amongdota
disconnected extensive data loss
Mon Nov 23, 2015 3:38 am
i have this problem, sory icant write smart english, perhaps this screenshoot explain my problem,
my main problem is disconnected extensive data loss,
x86 mikrotik ----> groove ))) (((( client station
chechito
Re: disconnected extensive data loss
Mon Nov 23, 2015 4:51 am
you have some advanced and HT tab settings different from default
why you have changed it??
are you using omnidirectional antenna??
please check the ccq of the disconnecting clients enabling the ccq column on registration table
amongdota
Sun Nov 29, 2015 3:55 am
what is the default setting for that tab?
Chinezupwnz
Mon Dec 07, 2015 5:00 pm
Enable WMM support.
Go to DHCP table and increase lease time, 4-5 hours.
victorsa
Sun Mar 11, 2018 9:13 am
Hello.
I have the same issue.
Did you find a fix?
Users browsing this forum: 2jarek, Deaqui, MSN [Bot] and 17 guests
