strelokr
Xiaomi phone low Wifi TX rate
Wed Dec 09, 2015 12:13 pm
Hello colleagues.
Briefly the issue. I’m bought phone Xiaomi Redmi note 2 prime. And at all available to me Mikrotik devices phone can’t be connect faster than 54Mbps to TX data
https://www.dropbox.com/s/lbqo7asxu6rix ... 4.png?dl=0
Tested on RB 951G-2Hud, hap lite old and new one version (RB941-2nD и RB941-2nD-TS) is the same behavior.
Your colleagues from support who been on the MUM in Ukraine 8 Dec 2015 have not been able to resolve the issue but recognized problem. They said contact on the support.
The problem is also present in other owners of phones of this brand, as can be seen from the frequent posts 4pda and other sites, for example http://en.miui.com/thread-35456-1-1.html
When testing with other routers ASUS (DD-WRT) and the tp-link (default FW) allowed in both directions for 40 megabits and 65 respectively. Tested downloading and uploading to an ftp server in a local Gigabit network.
As tested on Zyxel Keenetik (diff verions)also no problem.
Changing the parameters of the wireless router to give nothing except further deterioration rate.
I hope for early resolution my problems.
InoX
Re: Xiaomi phone low Wifi TX rate
Wed Dec 09, 2015 5:00 pm
I confirm that also Redmi Note 4G has Tx 54mbps and Rx 72mbps.
But Redmi Note 3G is conected to 150/150 mbps.
Router RB 951Ui2HND
strelokr
Wed Dec 09, 2015 5:20 pm
I wrote a request for technical support. Waiting for an answer
have You any ideas?
spaxton
Wed Dec 09, 2015 7:17 pm
This can change from update to update. You should post this to en.miui.com forum. I am XIAOMI user, too.
Best Regards.
InoX
Wed Dec 09, 2015 11:50 pm
I know, I'm updating my phones every week...this dowsn't change anything.
strelokr
Thu Dec 10, 2015 8:55 am
My phone with 5.11.5 Firmware.
especially skip all versions 5.11.xx . They had problems with the Wi fi in sleep mode.
strelokr
Thu Dec 17, 2015 4:39 pm
tech support confirm this bug. Now is working with R&D to find resolve this issue
strelokr
Wed Jun 15, 2016 12:25 pm
Sadly, technical support will probably close this question.
In my letters no one answers.
linzo
Sun Jul 31, 2016 6:10 pm
exactly the same problem((((
InoX
Mon Aug 01, 2016 12:54 pm
Redmi Note 3 with Qualcomm has also this problem. I will change mikrotik router for another vendor because of this.
linzo
Tue Aug 02, 2016 10:20 am
Broadcom 802.11n Wireless SDIO Adapter also tx 54 on mikrotik(((((((((
infans
Tue Aug 02, 2016 10:26 am
We are not alone. I think this topic  http://forum.mikrotik.com/viewtopic.php ... 67#p548967 have the same trouble like we are.
linzo
Thu Oct 06, 2016 5:54 pm
with HAP AC exactly the same problem on 2.4 GHz - only 54 with Xiaomi and Broadcom 802.11n Wireless SDIO Adapter
Golyakov
Lenovo P2 phone low Wifi TX rate
Fri Apr 21, 2017 12:01 pm
Good afternoon!
Sorry for my english.
For a long time I use MikroTik RB2011UiAS-2HnD, RB951Ui-2HnD, RB751G-2HnD and RB941-2nD. ROS v6.38.5 and v6.39rc72.
Recently purchased a phone Lenovo P2.
I can not understand why Lenovo P2 connects to WiFi at channel speed Tx Rate: 54Mbps, Rx Rate: 150Mbps-40MHz/1S/SGI? That is, the Tx Rate is only 802.11g, and the Rx Rate is 802.11n
Accordingly, the reception speed does not exceed 20 Mbit.
I tried every possible WiFi settings - from reset, to experiments with different parameters in the advanced mode. I tried to play with channels, and with the width of channels, and with the power of the transmitter, etc. Still, more than 54Mbps at the reception there.
And the same phone Lenovo P2 with routers D-Link, TP-Link, Asus, etc. Works fine, at a speed of ~ 60-70 Mbit in both directions.
