arafat586
VPN Configure step by step
Tue Oct 13, 2015 1:55 pm
Step1: At first click PPP then click interface then click PPTP Server then click Enable > Apply > OK
Step2: PPP > Secrets + Name=test2, password=test , profile= defaultencryption, Local address=192.168.5.1(must be other end Gateway), Remote address=192.168.5.100 (any private IP Local site) > Apply >OK
Dial up create for windows PC: Open Network and Sharing Center > Setup a new connection or Network > Connect to workplace > Next > use my internet connection (VPN) click > Internet address = Real IP > Next >connect ( finished ): Step by Step figure has given below
Click set up a new connection or network , VPN connection> then click connected to a workplace then click next.
Click connect to workplace then fill up internet address such as (43.224117.198) must be real IP
then click next.
Click Open Network and Sharing Center then click Change adapter settings then click VPN connection then put user name and password then click connect >ok
you can see the video for better understand
https://www.youtube.com/watch?v=c1wGbH4OMnE
http://greentechrevolution.com/vpn-configure/
BLAKE12
Re: VPN Configure step by step
Wed Oct 14, 2015 3:24 pm
Step 1: Setup requirements
Step 2: Implement DHCP services
Step 3: Create an enterprise certificate authority
Step 4: Install IAS
Step 5: Configure IAS
Step 6: Create a remote access policy
Step 7: Configure the VPN server
Step 8: Associate the VPN server with the DHCP server
Step 9: Configure your remote clients
Step 10: Test the client connection
Step 11: Alternate VPN configuration options
Devon
Sun Feb 07, 2016 7:35 pm
I'd be thankful for a comprehensive post specific to setting up and using a VPN including how one would allow other trusted people to use it from anywhere.
Mazies
Thu Apr 14, 2016 4:33 pm
Step 4: Install IAS
Hey I am newbie to here but how may i configure vpn on iPhone ?
jebz
Fri Apr 15, 2016 1:24 pm
I've found this guide quite helpful. It has a section toward the end for iPhones.
http://www.nasa-security.net/mikrotik/m ... ith-ipsec/
pamelabryant454
Thu Jul 28, 2016 8:21 pm
Download the Network Manager applet and plugin. You can install both the applet and the plugin at the same time with the following command. ...
Click on the Network Manager icon. Select the VPN tab. ...
Enter your VPN information. ...
Click the advanced button. ...
Connect to the VPN
BennyT
Tue Jan 24, 2017 12:46 am
i am using L2TP over IPsec with the iPhones on my 3011 with 6.38 Release Stable. I have problems with my windows to connect using L2TP too so the question is how can i got this working? Is there any other chance of VPN which i can configure to use a free VPN client like Shrewsoft?
If there is a step by step instruction it would help me.
Thanks a lot.
Regards,
Ben
cejkavo
Wed Oct 11, 2017 10:08 pm
I just went here to say thank you.
First manual worked. I created multiple useres via copy of secret and changing ip.
Fast and clear, you saved ma ass.
Users browsing this forum: No registered users and 3 guests
