MUM Europe 2020
blackmetal
translate rules , what these rules mean ?
Mon Nov 16, 2015 8:34 am
i have following rules :
add action=jump chain=forward connection-state=new jump-target=detect-ddos
add action=return chain=detect-ddos dst-limit=32,32,src-and-dst-addresses/10s
add action=add-dst-to-address-list address-list=ddosed address-list-timeout=10m chain=detect-ddos
add action=add-src-to-address-list address-list=ddoser address-list-timeout=10m chain=detect-ddos
add action=drop chain=forward connection-state=new dst-address-list=ddosed src-address-list=ddoser
my questions is :
1. if source ip from my network to outside (internet) create more than 32 connection per 10second will block and put in ddoser ip address group right?
2. if source ip from outside of my network (internet) create more than 32 connection per 10 seconds to my destion ip (to my network) will block and put in ddosed ip address group right?
3. i put my external and internal links to a bridge (because i want they work in transparent mode) so is above rules work fine for me in bridge mode ?
4. why action is jump and create dedicated firewall chain ? what is the benefit of dedicated firewall chain?
thanks,
bajodel
Long time Member
Long time Member
Re: translate rules , what these rules mean ?
Mon Nov 16, 2015 10:08 pm
.. my questions ..
Yes, yes, no (new connection has no meaning at layer2), less rules to evaluate
blackmetal
Tue Nov 17, 2015 8:36 pm
hi,
what do you mean?
your mean is in bridge mode we can not control new connection limitation?
and we can only control new connection and invalid an destablished connectios?
thanks,
bajodel
Long time Member
Long time Member
Fri Nov 20, 2015 12:59 am
your mean is in bridge mode we can not control new connection limitation? ..
At layer2 you have no "connections", only " packets " .? So no ..you can not control new connections
chechito
Fri Nov 20, 2015 2:34 am
you need to activate use ip firewall on bridge options
blackmetal
Sat Nov 21, 2015 7:55 am
thanks all it seems when enable use ip firewall in bridge it passes connection state to firewall and we can control it,
Users browsing this forum: No registered users and 72 guests
