strods
6.33.1 version is released!
Thu Nov 19, 2015 11:38 am
We have released new version of RouterOS 6.33.1 which is 6.33 with included fixes for known bugs. New features are not included.
What's new in 6.33.1 (2015-Nov-17 09:55):
*) licensing - fix unneeded connection attempts to 169.254.x.x must be CHR only (introduced in 6.33);
*) pppoe - fixed compliance to RFC4638 for MTU larger than 1488 (introduced in 6.33);
*) CRS2xx - fixed occasional switchip resets (broken in 6.33);
*) fastpath - fixed wireless interface fastpath (broken in 6.33);
*) smb - fixed SMB share crash when connection was cancelled;
*) lcd - fixed LCD crash on fast disable/enable;
*) lcd - refresh LCD after display command is executed;
*) vrrp - fix enabling disabled vrrp interface when vrrp program has exited;
*) winbox - do not send any changes on OK button press if nothing has been changed;
*) www - put correct path to Winbox v3.0 for new installations with branding package;
*) webfig - show correctly SFP Tx/Rx;
*) winbox - renamed power-cycle-ping-interval to power-cycle-ping-timeout;
*) hotspot - fixed missing image at login;
*) netinstall - fix branding pack parsing;
*) packages - show version tag when no bundle is installed.
onnoossendrijver
Re: 6.33.1 version is released!
Thu Nov 19, 2015 11:52 am
I think I found a little bug.
export shows this:
/tool romon port
add
On the previous 6.33 version it showed:
/tool romon port
set [ find default=yes ] cost=100 forbid=no interface=all secrets=""
add cost=100 disabled=yes forbid=no interface=all secrets=""
Something is missing :)
I found this when I checked my Rancid diffs.
Linux/network engineer: ITIL, LPI1, CCNA R+S, CCNP R+S, JNCIA, JNCIS-SEC
macgaiver
Thu Nov 19, 2015 12:18 pm
I do not get it - what is missing? all looks in order
What's new in 6.33 (2015-Nov-06 12:49):
*) romon - change port list to be not ordered in export;
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
onnoossendrijver
Thu Nov 19, 2015 12:32 pm
Well, this is not a config that you can copy/paste in a router. The CLI expects some input after 'add'.
macgaiver
Thu Nov 19, 2015 1:57 pm
Your initial config is the issue, fix it. and all problems will be gone.
As list behavior is already changed, and your config will not be common (cause of global romon option availability) , this is minor issue.
strods
Thu Nov 19, 2015 2:11 pm
If you have had imported configuration from old export, then you will have this:
/tool romon port
add
If you will run "/tool romon port" print then now you will have two entries for port=all. You can delete one of them. Old export was incorrect and now if you import it, then it seems like it is incorrect again. If you have default RoMON configuration then starting from this version "/export" will be empty.
freemannnn
Long time Member
Long time Member
Thu Nov 19, 2015 2:40 pm
in rush i upgrade my home router and two of my customers to 6.33.1 from 6.33 and now i cannot connect to all of them with ip cloud. the customers also called me that they have no internet.
onnoossendrijver
Thu Nov 19, 2015 2:46 pm
/tool romon port
add
I don't think I have ever imported old configuration on these devices. But removing one of the entries solved my problem. Thank you!
macgaiver
Thu Nov 19, 2015 2:49 pm
in rush i upgrade my home router and two of my customers to 6.33.1 from 6.33 and now i cannot to three of them with ip cloud. the customers also called me that they have no internet.
you are not doing it right. First test then upgreade yourself, then use for few days, and then and only then do something on customer network.
My upgrades have no issues so far.
freemannnn
Long time Member
Long time Member
Thu Nov 19, 2015 2:50 pm
yes of course i always do like this , i dont know today how i did this rushing bloody thing. i always upgrade my home router to play and after my customers!