What could be the reason? Is this some known problem? And will it be eliminated?
Son1c
Re: Lenovo P2 phone low Wifi TX rate
Fri Apr 21, 2017 8:32 pm
Good afternoon!
I have a similiar problem, but with Letv x500 smartphone and two tablets Asus ME400C and Chuwi Hi8. Tx Rate only 54Mbps, Rx Rate - 75Mbps-20MHz. Also tried different wifi settings, different router locations, no result(( Technical support couldn't help me to fix this problem.
flicker
Mon May 29, 2017 9:43 pm
The same here: hAP lite (RB941-2nD), latest firmware and RouterOS, 802.11n, Xiaomi Redmi 4 Pro. Other devices (iPad 2, iPhone, some notebooks) get expected rates (up to 60Mbps downlink). Only Redmi 4 is stuck at 801.11g rates, never getting speeds over 20Mbps when working with Mikrotik.
Had anyone some success contacting Mikrotik on the issue? What can we do to resolve this incompatibility?
thekrzos
Wed Jun 21, 2017 10:23 pm
Same problem...
Deaqui
Fri Jun 23, 2017 1:12 am
I have the same problem. I have done several tests with different smartphones in map lite, wap and groove. I have tried changing the settings several times but I get the same results.
My smartphone shows only 54 mb in reception and however shows 72 mb in transmission.
fanMikroTik
Re: v6.40.3 [current]
Fri Sep 08, 2017 9:35 am
RB951Ui-2HnD
Hello, there is always the same (well known) bug with TX Rate on all smartphones with android. TX Rate is always only 54Mbps but RX Rate is 72.2Mbps-20MHz/1S/SGI.
I have the solution on Linux machines (Linux Mint and Ubuntu) but not for unrooted phones.
For some wireless chipsets a simple tweak is sufficient for increasing the connection quality a lot.
Namely disabling the power management for the wireless chipset.
The speed of your wireless internet may then increase also.
Now, You can do that as follows:
Launch a terminal window.
Type in the terminal (or copy/paste):
sudo apt-get install gksu leafpad
gksudo leafpad /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf
Now a text file opens. In that text file, you see the following content:
[connection]
wifi.powersave = 3
Change 3 into 2.
Save the modified file and close it.
Reboot your computer.
Please try it and give me feedback :-)
Nubia, LG, Lenovo... not only Xiaomi!
viewtopic.php?f=7&t=102908&p=604516&hil ... 54#p604516
ploquets
Mon Sep 11, 2017 11:32 pm
Same here...
Tested using Moto Z2 Play and Asus Zenfone 3
Only RX (phone Upload) gets on MCS.
TX is always on 802.11g I guess
WTF MK ?
normis
Tue Sep 12, 2017 9:00 am
Yes, some low end chinese phones have such issues. I suggest for now to use better phones, since we can't solve this issue quickly. These phones are known to have issues. We have checked this issue, and there is incompatibility with these chips and the RouterOS driver. We can't easily solve it, it will take a lot of time.
i'm not sure about Moto Play, we have only tested this issue with Xiaomi and other chinese brands.
didomir
Wed Sep 13, 2017 10:03 am
Hi Normis,
Does this means that Xiaomi and other brands are not conforming with 802.11 wireless standards ? RedMi3 are using Broadcom BCM43341, I suppose that there will be a lot of devices (not only low end) which uses Broadcom WiFi chips.
Can you please provide information which WiFi chipsets are not compatible with RouterOS, a lot of WISPs/Hotspot owners will/might have complains from customers ?
Having fun with RB850Gx2,RB750Gr3,RB962UiGS-5HacT2HnT,RBmAP2nD,RB952Ui-5ac2nD,RB951G-2HnD,RB960PGS, RBMetalG-52SHPacn...
normis
Wed Sep 13, 2017 10:16 am
Currently we have seen this issue only with this specific broadcom chip, not all of them.
The wireless standards have all kinds of extensions and methods, it seems that our drivers do not work correctly with the way this chip wants to do rate selection. We need to invest a lot of time to resolve this, it is hard to say when it will happen.
infans
Wed Sep 13, 2017 1:45 pm
First massage Desember 2015. Is it not "a lot of time"?
normis
Wed Sep 13, 2017 1:46 pm
This issue is currently at low priority, we are not actively working on it, since it will require a lot of resources to fix it.
