cliffdike
Static NAT from external seems to hijack VPN traffic on same port
Thu Oct 29, 2015 10:40 pm
I’ve got a VPN (IPSec Site to Site) setup between two offices and it works great. I also have a static nat (port forward) on the external interface of my office for port 9100 that works as expected.
External if: forward 9100 to 10.0.0.151 on LAN for remote printing.
There is another printer located at 10.0.0.152 on the lan.
The server on the other end of the IPSec tunnel (192.168.1.111) sends traffic to 10.0.0.152:9100 and the router directs it to 10.0.0.151:9100
I’m baffled. I’ll post my config here after I sanitize it.
cliffdike
Re: Static NAT from external seems to hijack VPN traffic on same port
Fri Oct 30, 2015 9:56 pm
	# oct/29/2015 17:41:23 by RouterOS 6.32.2
	# software id = TDAR-4EY2
	add admin-mac=E4:8D:8C:29:A1:C5 auto-mac=no name=bridge-local
	set [ find default-name=ether1 ] name=ether1-gateway
	set [ find default-name=ether2 ] name=ether2-master-local
	set [ find default-name=ether3 ] master-port=ether2-master-local name=ether3-slave-local
	set [ find default-name=ether4 ] master-port=ether2-master-local name=ether4-slave-local
	set [ find default-name=ether5 ] master-port=ether2-master-local name=ether5-slave-local
	set [ find default-name=ether6 ] name=ether6-master-local
	set [ find default-name=ether7 ] master-port=ether6-master-local name=ether7-slave-local
	set [ find default-name=ether8 ] master-port=ether6-master-local name=ether8-slave-local
	set [ find default-name=ether9 ] master-port=ether6-master-local name=ether9-slave-local
	set [ find default-name=ether10 ] master-port=ether6-master-local name=ether10-slave-local
	/ip neighbor discovery
	set ether1-gateway discover=no
	/ip ipsec proposal
	set [ find default=yes ] enc-algorithms=3des lifetime=8h pfs-group=none
	add bridge=bridge-local interface=ether2-master-local
	add bridge=bridge-local interface=ether6-master-local
	add bridge=bridge-local interface=sfp1
	add address=10.0.0.100/24 comment="default configuration" interface=bridge-local network=10.0.0.0
	add address=x.x.x.93/29 interface=ether1-gateway network=x.x.x.88
	/ip dhcp-client
	add comment="default configuration" dhcp-options=hostname,clientid interface=ether1-gateway
	add address=10.0.0.0/24 comment="default configuration" gateway=10.0.0.100 netmask=24
	set allow-remote-requests=yes servers=8.8.8.8,75.75.75.75
	/ip dns static
	add address=10.0.0.100 name=router
	add chain=input comment="default configuration" protocol=icmp
	add chain=input comment="default configuration" connection-state=established,related
	add action=drop chain=input comment="default configuration" in-interface=ether1-gateway
	add action=fasttrack-connection chain=forward comment="default configuration" connection-state=established,related
	add chain=forward comment="default configuration" connection-state=established,related
	add action=drop chain=forward comment="default configuration" connection-state=invalid
	add action=drop chain=forward comment="default configuration" connection-nat-state=!dstnat connection-state=new in-interface=ether1-gateway
	add chain=srcnat dst-address=192.168.1.0/24 log=yes log-prefix=IPSEC-OUT src-address=10.0.0.0/24
	add action=masquerade chain=srcnat comment="default configuration" out-interface=ether1-gateway
	add action=dst-nat chain=dstnat dst-port=9100 in-interface=ether1-gateway log=yes protocol=tcp to-addresses=10.0.0.151 to-ports=9100
	/ip ipsec peer
	# Unsafe configuration, suggestion to use certificates
	add address=x.x.x.162/32 enc-algorithm=3des exchange-mode=aggressive lifetime=8h nat-traversal=no secret=xxxxxxxxxxxxx
	/ip ipsec policy
	add dst-address=192.168.1.0/24 sa-dst-address=x.x.x.162 sa-src-address=x.x.x.93 src-address=10.0.0.0/24 tunnel=yes
	add distance=1 gateway=x.x.x.94
	add distance=1 dst-address=192.168.1.0/24 gateway=ether1-gateway
	/lcd
	set default-screen=informative-slideshow
	/system clock
	set time-zone-name=America/Los_Angeles
	/tool mac-server
	add interface=ether2-master-local
	add interface=ether3-slave-local
	add interface=ether4-slave-local
	add interface=ether5-slave-local
	add interface=ether6-master-local
	add interface=ether7-slave-local
	add interface=ether8-slave-local
	add interface=ether9-slave-local
	add interface=ether10-slave-local
	add interface=sfp1
	add interface=bridge-local
	/tool mac-server mac-winbox
	add interface=sfp1
cliffdike
Fri Oct 30, 2015 9:58 pm
Log
13:57:55 firewall,info dstnat: in:ether1-gateway out:(none), src-mac 76:54:7d:91:5d:0a, proto TCP (SYN), 192.168.1.111:36078->10.0.0.152:9100, len 60
13:57:55 firewall,info IPSEC-IN srcnat: in:(none) out:bridge-local, src-mac 76:54:7d:91:5d:0a, proto TCP (SYN), 192.168.1.111:36078->10.0.0.151:9100, NAT 192.168.1.111:36078->(10.0.0.152:9100->10.0.0.151:9100), len 60
13:57:59 firewall,info dstnat: in:ether1-gateway out:(none), src-mac 76:54:7d:91:5d:0a, proto TCP (SYN), 192.168.1.111:36079->10.0.0.152:9100, len 60
13:57:59 firewall,info IPSEC-IN srcnat: in:(none) out:bridge-local, src-mac 76:54:7d:91:5d:0a, proto TCP (SYN), 192.168.1.111:36079->10.0.0.151:9100, NAT 192.168.1.111:36079->(10.0.0.152:9100->10.0.0.151:9100), len 60
troffasky
Sat Oct 31, 2015 10:23 pm
At a guess, I would say that your inbound NAT rule for the printer is either not specific enough.
scampbell
Trainer
Trainer
Mon Nov 02, 2015 9:52 am
Add your wan address as the dst-address (not the to-address) of you Nat rule. Specifying just the incoming interface will catch IPSec traffic as well as Internet traffic.
Users browsing this forum: No registered users and 29 guests
