anuser
Building inhouse access point (dual band) with NetMetal 5
Mon Dec 14, 2015 5:24 pm
I´d like to try Mikrotik for inhouse setup.
- NetMetal 5 RB922UAGS-5HPacT-NM (black edition seems to be new)
- R11e-2HPnD
I need omnidirectional antennas, so
what (small) antennas should I get?
-- (3 pieces) for 5.0Ghz?
-- (2 pieces) for 2.4Ghz?
Regards
gtj
Re: Building inhouse access point (dual band) with NetMetal 5
Mon Dec 14, 2015 7:01 pm
I use this setup as well in a bunch of places.
You need 3 5GHz and 2 2.4GHz antennas and don't forget the MMCX to RP-SMA pigtails for the R11e.
chechito
Mon Dec 14, 2015 7:16 pm
beware of not power on the radios without pigtail and antenna connected to them
powering a radio without antenna can damage it
anuser
Mon Dec 14, 2015 10:08 pm
Thanks for the information. Do you have any recommendation for the antennas?
gtj
Tue Dec 15, 2015 12:19 am
If I can find that last ones I bought I'll post the part numbers but they were normal 3dbi RP-SMA sticks. Don't get dual-band ones. Get 3 tuned for 5GHz and 2 tuned for 2.4GHz.
Users browsing this forum: No registered users and 22 guests