Son1c
Fri Sep 15, 2017 6:38 pm
My chinese phone use MT6630QP wifi chip and i have same issue.
mainTAP
Sat Sep 16, 2017 8:51 am
OnePlusX has also the same issue with mikrotik.
Sent from my ONE E1003 using Tapatalk
irineusjc
Tue Oct 03, 2017 7:53 pm
Same problem here w/ my chinese Xperia Z Ultra... 20mbps
I'm using RB951G 2hnd... my first, maybe the last MK !
honzam
Tue Oct 03, 2017 10:53 pm
Have you tried 6.40.4?
LAN, FTTx, Wireless. ISP operator
Son1c
Fri Nov 03, 2017 10:52 am
Yes, no result(((
infans
Fri Nov 03, 2017 8:45 pm
Let me ask: samsung s7 have cheap Chinese chip like other phones in topic, because with RB951G-2HnD don't use 40 MHz?
Dear developers, maybe problem more importantly then you think?
It all about 40 MHz, let force your routers and our phones to use this frequency, and all users will be happy.
Deaqui
Fri Nov 03, 2017 9:19 pm
I had a pending installation with Cap Lite but in the end I will opt for other equipment because I have the same problem.
fastchip
Sun Nov 19, 2017 5:16 pm
This problem is more than one year exactly.
I can not normally use the Internet, the speed is low and sometimes the signal is lost.
Corrections do not budge at all?
Only buy a router from another manufacturer?
fastchip
Sun Nov 19, 2017 6:24 pm
can the situation improve the situation here? https://android.googlesource.com/device ... om_cfg.ini
linek1980
Fri Dec 01, 2017 11:11 am
Does low priority means we will never get a solution?
chechito
Fri Dec 01, 2017 5:16 pm
i think issue is related to android phones in general like normis says using some specific wifi chipset
i have seen many of them in registration tables only with 802.11g tx datarates, various brands and models, motorola, samsung, huawei, LG
But not all android devices suffer the issue
its sad to hear from mikrotik this is a low priority issue
specially after investing years to make people to believe in mikrotik as a reliable choice for wifi deployments
if wifi is a low priority for mikrotik will be best to retire all your wifi line of products, we all migrate to alternatives like ubiquiti unifi (finally is stable) please dont take the effort to release more wifi devices until you resolve this issues
seriously i dont understand mikrotik strategies, 10 years later finally decide to make affordable and competitive cpe for wisp just when all the roofs of many countries are populated with ubnt and tplink wisp cpe's
2 years after the market they release dualband wifi ap overpriced and overheating
will be better if mikrotik concentrate only on routing but i remember only one core bgp implementation and routeros 7 and
seriously as a customer i don't understand and that obliges me to search alternatives, as an act of responsibility towards my clients
Respectfully Normis:
We are not trolling you, is not necessary to post arrogant responses like we are reading lately to board this topics, we deserve respect like you do too
bajodel
Long time Member
Long time Member
Tue Dec 05, 2017 10:53 pm
+1
didomir
Wed Dec 06, 2017 12:34 am
+1
+1000 ...
I have a coupe of MKT devices (SOHO usage, HAP AC,AC Lite , 951G,part of the list is in my signature) but because of all those WiFI issues I start looking for alternatives. So far, it was good decision, I 'm currently using Mikrotik for routing and another vendors for WiFi.
The problem is that in my case single vendor (MT) would be best, but I really need reliable WiFi.
If band steering, air fairness,device compatibility and radio quality (not to mention NV2 and AC scanning complains from the professional users) are not priority for MT, what can we do ?
haik01
Sun Dec 10, 2017 9:20 pm
+1
+1000 ...
Well, you answered your question yourself. Use Mikrotik for routing purposes, and use other brands for WiFi. Unifi, Cisco, Aruba (ok, that is a bit too far fetched with Aruba)....
