1001001
shutting down interfaces at a specific time
Fri Sep 25, 2015 12:14 pm
Hello everybody,
would it be possible to write a script that shutsdown an interface, lets say between 2200h and 0600h everyday?
If yes does somebody out there have a code snippet i can use to get started?
Best regards
1001001
PaulsMT
Re: shutting down interfaces at a specific time
Fri Sep 25, 2015 1:29 pm
If You want to run only one command on specific time, you don't need a script, you can just add scheduler:
to disable interface at 22:00
/system scheduler add start-time=22:00:00 on-event={:interface ethernet disable ether5}
second scheduler to enable interface at 6:00
/system scheduler add start-time=06:00:00 on-event={:interface ethernet enable ether5}
1001001
Fri Sep 25, 2015 1:43 pm
Thanks for your answer.
What if we had to do this at different times on different days?
Best regards
1001001
freemannnn
Long time Member
Long time Member
Sat Sep 26, 2015 12:58 pm
you have to make schedules that start for example 26-09-2015 "saturday" and repeat "weekly" so it runs every week same day
Users browsing this forum: No registered users and 53 guests
