Hi
Any one have filter rule to protect server from hacker in outside please write your rule here.
Security rule
Thank you1. Disable unused services from your MT device.
2. Add firewall rules to stop port scanning.
3. That it.
Thank youI like the following approach:
- place the server on a private IP
- using destination nat forward only the services you need to be accessible from the WAN
- use masquerade for outgoing server connections
- drop every other forward from the outside to the server
Thank youRouter = server?![]()
If so Wiki have some examples http://wiki.mikrotik.com/wiki/Firewall
If server is server behind router and providing some services to outside then we need more information.
