As soon as I get a couple of them for our lab, i'll do an IPSEC test until the magic blue smoke comes put and let you know where the breaking point is.im interested in ipsec topic too
Looks very promising device, althought I'm more waiting the desktop version, hopefully its coming soon too..
-Lane between cpu & switch chips
Thank you in advance.
Looks very nice. Also the lane between the switches to be able to make a big switch or offload one of the main lines to cpu if necessary would be awesome.
Tomorrow we will have it:)
Whre could we download newest version ROS for that board (RB3011)??
I think that every day will be added on download page. Hold onTomorrow we will have it:)
MT,
I'm missing this on the RB3011:
Memory card type 1 x M.2 SDD (which can be used as bootable drive).
Kind regards,
Patrick
Maybe not ... But it better should be.MT,
Kind regards,
Patrick
i think the only mikrotik with this feature is ccr1072, but dont know if can be booted from m2
Yes of course the slot to insert the card.nooo, the mPCI-e slot is missing...RB3011 inside![]()
So, how to download newest stable version for RB3011?
how many nand have your rb3011??
ohh yes very interested im waiting for that tooany IPsec/AES tunnel benchmark results?
auth-algorithms=sha256 enc-algorithms=aes-256-cbc name=strongish pfs-group=modp4096
This is a very low speed... Mikrotik Epic FailI've had IPSec running on the bench between an RB1100AHx2 and an RB3011UiAS-RM using the following IPSec proposal
Saturated duplex traffic seemed to hover around ~44Mbit.
I guess the Qualcomm encryption accelerator hasn't been turned on yet in RouterOS...
But HW acceleration will be supported in the near future?IPsec accelerator support for RB3011 is still being worked on, the HW acceleration is not yet supported for this model. The CPU is much faster than RB2011 even without HW accelerator.
We are working on it, yes.But HW acceleration will be supported in the near future?IPsec accelerator support for RB3011 is still being worked on, the HW acceleration is not yet supported for this model. The CPU is much faster than RB2011 even without HW accelerator.
Again sorry to intrude on much more serious discussions like IPSEC performance, but could somebody help me with an answer for the above query?I would be interested to install this at home as main router, in case its WAN to LAN speed is enough to fully take advantage of my 1 Gbps internet connection.
Could somebody please help me test that using a PPOE WAN connection?
I got ~ 79 Mb/s with OVPN and AES 128.Again sorry to intrude on much more serious discussions like IPSEC performance, but could somebody help me with an answer for the above query?I would be interested to install this at home as main router, in case its WAN to LAN speed is enough to fully take advantage of my 1 Gbps internet connection.
you can use built-in BTest features, 3rd-part software(inlcuding commercial packages)or simply check 3011 page about "performance test results"(scroll down to read it).Again sorry to intrude on much more serious discussions like IPSEC performance, but could somebody help me with an answer for the above query?I would be interested to install this at home as main router, in case its WAN to LAN speed is enough to fully take advantage of my 1 Gbps internet connection.
Thank you for your answer. The absolute value is very low, but I don't have the necessary knowledge to estimate what the difference would be for a simple internet connection (so no VPN) and with no encryption.I got ~ 79 Mb/s with OVPN and AES 128.
Thank you for your answer. I do not own this machine, the question was addressed in order to know whether I will want to buy it or not. I did look on the generic test data present on the RouterBoard page for the 3011, but like you said yourself it is better to test before... I've seen routers that are very powerful in terms of WAN to LAN capability when connected to "normal" WAN connection, but when used with PPOE they give very poor comparative results.you can use built-in BTest features, 3rd-part software(inlcuding commercial packages)or simply check 3011 page about "performance test results"(scroll down to read it).
http://routerboard.com/RB3011UiAS-RM for RM-encased 3011 version, for example.
PPoE had (relatively)low overhead (compared to VPN endpoints)so you can ~ approximate/guess thing bout, but aside that - its strongly depend of Kind and type of traffic you expect to generate over it. generally its better to test before.
if you looke for "short/dumb answer" i think its more like "yes" and achievable throughput over PPoE is relatively close to 1Gbps, but for usual/sane configurations its Had to be lower. so if you aiming to Really stress 1Gbps uplink, perhaps CCR1009 would be better start.
IPQ chips/SoC aimed to SOHO devices and never meant to provide "something outstanding" in terms of performance.