You are right, it would be `easier` with one vendor, but as you know, it is not a real big problem, since there are no `benefits` for one vendor here. You as a professional should not have a problem with two different types of equipment (for example Unifi and Mikrotik).
dnyl
Sun Jan 07, 2018 2:15 pm
Same problem on Huawei P9 lite. When the driver problem solved?
alexkulik
Sun Jan 14, 2018 11:50 pm
delete
biatche
Sat Jan 20, 2018 8:11 am
now i know i have many users complaining about my capsman setup. earning a terrible reputation. please fix.
carl0s
Mon Jan 22, 2018 7:20 pm
I had this issue with Intel 8260 yesterday. A driver reset on the Intel side seemed to sort it, and i have since upgraded the drivers, but I think maybe there's something on MT side that needs fixing really.
mlenhart
Thu Jan 25, 2018 12:16 pm
Normis, any update to this? When we can expect to be fixed?
It is a shame that vendor's (MikroTik) advice is to use higher-class phones. Why are you making devices (like hAP ac Lite = epic fail - ac on wireless, but only 100M ethernet) for SOHO users if you are not able to fix the issues promptly? Maybe it would be better to be focused more on another market (WISPs) and forget SOHO devices if you are not able to fix the issues promptly.
I am using HTC One M9 (definitely not a cheap smartphone) and have the same issue as many people above mentioned... and considering to give anyone I know the same level of advice as we got from MikroTik: "use higher-class vendor and forget about MikroTik"
Ilya
Sat Jan 27, 2018 10:36 pm
I found a way out and advise everyone - vote with money. With this attitude to the problem, you should not wait in the future for confidence in the vendor.
Paternot
Forum Veteran
Forum Veteran
Sun Jan 28, 2018 5:10 am
Have You tried 6.41?
Tested with a Moto Z2 Play (5 GHz 802.11n, 40MHz) and an Asus Zenfone 3 Zoom (2,4GHz 802.11n, 20MHz). I saw people complaining about both of them here - but they are working fine with my APs. Maybe version 6.41 fixed this?
Both APs are 952Ui-5ac2nD, international version, Brazil as selected country.
nordex
Sun Jan 28, 2018 10:50 pm
The issue is mostly on 2.4ghz and 54mbit max rate and it is software bug (installing openwrt or LEDE, and it works full speed)
Normis, please respond to what users ask from Mikrotik.
This is a HIGH-level issue.
When will this be fixed?
r0ute0ne
Mon Jan 29, 2018 12:27 pm
Having the same problem on older samsung and lg phones...
Lutor
Tue Jan 30, 2018 8:49 am
Same here, Google Nexus 4 and Lenovo TAB 2 X30L - only 54mbit max rate on 2.4ghz. hAP ac lite, 6.41. On Asus RT-N11P this devices connect on 72 or 150mbit.
Mikrotik, do you think this situation of keeping silence is normal?
mlenhart
Mon Feb 05, 2018 2:17 pm
just to update a little, this issue is not only in 2.4 but also in 5 GHz... Tested on HTC One M9 with hAP ac, ROS version 6.41.
honzam
Thu Feb 08, 2018 7:45 pm
I have the same problem with Samsung Galaxy XCOVER 4 and tablet LENOVO YOGA 2
:-( very bad
mlenhart
Fri Feb 09, 2018 3:28 pm
:-( very bad
Do you have the problem in both bands, 2.4 and also in 5 GHz?
vadim69
Fri Feb 16, 2018 4:23 pm
Hello everyone,
I would like to make a conclusion about the problem with WiFi. I have read few topics about this problem.
viewtopic.php?t=123299
viewtopic.php?f=7&t=122853
viewtopic.php?t=102908
viewtopic.php?t=97827
Everybody tells that some devices connected to Wi-Fi 2.4GHz have low speed on download and TX rate on Mikrotik shows only 54Mbps. In the same time RX rate is ok (65-300Mbps depend on client device).
I wrote to Mikrotik support and received a reply:
currently we don't have clear solution and road map for this fix.
We can suggest to use 20/40mhz-Ce channel width or even use 20MHz channels.
In eC mode extension comes before control, that may disturb correct work on some wireless devices.
Of course suggestion is about nothing.
The earliest message about the problem was at Sat Jun 20, 2015 3:21 am
viewtopic.php?t=102908 comment number 23, 24 and 35
I absolutely agree with "infans". Becomes 2018 year and still nothing. The latest version of firmware and ROS 6.41.2 have the same problem.
