this is our web proxy setting
it is not working !!!
this is the interface
the web proxy
the Firewall NAT
the traffic is not going through the proxy redirect firewall nat rule as below !!
Code: Select all
[admin@MikroTik] /ip firewall nat> print
0 chain=dstnat action=redirect to-ports=8080 protocol=tcp
src-address-list=192.168.13.0/24 in-interface=ether2 dst-port=80 log=no
log-prefix=""
1 chain=srcnat action=masquerade log=no log-prefix=""
Code: Select all
[admin@MikroTik] /ip proxy> print
enabled: yes
src-address: ::
port: 8080
anonymous: no
parent-proxy: ::
parent-proxy-port: 0
cache-administrator: webmaster
max-cache-size: unlimited
max-cache-object-size: 2048KiB
cache-on-disk: no
max-client-connections: 600
max-server-connections: 600
max-fresh-time: 3d
serialize-connections: no
always-from-cache: no
cache-hit-dscp: 4
cache-path: web-proxy
any help please?
