paldos
Connection Rate not work on RB951-2n
Tue Sep 29, 2015 2:05 pm
ver:6.3x
jarda
Tue Sep 29, 2015 5:12 pm
And what do you expect that should happen now?
paldos
Re: Connection Rate not work on RB951-2n
Wed Sep 30, 2015 4:04 am
Hoping to fix this bug
chechito
Wed Sep 30, 2015 5:00 am
yes that problem persist i hope mikrotik solve it soon its a handy feature to mangle, mark or filter connections according to its rate
jarda
Wed Sep 30, 2015 6:24 am
If you have a bug, make supout file and send it with description to support via email.
freemannnn
Long time Member
Long time Member
Thu Oct 01, 2015 2:09 pm
connection-rate works in 6.28 and previous versions. i cant understand why its not fixed yet.
why to make a supout? its not working even after reset configuration and with a simple quickset
alaskanjackal
Fri Oct 02, 2015 10:06 pm
I'm seeing this, too. Dropped the connection-rate parameter from a Mangle rule and it properly marks the traffic. Add it back in and the traffic is not marked (despite being within the connection-rate parameters).
It does seem to be a bug to me, too.
Users browsing this forum: Google [Bot], jasoncarwile, Kramerraider, sindy, Znevna and 167 guests
