IPANetEngineer
Trainer
Trainer
10 Gig over EoIP tunnel - it is possible!!
Sat Oct 17, 2015 1:45 am
10 Gbps (unencrypted) is possible in EoIP (and 7.5 Gbps of encrypted EoIP over IPSEC) !!!
Details below:
http://www.stubarea51.net/2015/10/16/10 ... ip-tunnel/
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
chechito
Re: 10 Gig over EoIP tunnel - it is possible!!
Sat Oct 17, 2015 11:02 am
very nice test!!!
about the topology:
who equipment was a terminator for the eoip or eoip over ipsec tunnel or tunnels??
how many tcp connections are established for the test??
IPANetEngineer
Trainer
Trainer
Sat Oct 17, 2015 10:00 pm
Thanks Chechito!
Here is the network diagram:
We used both of the CCR1036-8G-2S+ to terminate the EoIP tunnels with the 1072 routing between them. Then we connected the 1036's to our ESXi server at 10 gig each to be able to push a full 10 Gbps from end to end.
Here is a brief overview of how many TCP streams we used.
10 Gig unencrypted (9000 MTU) - Minimum of 2 to get max throughput.
7.5 Gig IPSEC encrypted (9000 MTU) - Minimum of 4 to get max throughput.
6.4 Gig unencrypted (1500 MTU) - Minimum of 10 to get max throughput.
1.7 Gig IPSEC encrypted (1500 MTU) - Minimum of 25 to get max throughput.
If you spend a lot of time tweaking the TCP buffers, window size, etc, you might be able to get it done with fewer streams. We didn't really spend much time messing with those for this test.
chechito
Sat Oct 17, 2015 11:25 pm
thx for your reply
very interesting
that means this test proves ccr1036 performance not ccr1072, ccr1072 its only passing the traffic
just another questions:
the cpu sage was 100% on all cores??
which settings of ipsec sa proposal do you use (default is sha1 aes-128)??
doush
Long time Member
Long time Member
Sun Oct 18, 2015 4:40 pm
Please make a PPPoE test so we can see if it is possible to use 1072 as an access concentrator.
chechito
Mon Oct 19, 2015 4:07 am
its a good idea
they have announced that test and another more
i think seen this test you can get some idea of pppoe performance, eoip even without ipsec its more demanding than pppoe
of course firewall, nat, mangle an queues are the most demanding features and is impossible to recreate every possible scenario
IPANetEngineer
Trainer
Trainer
Mon Oct 19, 2015 7:42 pm
We are definitely working on the PPPoE tests...we have had a VERY positive response from the MikroTIk community to the testing we are doing and so we are trying to prioritize all the requests that have come in for the CCR1072 :-)
Will let you guys know when we get close to publishing results. :D
IPANetEngineer
Trainer
Trainer
Thu Oct 22, 2015 9:01 pm
Just to give you a little preview of our PPPoE testing going on right now.....
30,000 PPPoE connections with 30,000 simple queues so far. We are working on a post for stubarea51.net and will share details and testing setup very soon.
chechito
Fri Oct 23, 2015 12:26 am
thx for your reply
just another questions about eoip test:
IPANetEngineer
Trainer
Trainer
Fri Oct 23, 2015 5:12 pm
thx for your reply
It actually wasn't too high...I think we never saw it go above 10% and was usually 3 to 4 % on average.
IPSec settings used were the default when using the ipsec key in EoIP which is sha1 / aes128.
timur
Wed Nov 04, 2015 3:55 pm
Can RouterOS installed on VMWare machine provide the same performance? If it can do this, what is the hardware requirements?
Users browsing this forum: No registered users and 10 guests