One of answers from Mikrotik support was:
viewtopic.php?f=7&t=102908 comment number 21
I tried to make a list of devices there was a problem:
Asus Zenfone 3
Chuwi Hi8
Google Nexus 4
Google Nexus 5
HTC One M9
Huawei P9 lite
Lenovo P2
Lenovo TAB 2 X30L
Letv x500
Moto Z2 Play
OnePlusX
Redmi Note 3
Redmi Note 4G
Redmi Note 5
Samsung S7
Sony Xpera Z Ultra
tablets Asus ME400C
Don't think that phones like Samsung S7, Google Nexus 5, HTC One M9 or Sony Xpera Z Ultra are "some low end Chinese phones"
The problem present at almost all routers with only 2.4GHz module. Mikrotik support confirmed this and told that there aren't problems on routers with 5GHz AC Wi-Fi module. However i tried with hAP AC lite and there is the same problem.
Not a long time ago becomes a new model Wi-Fi AP: "cAP AC". I hasten to inform that Wi-Fi works fine.
Dear Mikrotik experts, on behalf of all Mikrotik fans, please take care of solving the problem.
With best regards.
honzam
Fri Feb 16, 2018 6:15 pm
:-( very bad
Only 2,4Ghz. On 5Ghz is 150/150Mbit
nordex
Sat Feb 17, 2018 1:15 pm
I vote that we make new forum topic with alert to all new buyers informing them that mikrotik does not work correctly in 2.4ghz spectrum.
And with regular bumping we should keep it on top of forum.
mlenhart
Sun Feb 18, 2018 2:32 pm
I fully support this idea :)
MikroTik has to wake up and stop ignoring customer complains and blaming us for "buying lowend chinese phones" and releasing very poorly tested new devices (or better, non-tested at all... see issues with new AC devices based on ARM)
For this issue, 3 years are definitely enough time to fix it.
alexkulik
Mon Feb 19, 2018 2:46 pm
delete
mlenhart
Thu Mar 01, 2018 11:03 pm
Dear MikroTik,
could you please let us know we will see a fix for this issue any ever at all?
td32
Fri Mar 02, 2018 1:57 am
I have noticed this issue is present with Huawei P10lite also, max you can get on 2.4Ghz is 54Mbps.
alexkulik
Fri Mar 02, 2018 1:56 pm
delete
alexkulik
Fri Mar 02, 2018 2:14 pm
delete
normis
Fri Mar 02, 2018 2:28 pm
This issue is related to the chipset incompatibility between what we use in our devices, and the chip in these phones. There isn't much we can do.
Newer devices, such as hAPac^2 and cAPac do not have this issue anymore.
alexkulik
Fri Mar 02, 2018 2:32 pm
delete
Son1c
Fri Mar 02, 2018 3:52 pm
In previous your posts, you suggested to buy better phones, now when many users report about this issue not only on cheap phones, you suggest to buy your new devices. Nice work, Mikrotik.
Now, when i've bought your "old" device, i must to sell it and buy a new model, but where is the guarantee that on new model, such as hAPac^2, i will not have the same issue?
normis
Fri Mar 02, 2018 3:58 pm
None of that is contradictory. I said that the hardware in these mostly cheap phones is incompatible (in some ways) with the chips used in MikroTik devices.
This means there are two solutions: change phone or change chips in MikroTik devices. Either solution works fine.
Son1c
Fri Mar 02, 2018 4:19 pm
Do you suggest choosing a phone specifically for the router? Because not all phones work well with your devices. Are you seriously???
alexkulik
Fri Mar 02, 2018 4:20 pm
delete
alexkulik
Fri Mar 02, 2018 4:29 pm
delete
dvm
Fri Mar 02, 2018 5:07 pm
If that's true chipset incompatibility, why the physically same MikroTik device with LEDE firmware installed works fine?
troffasky
Fri Mar 02, 2018 11:30 pm
He said "Either solution works fine", so you can choose a different phone if you must keep using the RB951, or choose a different AP if you must use a specific incompatible phone.