@@@@@ now i have to go to the sites to check. i hope there is no need for netinstall
chechito
Thu Nov 19, 2015 3:09 pm
bad idea to install a new release only 3 or 4 hours after has been released to remote customer equipment
freemannnn
Long time Member
Long time Member
Thu Nov 19, 2015 3:17 pm
yes you are right!
i always install new version to my router at home and test. and after some days i install to my customers.
today i dont know i was tricked that is a bug release and no problems will appear!
normis
Thu Nov 19, 2015 3:23 pm
please find out what specifically is the issue and let us know
freemannnn
Long time Member
Long time Member
Thu Nov 19, 2015 3:29 pm
i will go first to my house to check if i can connect to my rb2011 with winbox and see what is wrong.
if winbox is ok maybe something wrong with pppoe dialer and the bridge modem.
if cannot connect with winbox propably netinstall is required! after i pick up my laptop and go to customers.
i will inform what i have found in some hours!
dd9qp
Thu Nov 19, 2015 3:36 pm
PPoE-Out Client: DialIn to German Telekom not working on RB493AH.
RB439AH was running ok with V6.33, V6.33.1 didn't do the dialin-process and ran into loop.
Login process always gets terminated.
Downgraded to V6.33 and everything worked ok again.
freemannnn
Long time Member
Long time Member
Thu Nov 19, 2015 3:48 pm
i am in greece and i use pppoe with 1492 mtu-mru to dial at bridge modem. maybe we have the same problem
this is a photo from customer of another rb951 at a previous version ros
dd9qp
Thu Nov 19, 2015 4:14 pm
It's the same here: 1492/1492 - runs perfectly in V6.33
cantanko
Thu Nov 19, 2015 5:03 pm
Same issues with PPPoE client on CRS-1xx - can't test downgrading yet as need to go home to fix it :D
freemannnn
Long time Member
Long time Member
Thu Nov 19, 2015 7:02 pm
just came home and rb2011 with 6.33.1 was ok except pppoe-out1 was in a loop and not connecting.
remove 1492 in both fields (see image below) and connected!
i am going to my 2 sites to do the same. i wont downgrade to 6.33
dadoremix
Thu Nov 19, 2015 7:28 pm
Yes... Pppoe not working, recived bad pap...
Rb435g and 493ah
Again fix will be needed 6.33.1.1
felted67
Thu Nov 19, 2015 7:34 pm
with RB951G-2HnD the same. Just terminating and no connection.....
Carrier: Deutsche Telekom 6000RAM DSL.
(Remote site - will checkout tomorrow).
Greetz.......Detlef
hardvk0
Thu Nov 19, 2015 10:39 pm
I have a RB2011.
Since version 6.32.3, MTU 1492 in PPPoE has malfunctioned. Any later version has solved.
V6.32.3 work fine.
imagen
V6.34rc6 Don't work.
share image
strods
Fri Nov 20, 2015 7:14 am
If you did use RouterOS + RouterOS for PPPoE tunnel, then it should work correctly since 6.34rc3. Now also problem with RouterOS + other vendor device is fixed if RFC4638 is supported in both ends. Upgrade your RouterOS device to 6.34rc6.
If you still have some problems about which we are not aware of, then please generate supout file with PPPoE debug logs and send it to support@mikrotik.com
macgaiver
Fri Nov 20, 2015 8:06 am
It is good that we have many new users joining into forum to report the same issue and it is completely unsuspicious. :)
Do you have any information about what is PPPoE server in your case?
Have you same issues with MTU/MRU 1480?
I just checked my pppoe-clients, and i was not able to repeat the issue with regular MTU.
rado3105
Fri Nov 20, 2015 6:09 pm
What was the result of this in 6.33?
freemannnn
Long time Member
Long time Member
Fri Nov 20, 2015 7:51 pm
in greece pppoe client is using 1492 mru mtu
i have to downgrade back to 6.33 to keep using that number
with 6.33.1 it was in a connection loop and never connected.
