aaamit
Mikrotik RB951Ui-2HnD
Mon Nov 30, 2015 1:06 am
I have to setup a public wifi hotspot in a restaurant. The place is one big open hall (85 feet X 40 feet) , will have at most 40 guests connected simultaneously with bandwidth limited to 2 Mbps per guest.
Am planning to use the Mikrotik RB951Ui-2HnD.
Que 1. Can anyone please recommend how many should I use and their location. Will 1 router placed in the centre be sufficient?
Que 2. Do I need to solder external antennas? If yes, which antennas?
Que 3. Can the router support 2 internet connections. One primary and one backup (3G)
ceiling: 12 feet. false ceiling 2 feet. effective ceiling 10 feet.
no hanging lights, no hanging fixtures, no partitions, etc.
just tables and chairs
walls: concrete/brick with huge glass windows
Can mount anywhere I want.
pukkita
Trainer
Trainer
Re: Mikrotik RB951Ui-2HnD
Mon Nov 30, 2015 11:45 am
1.- Great pick, one at the center will be enough
2.- No need for external antennas, internal ones will perform excellent. See this post: http://forum.mikrotik.com/viewtopic.php?f=7&t=102456
3.- Yes, it can support two connection as long as the 3G modem is compatible, see http://wiki.mikrotik.com/wiki/Supported ... and_modems
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
aaamit
Mon Dec 07, 2015 12:02 pm
Thanks a lot
pukkita
Trainer
Trainer
Mon Dec 07, 2015 2:53 pm
You are welcome!
Just take care not placing it too near any kind of AC motor or electrical junctions.
Users browsing this forum: No registered users and 15 guests
