Here is a copy of my export, I have a voice vlan and a data vlan. The dhcp appears to be working. I'm getting 192.168.2.x addresses on my Voip equipment with no trouble. Call quality seems fine. Yet, when I go to interfaces in winbox and look at the voice vlan I see no traffic other than what seems to be occasional broadcast traffic, even when I know there is a call in progress. I've also seen some trouble with certain websites loading on the data vlan. I'm new to this sort of setup (vlans) and I thought I had everything working, but the lack of visible traffic on the interface is bothersome. Can anyone help me see where my config is faulty? Thank you.
add disabled=yes mtu=1500 name="Voice Vlan"
add admin-mac=4C:5E:0C:7C:81:47 auto-mac=no disabled=yes mtu=1500 name=bridge-local
set [ find default-name=ether1 ] name=ether1-gateway
set [ find default-name=ether4 ] master-port=ether3
/ip neighbor discovery
set ether1-gateway discover=no
/interface vlan
add interface=ether3 l2mtu=1594 mtu=1496 name=Data vlan-id=100
add interface=ether3 l2mtu=1594 mtu=1496 name=Voice vlan-id=200
add disabled=yes interface=ether3 name=vlan1 vlan-id=1
set [ find default-name=ether2 ] master-port=ether3
set [ find default=yes ] eap-methods=""
add authentication-types=wpa2-psk eap-methods="" management-protection=allowed mode=dynamic-keys name=profile1 \
supplicant-identity="" wpa2-pre-shared-key=SunshineGardens2015
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-ht-above disabled=no distance=indoors l2mtu=2290 \
mode=ap-bridge security-profile=profile1 ssid=xxxxxxx
add name="Access Pool" ranges=10.10.11.1-10.10.11.2
add name=dhcp_pool1 ranges=192.168.3.2-192.168.3.254
add name=dhcp_pool3 ranges=192.168.2.200-192.168.2.254
add name=dhcp_pool4 ranges=192.168.1.100-192.168.1.254
add address-pool="Access Pool" disabled=no interface=ether5 lease-time=3d name=Access
add address-pool=dhcp_pool1 disabled=no interface=wlan1 lease-time=3d name=dhcp1
add address-pool=dhcp_pool3 disabled=no interface=Voice lease-time=3d name=dhcp3
add address-pool=dhcp_pool4 disabled=no interface=Data lease-time=3d name=dhcp2
/ppp profile
set [ find name=default ] name=default
set [ find name=default-encryption ] name=default-encryption
add address=10.10.11.1/30 interface=ether5 network=10.10.11.0
add address=192.168.1.1/24 interface=Data network=192.168.1.0
add address=192.168.2.1/24 interface=Voice network=192.168.2.0
add address=*********
interface=ether1-gateway network=********
add address=192.168.3.1/24 interface=wlan1 network=192.168.3.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid disabled=no interface=ether1-gateway
/ip dhcp-server lease
add address=192.168.2.252 client-id=1:0:15:65:7b:a6:71 mac-address=00:15:65:7B:A6:71 server=dhcp3
add address=192.168.1.247 client-id=1:0:1b:fc:8b:e:ae mac-address=00:1B:FC:8B:0E:AE server=dhcp2
add address=192.168.1.248 client-id=1:50:e5:49:14:ca:20 mac-address=50:E5:49:14:CA:20 server=dhcp2
add address=192.168.2.251 client-id=1:0:15:65:79:d2:80 mac-address=00:15:65:79:D2:80 server=dhcp3
add address=192.168.2.249 client-id=1:0:15:65:7e:10:6f mac-address=00:15:65:7E:10:6F server=dhcp3
add address=192.168.1.107 client-id=1:4:a1:51:1a:c1:6a mac-address=04:A1:51:1A:C1:6A server=dhcp2
add address=10.10.11.0/30 dns-server=10.10.11.1 gateway=10.10.11.1 netmask=30
add address=192.168.1.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.1.1 netmask=24
add address=192.168.2.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.2.1 netmask=24
add address=192.168.3.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.3.1
set max-udp-packet-size=512 servers=8.8.8.8,4.4.4.4
/ip dns static
add address=192.168.1.1 name=router
add chain=forward dst-address=192.168.1.1-192.168.1.254 in-interface=ether5 src-address=10.10.11.2
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=established
add chain=input comment="default configuration" connection-state=related
add action=drop chain=input comment="default configuration" in-interface=ether1-gateway
add chain=forward comment="default configuration" connection-state=established
add chain=forward comment="default configuration" connection-state=related
add action=drop chain=forward comment="default configuration" connection-state=invalid
add action=masquerade chain=srcnat comment="default configuration" out-interface=ether1-gateway
add chain=srcnat out-interface=ether1-gateway src-address=10.10.11.0/24
add chain=srcnat out-interface=ether1-gateway src-address=192.168.1.0/24
add chain=srcnat out-interface=ether1-gateway src-address=192.168.2.0/24
add chain=srcnat out-interface=ether1-gateway src-address=192.168.3.0/24
/ip ipsec policy
set 0 dst-address=0.0.0.0/0 src-address=0.0.0.0/0
add distance=1 gateway=*********
/system clock
set time-zone-autodetect=no
/tool mac-server
add interface=ether2
add interface=ether4
add interface=ether5
add interface=wlan1
add interface=bridge-local
/tool mac-server mac-winbox
add interface=wlan1
/tool romon port
add disabled=no