HiltonT
Fri Nov 20, 2015 8:34 pm
I upgraded my office CRS125 before doing any client units (our usual procedure) and 6.33.1 broke my PPPoE connection (MTU=1480) - not even creating a new PPPoE client would allow me to connect. I downgraded back to 6.33 and connected again immediately using the original PPPoE Client profile.
I'm hanging back on further upgrades until this PPPoE bug is fixed.
Regards,
Hilton Travis
hardvk0
Fri Nov 20, 2015 8:58 pm
In my case, the connection is with the ISP. I have no way of knowing if it supports RFC4638.
It worked well before, not now.
Hotz1
Sat Nov 21, 2015 3:28 am
Could someone who downloaded the Grand Unified Torrent™ for 6.33.1, please seed? It's stuck at 81.88%.
Principal, Engineering
Cape Ann Communications, Inc.
Gloucester, MA, USA
mistry7
Sat Nov 21, 2015 10:03 am
Same Problem here with PPPoE-Client Connection.
ROS 6.33.1 do MTU 1480
Possible ist 1492 but the Connection is always done in 1480.
mistry7
francisuk24
Sat Nov 21, 2015 4:15 pm
Simple queue not working v6.33.1, Could this be an RB750 r2 mipsbe firmware issue? http://forum.mikrotik.com/viewtopic.php?f=3&t=102410
RouterBoard RB750R2, RouterOS Level 4
ISP: Zen Internet via VDSL 2 > 74.68Mb Down / 17.84Mb Up
jarda
Sat Nov 21, 2015 5:01 pm
Although I was saying that 6.33 provided its version number to Dude 4b3, now I have to say that 6.33.1 definitely does not. All devices in device list with 6.33.1 lost their version value.
Mikrotik, did you any undocumented change on snmp oids or what?
raffav
Sat Nov 21, 2015 8:40 pm
Hello, can someone give some example how to use the vlan-mode and vlan id on the virutal ap ?
i cant figure out how do make work
thanks
ckleea
Sun Nov 22, 2015 12:34 am
I found the same issue of KVM in x86 not functioning. It just showed starting but not running.
I have to restore back to 6.32.3
igb
Sun Nov 22, 2015 11:25 am
Attempting to use Webfig gives "Error: Not Found" at the login screen for some source addresses (I can't quite figure the pattern out: I was at one point trying 0.0.0.0/0 and ::0/0 as permitted and still have the problem when accessing remotely). Works reliably when connected via L2TP+IPSec VPN. Worked OK with 6.33.
storp
Tue Nov 24, 2015 2:58 pm
I hade the same issue when connecting through https after upgrade but fixed it by clearing all local cache in my browser (firefox). Give it a try and see if it helps.
pukkita
Trainer
Trainer
Thu Nov 26, 2015 1:20 pm
Doesn't seem to be the case, at least with NetMetals (wireless-cm2 package used, Nv2, wireless interface queue set to only-hardware-queue) performance worsens with it enabled.
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
purana
Fri Nov 27, 2015 12:49 pm
I upgraded my RB951G-2HnD from v6.30.1 to v6.33.1 and immediately after doing so the PPPoE connection stops working to my ADSL bridged modem.
I had to downgrade back to get PPPoE working again..
Looks like we might have some issues with PPPoE in the release.
purana
Fri Nov 27, 2015 12:53 pm
My pppoe-out1 is configured the same. It stops working and never connects upon upgrading to 6.33.1 and I had to downgrade back to the version that was working.
