MUM Europe 2020
marcthespark
DynaDish routerOS
Wed Dec 02, 2015 12:46 pm
Hi has anybody had any issue when installing the latest RouterOS on a DyanDish,once i install it,it wont let me back into the Dish!!
pturkey
Re: DynaDish routerOS
Thu Dec 03, 2015 12:44 am
I have 2 new DynaDish units I took them out of the box and upgraded to 6.33.2 now both of them are dead. I can't even get them to connect to the netinstall.
I needed them install today.
pturkey
Thu Dec 03, 2015 6:11 am
Now what?
I have 2 new DynaDishish's and they are both DEAD!
Replace them or let me know how to make them work.
normis
Thu Dec 03, 2015 11:30 am
Please clarify, which is the "latest" RouterOS that you used, and how did you upgrade? Winbox / Webfig / FTP, using "check for updates"? What version number did you have before ?
pturkey
Thu Dec 03, 2015 1:42 pm
The first one I did was in Quick Set and the other was with winbox.
The version was 6.33.2
normis
Thu Dec 03, 2015 1:44 pm
6.33.2 is the current (newest). What was the previous that you had there ?
pturkey
Thu Dec 03, 2015 1:57 pm
They are new units out of the box. I just received the last week.
They had what ever MikroTik sent them with.
normis
Thu Dec 03, 2015 2:00 pm
In understand. We would like to repeat this here, so that is why I asked. Different units have different versions from factory, but we will test several types. Thanks
pturkey
Mon Dec 07, 2015 6:20 pm
I need the two DynaDish fixed or replaced soon.
How do I fix this problem?
pturkey
Mon Dec 07, 2015 7:23 pm
It looks like the ethernet port is disabled.
I am able to get the DynaDish to connect to an AP, but I can't login to it.
The firewall is blocking me.
Is there a way to get past the wirewall?
pturkey
Mon Dec 07, 2015 7:42 pm
I am now able to get logged in.
The answer is to use the power injector that came with the unit.
It will not work with any other injector.
pturkey
Mon Dec 07, 2015 7:52 pm
I upgraded to 6.33.3 and it has the same problem.
pturkey
Tue Jan 05, 2016 1:20 am
I still have 1 unit that will not work.
After the upgrade on 2 units I was able to get 1 working.
I need the other DynaDish 5 replaced.
It has been about a month with this un-usable antenna.
Users browsing this forum: anyad, Bing [Bot] and 119 guests