I've been running one with the same RouterOS version for about a week, with peaks over 400 Mbps without packet loss. Have you tried using a different port to rule out a defective ethernet interface?Little out of VPN topis but does anyone expriened some strange behaviour in RB3011?
And ... on RB3011 we had ... 5-10% packet losses. Nothing changes, than device.
Any ideas?
OH yes, one more info: RouterOS 6.33.3 on both RB750GL and RB3011
RouterOS 6.33.5 does show the switch menu in Webfig, but I don't see it in the CLI or Winbox. The LCD menu is available in all three interfaces.Hello,
LCD and Switch menu missing... Anyone else have that problem?
Thank you!
p.s. oh, I just saw *) winbox - added LCD menu for RB3011; will be added Switch menu too?
Moreover, there is no MASTER-PORT and BANDWIDTH (RX/TX) drop-down controls in "interfaces" settings (Winbox).Any news about the "Switch" menu in Winbox?
Did not even appear in the latest 6.34rc version.
It is a good hardware, but the external small power adapter, it's a shame.WHY WHY WHY???
No internal PSU???
Thank you MT for WinBox 3.1Hello,
Thank you!
Hello, I didn't be able to repartition my RB3011 with ROS 6.33.5, could you help me? Is this supported function for arm processor? Thank you.Just received two RB3011 and struggling to repartition them to have two partitions.
It accepts the commands either via terminal or winbox, reboots fine but after a reboot there is still only one partition.
Anyone else tried repartitioning?
Download WinBox 3.1The new 6.35 release still hasn't addressed the lack of repartitioning functionality on the RB3011; switch menu is visible in Webfig but not in Winbox, and the master port field is still missing for Ethernet interfaces when using Winbox.
I bet it will require RouterBOOT update and I think it's not high-priority task since almost noone shutdowns routers2. My RB3011 reboots within 30 seconds after trying to shutdown it from Winbox. Anyone who has RB3011, please report do you have such issue or not.
Yes, all RouterBOARDs will do this, it is not a bug per-se, it is more something like unsupported feature. Device needs to be disconnected from power to turn off completely. If you don't unplug it, it will start again. Shutdown command is not required, it is quite safe to just unplug it.My RB3011 reboots within 30 seconds after trying to shutdown it from Winbox
Isn't a shutdown command only useful while running with external storage for e.g. proxy? Cutting power may damage filesystem on it since it's r/w.Shutdown command is not required, it is quite safe to just unplug it.
Before today I always thought that I should and I must shutdown Mikrotik router before unplug power supply (PS).I bet it will require RouterBOOT update and I think it's not high-priority task since almost noone shutdowns routers2. My RB3011 reboots within 30 seconds after trying to shutdown it from Winbox. Anyone who has RB3011, please report do you have such issue or not.
I'm truly interested in your use-case for that.
Hi, if safe why the log complains about impropper shutdown? Maybe the message needs to be changed.Yes, all RouterBOARDs will do this, it is not a bug per-se, it is more something like unsupported feature. Device needs to be disconnected from power to turn off completely. If you don't unplug it, it will start again. Shutdown command is not required, it is quite safe to just unplug it.My RB3011 reboots within 30 seconds after trying to shutdown it from Winbox
Thank you very much for extended explanations. Now I understand.but sudden reboot may be sign for something bad).
So in summary these log entries are to inform about sudden reboots.
Thanks your answer!It has some problems with mysterious false-positive loop detection, but other than that it's good.
Thank you I read this topic. I think even I'm waiting a few months to purchase... This is a new architecture. The Mikrotik still have to work on it.There's a separate topic about that issue: http://forum.mikrotik.com/viewtopic.php?t=104716
I can confirm. I tried with several USB device and does not work on 6.36rc28. All works fine in 6.35.4With the latest software update 6.36rc28 my RB3011 doesn't see any usb devices. With current version it works fine.
I only had an USB2 HDD, got 30mb/s on SMB.Hi,
have anybody tested RB3011UiAS-RM with shared drive connected on USB 3.0 port for SMB or Widows share performance ?
Which speed are you getting ?
No this requires a kernel newer than the 3.3 that RouterOS v6 uses.did the encryption hw acceleration ever get turned on for this model?
I have RB3011UiAS-RM with CPU Frequency is empty. It's bug or something wrong with my RB?RB3011RESOURCES.jpghow many nand have your rb3011??
After one year what about HW encryption acceleration?IPsec accelerator (HW acceleration) RB3011UiAS-RM ???
Когда, сколько ждать?
When, how long to wait?