Really disappointed, especially since when I tweeted about it and got no reply from mikrotik on twitter.
strods
Fri Nov 27, 2015 1:11 pm
purana - In 6.34rc11 it is fixed. At least all of our clients who had these problems reported back that now it is fixed.
purana
Fri Nov 27, 2015 1:47 pm
I'll wait until the next stable release.
cantanko
Mon Nov 30, 2015 1:53 pm
Regarding the PPPoE breakage between 6.33 and 6.33.1, setting the max-mtu and max-mru to "auto" fixed it for me...
vzouh
Mon Nov 30, 2015 3:03 pm
Hi Everyone,
Just updated my RB1100AH from 5.26 to 6.33.1 yesterday,
everything looks just fine but i found the log reporting many warning
19:46:03 interface,warning ether7: bridge port received packet with own address as source address (00:0c:42:eb:0a:05), probably loop
19:46:10 interface,warning ether7: bridge port received packet with own address as source address (00:0c:42:eb:0a:05), probably loop
19:46:17 interface,warning ether7: bridge port received packet with own address as source address (00:0c:42:eb:0a:05), probably loop
19:46:24 interface,warning ether7: bridge port received packet with own address as source address (00:0c:42:eb:0a:05), probably loop
19:46:29 interface,warning ether7: bridge port received packet with own address as source address (00:0c:42:eb:0a:05), probably loop
19:46:35 interface,warning ether7: bridge port received packet with own address as source address (00:0c:42:eb:0a:05), probably loop
19:46:43 interface,warning ether7: bridge port received packet with own address as source address (00:0c:42:eb:0a:05), probably loop
19:46:50 interface,warning ether7: bridge port received packet with own address as source address (00:0c:42:eb:0a:05), probably loop
19:46:56 interface,warning ether7: bridge port received packet with own address as source address (00:0c:42:eb:0a:05), probably loop
19:47:03 interface,warning ether7: bridge port received packet with own address as source address (00:0c:42:eb:0a:05), probably loop
I didn't find any suspicious large traffic within that interface (ether7)
FYI, ether7 bridged with one vlan
add mtu=1500 name=Usee_br
add auto-isolate=yes bridge=Usee_br interface=ether7
add auto-isolate=yes bridge=Usee_br interface=vlan835
/interface bridge settings
set allow-fast-path=no
Is this somekind of difference between 5.26 and 6.33.1, or maybe some bug ?
any suggestion will be very appreciated ;)
macgaiver
Mon Nov 30, 2015 3:37 pm
in most cases problem is somewhere else in the network. same vlan bridged with same ethernet network maybe? without RSTP?
vzouh
Mon Nov 30, 2015 3:49 pm
protocol-mode=rstp
bridge contains 1 ethernet and 1 vlan from other ethernet
my router contains total 3 bridges
fyi, i didn't make any configuration changes, while this router uptime more than 1year without any suspicious error/warning in 5.26
slavisar
Mon Nov 30, 2015 9:44 pm
Since 6.33.1 I have lost wpa2 capability. Devices affected are GrooveA 5HPn, SXT G-2HnD and RB2011UiAS-2HnD-IN.
When establishing wpa2 connection, AP log says "unicast keys exchange timeout", then connection drops.
If connection is set unencrypted, everything works ok. I have also tried PTP bridge configuration, but no luck.
I also have tried to downgrade to earlier versions of routeros, but wpa2 still does not work (???).
My equipment is less than year old and has been working flawlessly since latest upgrade.
Trema
Tue Dec 01, 2015 12:27 am
Could it be that the configuration export is broken?
/system export file=filename
I tried it on several devices. Export file won't get bigger than a few KiB's. Adding the "verbose" option doesn't make it any better. :(
sasskass
Tue Dec 01, 2015 2:40 am
Serious ethernet problem!
What the hell is going on ? Bridged ports and as soon as the device will start transmitting the multicast data the outgoing port will start going down/up ~10 times per minute.
Upgraded a couple of SXT-s and some soho 2g routers, same issue...
Aleksander
strods
Tue Dec 01, 2015 10:17 am
Version 6.33.2 is released! Please upgrade if you are experiencing issues with 6.33.1.
http://forum.mikrotik.com/viewtopic.php?f=21&t=102664
Users browsing this forum: Hinata001, kiank7 and 79 guests
