MUM Europe 2020
ekkas
Long time Member
Long time Member
NStreme question
Thu Aug 10, 2006 5:20 pm
Will NStreme work fine with an AP-bridge and multiple MT stations, or is it meant just for a point-to-point link?
Ekkas
cmit
Thu Aug 10, 2006 5:29 pm
It will work fine for a point-to-multi-point network (and is what NStreme was designed for, amongst other - to work around hidden station problem etc.). The only thing (rather obvious) to observe is that all your clients have to MikroTik, too (and be configured for NStreme)...
Best regards,
Christian Meis
Best regards,
Christian Meis
Equis
Forum Veteran
Forum Veteran
Fri Aug 11, 2006 2:43 pm
Nstream (and polling) is perfect for p2mp
I now have 100% mikrotik and not sure if my phone still works (no support calls anymore)
Nstream will add abot 3ms to a ping but with multiple clients under heavy load thats where is is perfect
I have done spped tests and will nstream on ping sstay low under full load
rmdjapri
Sat Aug 12, 2006 11:41 am
Can we do Nstream with RB532A ? I assume that the resources will not be enough? CMIIW.
Best regards,
Romie Djapri
ekkas
Long time Member
Long time Member
Sat Aug 12, 2006 12:14 pm
I also found that NStreme does improve bandwidth test up to more than 100% faster, but sometimes the connection drops, disable nstreme and everything is ok again... P2P link with grid antennas, on 5GHz.
Equis
Forum Veteran
Forum Veteran
Sun Aug 13, 2006 1:01 pm
single nstream on rb500 is fine (20mbps) with good signal
Alex
Sun Aug 13, 2006 11:24 pm
and without nstreme and with g-turbo 32 mbps... :shock:
aviper
Sun Aug 13, 2006 11:33 pm
Short of CPU power i think ...
rmdjapri
Mon Aug 14, 2006 4:36 am
What is a good signal mean? Is it -50 ~ -70 is still consider as a good signal?
best regards,
Romie Djapri
Equis
Forum Veteran
Forum Veteran
Mon Aug 14, 2006 4:38 am
best regards,
Romie Djapri
-70 is good signal on 5.8ghz
rmdjapri
Mon Aug 14, 2006 4:53 am
What about on 2.4 ghz? Is it still a good signal?
Equis
Forum Veteran
Forum Veteran
Mon Aug 14, 2006 4:55 am
-70 is OK on 2.4 but I normally don't get that high speeds
perhaps 10mbps
Others may have different experiances
Users browsing this forum: Google [Bot] and 33 guests