Son1c
Sat Mar 03, 2018 1:39 am
It sounds strange and absurd, choose a phone for the router, or i something don't understand???
alexkulik
Sat Mar 03, 2018 8:39 am
Delete
MikTikAddicted
Sat Mar 03, 2018 8:49 am
Hi everyone.Normis,where i can change wifi chip of one of my 100...1 miktiks FOR FREE? I think you must make return of all your "bad"devices.
honzam
Sat Mar 03, 2018 7:15 pm
The problem is on the hardware level. To solve it you need to physically desoldering the chipset and replace it with others.
Why do you think the problem is in hardware? I have info from support - it is software problem.
we will work on this problem but first we need to finetune the new wireless driver for the new hardware and then we would try to implement the fix for the old wireless hardware.
Best regards,
Uldis C.
alexkulik
Sat Mar 03, 2018 7:38 pm
Delete
honzam
Sat Mar 03, 2018 8:15 pm
Yes, it is software problem. Because with LEDE works Mikrotik hardware better then original software (ROS)
UpRunTech
Sat Mar 03, 2018 9:37 pm
Best regards,
Uldis C.
Uldis/Normis: When you do your development and testing on Wifi modes do you validate the signal with a suitable Rhode&Schwartz/Agilent/Anritsu/Keysight/etc spectrum analyser and 802.11 protocol tester at all? It would seem to me such a device would reveal your problem very quickly! It seems to me like you're guessing!
nkourtzis
Mon Mar 05, 2018 10:46 pm
I have read through the topic and is clear to me that Mikrotik via Normis as representative, is either lying or the Mikrotik developers really have no much idea about wifi, although they are supposedly writing code for wifi devices. Both possibilities are really sad and show that anyone who takes wifi seriously should not invest much in Mikrotik Access Points.
Reportedly, LEDE works just fine in the very same devices for which MkTik initially responded that they need too much work to fix and later changed to that they are fundamentally incompatible and thus cannot be fixed. My guess? Of course the problem is not in the chip and can be fixed, but the Mikrotik Atheros driver is a highly proprietary patchwork, too alienated from the upstream code to backport any fix, especially since the current Mikrotik devs are clearly not very competent in low-level wifi coding: everything that requires hacking deeply into the hardware are off-limits for them, like NV2 for example.
In this respect, it looks like the initial reply by Normis was the more sincere one, while the second was just a clumpsy cover-up of MkTik's severely limited coding ability for anything wifi-related.
Passionate about networks
Enthusiastic about Mikrotik
MTCNA | MTCRE | MTCINE
No trees were killed to send this message,
but a large number of electrons were terribly inconvenienced.
Bavarian
Thu Mar 08, 2018 4:27 pm
I can confirm the same issue here with 2 devices - Xiaomi Redmi Note4 and a wireless usb stick with RTL8811AU chip. Both tested on 2.4 Ghz band.
WhyFi
Thu Mar 15, 2018 2:52 pm
Same problem here.. RX and TX <20Mbps
CAT S60
LG G3
Any news on a software fix?
Does the new hAP ac² suffers from the same issue?
Simono
Tue Mar 20, 2018 9:52 am
I also have big problem with now one phone on my network, it's Xiaomi Redmi 3. User told me thet biggest problem is form a week (probably last update for the router and CAPs). I see that RX connect is only 1-13,5Mbps, TX connect in the same time is to 150Mbps. I mustrun one AP on OpenWrt/LEDE to give use possible to use internet. In this case is biggest problem only for download speed because speed connect to APs is mostly 1Mbps.
Simono
Tue Mar 20, 2018 9:59 am
I also have problem with TX rate now for one phone on my network, it's Xiaomi Redmi 3. User told me that big problem is for a week. Then I've upgraded my router and CAPs to 6.41.3
He get TX rate mosty 1Mbps and of course can't use internet connection.
endorphinity
Tue Mar 20, 2018 9:32 pm
Apparently, there is a serious flaw in your hardware design process. Here is the screenshot of my wap AC connected devices which shows quite a few devices none of which is low-end Chinese phone, as it was said previously. Especially interesting is the Tx rage of iPhone 6s which is even lower than that of Moto G2.
floresta
Fri Mar 30, 2018 1:12 am
I am also having this exactly same problem.
