only temperature monitor (36C):
http://routerboard.com/RB2011UiAS-2HnD-IN
CPU temperature monitor No
manjil
Wed Sep 16, 2015 9:58 pm
hello sir plz told me how to make statik ip in mikrotik
dadoremix
v6.32.1 released
Wed Sep 16, 2015 10:06 pm
Read wiki mikrotik
Read manual, these topic is for 6.32.1 mikrotik
Teq
Fri Sep 18, 2015 12:43 am
Hello, I notice that the RB1200 is no longer listed under any of the instruction sets on the download page (unless I'm missing something). Is it still supported? What is the latest stable version that can be installed on the RB1200?
normis
Fri Sep 18, 2015 8:56 am
The list is updated manually and sometimes is not up to date. The software is not made per-board. If the device has a PPC processor, it is automatically supported. We don't remove support "per device"
popovdv
Sat Sep 19, 2015 2:56 pm
still have high cpu (100%) load on main CapsMan router when Caps start upgrading
first it's this bug was in 6.31 now it still in 6.32
when do you fix it?
docmarius
Sun Sep 20, 2015 1:21 am
The PPoE upload speed limitation bug resolved in 6.30.4 and in 6.31 RCs is present on my RB1100AHx2 in 6.32.1 (2Mbps vs. 200Mbps)... Should this not had to be fixed long time ago?
Torturing CCR1009-7G-1C-1S+, RB450G, RB750GL, RB951G-2HnD, RB960PGS, RB260GSP, OmniTIK 5HnD and NetMetal 922UAGS-5HPacD + R11e-5HnD in my home network.
WirelessRudy
Sun Sep 20, 2015 2:54 am
See screendump:
Fixed IP on bridge is shown in address list, dhcp-client acquired IP is not shown.
If renew the dhcp-cl the same IP is handed out by server again and shown as renewed by the client.
Still it is not in the address listing.
Winbox or telnet give same result....
This must be bug. It is not harming the unit from normal function but it can't be right....
Show your appreciation of this post by giving me Karma! Thanks.
Rudy R. Puister
WISP operator based on MT routerboard & ROS.
strods
Mon Sep 21, 2015 12:26 pm
This topic will be frozen. If you have any issues with 6.32.1, then please test 6.32.2. If issue/s persist, then use this forum topic:
http://forum.mikrotik.com/viewtopic.php?f=21&t=100643
Users browsing this forum: No registered users and 9 guests
