azurtem
Trainer
Trainer
RB922UAGS-5HPacD + R11e-2HPnD
Fri Oct 23, 2015 12:13 pm
Hi
I'd like to combine these two elements together in order to offer a dual band access point
Is there any reason why this wouldn't be technicazlly speaking feasible or recommendable ?
yann
gtj
Re: RB922UAGS-5HPacD + R11e-2HPnD
Fri Oct 23, 2015 5:19 pm
I use the R11e cards in RB921UAGS NetMetal 5 devices and it's been working well. No issues.
azurtem
Trainer
Trainer
Fri Oct 23, 2015 5:37 pm
thanks GTJ
gtj
Fri Oct 23, 2015 6:20 pm
Actually, one thing to be aware of is input power. Make sure you're supplying enough to handle both radios.
azurtem
Trainer
Trainer
Fri Oct 23, 2015 8:35 pm
is 24V enough or is 48V more recommended ?
gtj
Fri Oct 23, 2015 9:31 pm
The max for the RB922 is 30V.
Since the RB922 is listed at 17 watts (about 708 ma at 24v) and the R11e is 7 watts (about 291 ma at 24v), you need a minimum of 1 amp (with nothing to spare).
If you're using a standalone power supply, make sure it's at least 1.5A
If you're doing PoE from another device make sure the device can supply 1A on a single port.
Regardless, if you have a long cable, use Cat 6 (23ga wire) instead of Cat 5 (24ga wire) to reduce the current loss.
azurtem
Trainer
Trainer
Sat Oct 24, 2015 12:28 pm
thank you very much GTJ
efaden
Sat Oct 24, 2015 4:28 pm
I'm basically doing this myself.... Works really well... I actually have three of them powered by a 260GSP...
azurtem
Trainer
Trainer
Tue Oct 27, 2015 6:04 pm
Thanks Efaden
What type of power supply are you using with the 260GSP ?
efaden
Tue Oct 27, 2015 10:29 pm
The one it came with.
azurtem
Trainer
Trainer
Wed Oct 28, 2015 2:58 pm
thanks Efaden
yann
Users browsing this forum: No registered users and 25 guests