My Mikrotik device is a RBCAPL-2ND (CAP Lite). The phone is a Moto G5 plus, which has a Qualcomm Snapdragon 625 chipset, probably the same processor as the Xiaomi's phones.
Interestingly, my Moto G5 plus initially is shown on the registration page with the Tx Rate set to 14mbps-20MHz/1s/SGI. But after a few seconds the Tx Rate changes to 54Mbps. When my phone is connected to the Mikrotik CAP Lite, the download bandwidth measured using IPERF3 is ~20 Mbps and the upload bandwidth is ~50 Mbps.
Another problem with this CAP Lite device is that the channels 7 and 8 cannot be used properly because they provide a max bandwidth of about 3 Mbps.
My Google Chromecast and my Lenovo ThinkPad T430 have no problem to connect to this CAP Lite at 802.11n speeds (72 Mbps and 144 Mbps respectively).
The same phone connects successfully at 802.11n speeds (2.4 GHz) to the following wireless devices:
TP-LINK TL-WR842ND.v2 running LEDE firmware 17.01.4 - Tx 72Mbps - Rx: 72Mbps - actual bandwidth measured using IPERF3: ~51 Mbps.
TP-LINK EAP115.v1 running firmware version EAP115(US)_V1_170106: Tx: 72Mbps - Rx: 72Mbps - actual bandwidth measured using IPERF3: ~52 Mbps.
TP-LINK Archer C20.v4 running firmware version Archer C20(BR)_V4_170309: Tx: 72Mbps - Rx: 72Mbps - actual bandwidth measured using IPERF3: ~50 Mbps.
So until this driver problem is fixed, this device is useless to me.
nemoforum
Sat Mar 31, 2018 1:42 pm
Okay, I followed your recommendation and got another issue viewtopic.php?f=2&t=132576
nemoforum
Thu Apr 19, 2018 12:39 pm
Best regards,
Uldis C.
WHEN?!
alexkulik
Thu Apr 19, 2018 6:41 pm
Delete
Pauloriply
Fri Apr 20, 2018 2:33 pm
Hello.
I was tormented with the same problems.
Today I updated one access point wAP AC to 6.43rc3. Result - It works as it should !!!
Problems with mobile devices have been fixed!
antonsb
Re: Xiaomi phone low Wifi TX rate  [SOLVED]
Fri Apr 20, 2018 3:07 pm
6.43rc3
*) wireless - improved compatibility with BCM chipset devices;
This includes XIAOMI devices. Please upgrade and test - fixes soon will be included in current releases as well
Pauloriply
Fri Apr 20, 2018 3:22 pm
6.43rc3
ISP link 1Gb
AP - wAP AC
Devices:
Xiaomi mi max2 (down - 54 Mbps, up - 72Mbps)
Lenovo P2 (down - 90 Mbps, up - 70Mbps)
Tested only on 2.4 GHz
antonsb
Fri Apr 20, 2018 4:00 pm
Are data rates reaching maximal supported by devices?
Pauloriply
Fri Apr 20, 2018 4:09 pm
About Lenovo P2 - no questions.
But I'm not sure that Xiaomi Mi Max 2, with the manufacturer's support for MU-MIMO gives out a maximum. If I'm wrong, correct it.
dvm
Fri Apr 20, 2018 4:47 pm
6.43rc3
Not only BCM and Xiaomi.
Lenovo K5 (Qualcomm Snapdragon) now get Tx Rate 72.2Mbps-20MHz/1S/SGI (max supported by device) with RB951Ui. With all previous ROS versions Tx Rate was 54Mbps (i.e. only 802.11g).
alexkulik
Fri Apr 20, 2018 6:05 pm
delete
antonsb
Fri Apr 20, 2018 6:56 pm
Your phone is already working on max rate, this limitation in Your phone hardware.
alexkulik
Fri Apr 20, 2018 7:21 pm
delete
Pauloriply
Fri Apr 20, 2018 7:35 pm
Your phone is already working on max rate...
So what about xiaomi mi max 2?
Bavarian
Fri Apr 20, 2018 9:24 pm
6.43rc3
Wow! That's great, thank you!
antonsb
Fri Apr 20, 2018 9:59 pm
This device is factory locked to 20MHz channels, to get more throughput you have to unlock 40MHz channel support
honzam
Fri Apr 20, 2018 10:13 pm
Hello. Very thanks Mikrotik!!!
