bertj
Which SXT to choose?
Fri Sep 11, 2015 12:34 am
I need install point-to-point link on 2 buildings on 200 meters distance.
I want to buy SXT because it is easy install.
What model should to order:
1. SXTG 5HPacD 802.11ac, 16dBi, 28 degree antenna,
2. SXTG 5HPacD HG 802.11ac, 17dBi, 24 degree antenna,
or
3. SXTG 5HPacD SA 802.11ac, 13 dBi, 90 degree antenna ?
Thanks for help
chechito
Re: Which SXT to choose?
Fri Sep 11, 2015 2:10 am
use the cheaper RBSXT5nDr2 sxt lite 5 in bridge mode you can operate even at 5dbm tx power without problem
bertj
Fri Sep 11, 2015 4:23 pm
Thank you chechito for replay.
I want bay 802.11ac for max throughput. What it's on 80Mhz channel?
I'll set minimum TX power, but which antennas will be better: 24 degree or 90 degree?
Regards :)
gabrielpike
Fri Sep 11, 2015 5:02 pm
You will probably want the 24 degree sxt with higher gain. The 90 degree is meant to be PTMP AP.
Gabriel Pike
MTCNA
chechito
Fri Sep 11, 2015 5:09 pm
yes 24 degree its better because takes less noise from surrounding environment
80mhz will be fine
bertj
Fri Sep 11, 2015 5:56 pm
ok, I will get 5HPacD HG with 24 degree antenna.
Thanks for quick response.
Users browsing this forum: Bing [Bot] and 54 guests
