MUM Europe 2020
technalogic
CCR1036-12G-4S unable to boot
Fri Oct 30, 2015 10:57 am
Hello
we are using CCR1036-12G-4S one the device was not booting lcd screen show load from kernel
and device was hang we try to install with netinstall but netinstall also cant find device
we use both procedure for netinstall console and Ethernet but still cant fix then we contact to our local distributor
he said he also cant fix this error what can we do now ? (Device warranty was Expire also )
strods
Re: CCR1036-12G-4S unable to boot
Fri Oct 30, 2015 11:53 am
Try to:
1) Power your device off;
2) Press and hold reset button;
3) Power device on;
4) Hold reset button pressed for 1-2 seconds and then release;
5) If device boots up, then run command "/system routerboard upgrade"
technalogic
Sat Oct 31, 2015 10:20 am
Try to:
Dear support thank you for quick reply we do this but nothing happen still struck on loading kernel
3) Power device on;
Users browsing this forum: No registered users and 17 guests
