wirdo
XR - when?
Fri Oct 01, 2004 8:38 pm
Great feature on new atheros cards is available for 4-5 months already but not in routeros yet... please update drivers to include it. Thanks!
mag
Re: XR - when?
Sat Oct 02, 2004 10:17 am
could you explain a bit, what feature this is and why it would be important to have it?
tia.
matthias
wirdo
Sat Oct 02, 2004 11:24 am
ask google.
stephenpatrick
Forum Veteran
Forum Veteran
Sat Oct 02, 2004 12:26 pm
Looking on the web at some articles:
http://www.theregister.co.uk/2003/09/15 ... ifi_range/
http://wireless.ittoolbox.com/browse.as ... aper%2Epdf
http://www.networkcomputing.com/showite ... D=15200422
It is a proprietary "WiFi extension" on the later chipsets, which "supports low SNR operation". Atheros claims a 3x range extension.
Not sure whether this is supported in MT, I guess not yet, I would expect to see an 'XR' switch to enable/disable.
Regards
Stephen
mag
Sun Oct 03, 2004 12:32 am
thanks for the links, i have seen d-link has boxes (e.g. DWL-2100AP) claiming to use XR. as the white paper states, it works by improving sensibility down to -105 dB and lowering bandwith below 1mbps so it seems to me a technique mostly for the low-cost 802.11g market.
if it is an atheros chipset feature, it should probably not too difficult to make an XR option-switch. nice to have, but not very important.
regards,
matthias
Hammy
Forum Veteran
Forum Veteran
Tue Oct 05, 2004 6:56 pm
but wouldn't squeezing a couple extra db out of a link be worth a simple switch?
mag
Tue Oct 05, 2004 9:00 pm
as i said: a nice to have low-cost-market feature.
i know what a good receive-amplifier with -105dB costs, therefore i do not think atheros is using such one. the white paper does not mention any other radio parameters too.
regards,
matthias
jonbrewer
Fri Oct 22, 2004 12:51 pm
regards,
matthias
Hi Matthias,
I think you have not read about Atheros XR. The receive sensitivity is really this good.
Having XR support means that connections will hold on for another 10db and won't just drop at -92.
This is very important where we can only use 5.2-5.3 GHz at max EIRP of 250mW.
Look at Atheros website!
Cheers,
Jon
Hammy
Forum Veteran
Forum Veteran
Fri Oct 22, 2004 5:21 pm
Are all modulations increased, or are there just additional ones?
Users browsing this forum: bpwl, stevan90 and 82 guests