This problem is for me FIXED!
My affected devices: Samsung galaxy Xcover4, Lenovo K6 and tablet Lenovo YOGA2. With 6.41.3 is maximum TX rate 54Mbit and download speed max 20Mbit.
With 6.43rc are ALL devices Tx Rate 72.2Mbps-20MHz (maximum supported).
On samsung Xcover4 is download over 42Mbit
strelokr
Fri Apr 20, 2018 10:46 pm
I sat once again twisting the wi-fi settings in the hope of achieving normal speed. I think I'll go and look at the forum to see what people write. the problem was solved! Thank you Mikrotik team. Now my old Xiaomi red note 2 works as expected. Now I'll update the wap AC at work
Deaqui
Sat Apr 21, 2018 2:26 am
After upgrading to version 6.43.3rc my Huawey Yumo reaches a data rate of 65Mbps-20MHz / 1S. With previous versions, it only reached 54 mbps.
Thanks Mikrotik!
UpRunTech
Sat Apr 21, 2018 4:21 am
6.43rc3
I am pretty interested to know what the fix was. Any chance of a technical summary about what had to get changed?
Also, given 6.43 stable is still some months away can you please backport this fix to 6.42.1?
alexkulik
Sat Apr 21, 2018 8:24 am
Delete
dnyl
Mon Apr 23, 2018 1:26 pm
Huawei P9 lite, works great :) 150/150 :-D :-D :-D :-D :-D
SwissWISP
Mon Apr 23, 2018 2:51 pm
Thanks guys for the fix! It works great on my Cat S60. Now I reach an air rate of 150Mbps, which is the same speed as in the opposite direction.
- Mat
UpRunTech
Mon Apr 23, 2018 5:08 pm
The bonus with 6.42.1 is that it has the BCM Wifi fix in it. Already I am seeing all my Android devices and laptops with BCM chips now connecting faster than 54Mbit! Wooohooo! File transfers over SMB/CIFS to the laptops improved 50% too (on a 20MHz channel).
floresta
Thu Apr 26, 2018 10:03 pm
I just upgraded my CAP Lite (RouterBOARD cAP L-2nD) to RouterOS v6.42.1 (stable) and I can confirm that my Moto G5 Plus now can connect to this router using the 802.11n speeds, instead of 802.11g. The registration now shows 72.2Mbps-20MHz/1S/SGI on both TX and RX.
The bandwidth measured using IPERF3 tool shows ~50 Mbps on download and ~53 Mbps on upload. Those bandwidth results are on par with the TP-LINK EAP115.
Congratulations to the Mikrotik Team for this fix.
Thank you very much Mikrotik Team.
vecernik87
Forum Veteran
Forum Veteran
Fri Apr 27, 2018 2:14 am
Please, disable bluetooth while you test your wifi on phones. Many phones (including xiaomi - i have one of these) have shared resources for bluetooth and wifi.
chechito
Sun Apr 29, 2018 4:39 pm
Good day
Once again, a huge thank you to your team!
You fellows!
As for the phone, you were wrong, the limitation was software! With ROOT, it now supports a bandwidth of 40Mhz.
Now everything suits me!!!!!
All the best to your team!
another good new
6.40.8 includes the fix
dougunder
Wed May 02, 2018 6:36 pm
Were testing 6.42.1
2G is terrible (10-15mb) unless you use 20/40 (60+)
This is across devices.
Terrible waste of spectrum when all you need is a stable 30m
Most of our customers have our 30 synchronous (3030 i get me hands dirty)
Huge bonus points is you can name the artist :)
5 or 6 all in an apartment all channel bonding saturates 2G.
Really unsustainable.
antonsb
Thu May 03, 2018 1:25 pm
Were testing 6.42.1
Sorry but it's hard to understand You.
Are You still experiencing issues? Are You sure this is not caused by other factors?
strelokr
Thu May 24, 2018 10:31 am
I connected to another provider. 100 MB. The download speed is still around 50Mb / sec. And the Upload speed reaches 92 MB / sec. The Mikrotik team made a bug fix, but not until the end
Users browsing this forum: snib and 39 guests
