andressis2k
New SXT AC Lite
Thu Nov 26, 2015 11:47 pm
I've just seen it. 5/10/20/40/80MHz support, and... additional 2,4GHz for alignment purposes!!
http://i.mt.lv/routerboard/files/SXT_ac ... 114241.pdf
jarda
Fri Nov 27, 2015 6:39 am
I can't understand why the number of 2.4ghz clients is artificially limited to maximum of one. Sure I understand the purpose, but why not to provide standard functionality of the wlan interface and let the user to use it how he wants?
wojtekc
Re: New SXT AC Lite
Fri Nov 27, 2015 8:47 am
2,4 G
Antenna Gain 1,5 dBi !!!
chechito
Re:
Fri Nov 27, 2015 8:57 am
i think its a good improvement, good innovation other vendors dont have
remember, its a level 3 license.
maybe similar device will come with level 4 license or upgrading license
jarda
Fri Nov 27, 2015 10:55 am
That's it. Level 3 as it is lite version.
Łukasz
Re: New SXT AC Lite
Fri Nov 27, 2015 11:38 am
I also think that this is very good improvement.Thank you Mikrotik.
Now I am waiting for CPE with higher gain and CRS with gigabit poe out on all ports and i will be happy.
InoX
Re: New SXT AC Lite
Sat Nov 28, 2015 3:46 pm
10/100Mbps Ethernet port :(
G2Dolphin
Re: New SXT AC Lite
Sun Nov 29, 2015 2:55 am
Meh, I can't see a reason for this device to exist without 1Gbps port. Yes, cheap, but why do we need 802.11ac PtP then?
CCR1009-7G-1C-1S+PC, RB3011UiAS-IN (2011 case+3011-RM), hAP ac, mAP2n/mAP2nD, wAP ac LTE6
There's nothing wrong with your Internet connection, I have a broken avatar. :)
andressis2k
Re: New SXT AC Lite
Sun Nov 29, 2015 6:53 am
Do you expect more than 100 mbps in a PtMP envroiment?
I think it's great to install as customer CPE
If you need Gigabit version, there are some models
If you need cheap AC CPE, this device is for you
InoX
Re: New SXT AC Lite
Sun Nov 29, 2015 2:47 pm
I know is cheap.
I know there are models with gigabit.
I don't need you to tell me that.
It's just not nice it doesn't have gigabit. Some of us would like to serve more than 100mbps with an cheap CPE.
The next option is almost double the price...
chechito
Re: New SXT AC Lite
Sun Nov 29, 2015 8:48 pm
agree
in a ptmp hardly to serve more than 100mbps of throughput per client, very optimized device at a good price
taduikis
Re: New SXT AC Lite
Wed Dec 02, 2015 11:37 am
I was very excited when I saw a second wlan interface at 2G, but my excitement went away immediately when I tried to setup the Virtual AP on it and got notification that L3 doesn't support that feature.. The original intention of mine was to setup a few dummy APs with different SSIDs to make an impression that our service is abundant in that territory, because people here care what service their neighbors are using. I'm aware of low antenna gain and tx-pwr of 2G interface, but I only care if people pick up these APs in their scans with phones, tablets and computers. So, now at least for me, this is a waste of additional NIC.. :(
tealc
Re: New SXT AC Lite
Wed Dec 16, 2015 11:52 am
I just wanted to return device today for malfunction when I saw two interfaces, especially one of them beeing 2.4 :D
Eitherway, Miktotik you should lower a little bit restriction on that 2.4 interface.
Would be a surplus to have additional use beside administration. For example like exterior AP limited for only few clients (backyard/garden ap for client), now it's sitting there for what...disabled :shock:
ROS 6.33.1 - my approved stable :D
Private: RB3011 | RB2011 | RB951G | RB750G | Dynadish | 2xSXTac ...
Community: CCR-1009 | RB600 | RB2011 | RB750GL | OMNITIK | SXTac's ...
tealc
Re: New SXT AC Lite
Wed Dec 16, 2015 12:10 pm
Is it possible that this device is 5GHz SISO instead of MIMO?? :shock:
marekm
Re: New SXT AC Lite
Wed Dec 30, 2015 4:42 pm
Is the 5GHz antenna in the SXT AC Lite the same as in the standard SXT G-5HPacD? The standard SXT AC antenna works quite well up to 6100 MHz, SXT AC HG not so well (different antenna design - higher gain, but narrower bandwidth), it would be interesting to know about the SXT AC Lite before I buy more of them.
okoun
Re: New SXT AC Lite
Wed Jan 06, 2016 12:49 am
Attention! This equipment has inexplicably only 16 megabytes NAND !!!
how is it possible that older LITE 802.11n had 128 megabytes NAND ??
Yes, 128 megabytes NAND is useless, it would suffice even 32 megabytes, but 16 megabytes is awfully little!
Please make redress
chechito
Re: New SXT AC Lite
Wed Jan 06, 2016 12:59 am
Please make redress
datasheet specify that please read before buy
latest small devices all come with only 16mb of nand, one good example of that is the hEX
i miss the 128mb too :( :(
jnygard
Re: New SXT AC Lite
Sat Jan 30, 2016 6:07 pm
Interesting trick: I bumped the license up to level 4 and I now have a 2 chain 5 GHz ac AP AND a 1 chain 2 GHz AP that can serve MULTIPLE clients! Away went the limit of only one client connected to the 2 GHz interface!!!
Sob
Re: New SXT AC Lite
Sat Jan 30, 2016 8:45 pm
The trick would be more interesting, if it did not cost $45. ;)
Excessive quoting is useless and annoying. If you use it, please consider if you could do without it.
taduikis
Re: New SXT AC Lite
Sat Jan 30, 2016 9:15 pm
I'm in fact a little disappointed with those new SXT Lite5 AC. Mikrotik is obviously cutting corners with them. It's NAND flash is noticeably slower - unit bootup, netinstall and file operations take forever now, no beeper is VERY bad move, also I have plenty of them dead already. If they die, they seem to fail next day of operation. Very frustrating against clients. But I hope that affects only first batches and gets fixed soon. For a while I'm staying with good old Lite5, since AC doesn't really provide much of improvement in overcrowded freq anyway..
InoX
Re: New SXT AC Lite
Sat Jan 30, 2016 11:28 pm
You had that before upgrade also...
Thats what L4 do...
Nothing new.
craigmitchell
Re: New SXT AC Lite
Sun Jan 31, 2016 11:26 am
Hey jnygard, thanks for the tip!!
I must have missed this product. Shame it's only got a L3 license to start with, but I've a couple L4 licenses lying around that I can now put to good use!
I can imagine a few scenarios where this would be useful. In fact I would prefer that the 5GHz was L3 because I would use that as a PtP to another SXT say 10km away, and then the L4 would be to serve the local clients on 2GHz..
Perfect!
It would be awesome if the product had a L4 license all around though :)
valent
Re: New SXT AC Lite
Wed Mar 30, 2016 9:48 pm
If you don't want to pay for Mikrotik L4 and need both wifi interfaces then just install OpenWrt and there you go :)
Users browsing this forum: No registered users and 64 guests
