MUM Europe 2020
doctor12th
Can't obtain 300mbps/300mbps
Sun Nov 15, 2015 1:46 pm
I have two routerboards
RB951g-2hnd and
RB951-2n
I can't obtain 300mbps wds link, it is also max 150/150 also using chain0 and chain1 in TX and RX. 40mhz eC
I tried to enable mcs-15 in ht basics but if it 's enabled nobody can Connect, also the other routerboard with MCs 15 enabled.
What can i do?
jarda
Fri Nov 20, 2015 1:31 pm
See the spectral scan and select the clear frequency.
honzam
Re: Can't obtain 300mbps/300mbps
Fri Nov 20, 2015 2:25 pm
RB951g-2hnd and
RB951-2n
Max speed for RB951-2n is 150Mbit.
For 300Mbit you need dual chain "D" routerboard. For example 2x rb951G-2HnD
LAN, FTTx, Wireless. ISP operator
jarda
Fri Nov 20, 2015 5:01 pm
Oh. I have overlooked that one of his devices does not have dual chain radio...
chechito
Re:
Fri Nov 20, 2015 5:38 pm
and rb951-2n has the worst radio i have tested on mikrotik
works well but
very low tx power and very poor sensitivity
Users browsing this forum: No registered users and 22 guests
