sjokotof
CCR1009-8G-1S-1S+PC lower clock
Mon Jan 04, 2016 10:23 pm
The spec for CCR1009-8G-1S-1S+PC seems to have changed from 9 cores x 1.2GHz CPU to 9 cores x 1GHz CPU.
Did the actual spec change from 1.2 to 1 or merely the listing at http://routerboard.com/products?
chechito
Re: CCR1009-8G-1S-1S+PC lower clock
Tue Jan 05, 2016 7:41 am
passive cooling version operates at 1.0ghz
active cooling version operates at 1.2ghz
sjokotof
Tue Jan 05, 2016 1:01 pm
Thx, but does not reply the question
strods
Tue Jan 05, 2016 1:52 pm
It is only default frequency. You can set it manually to 1.2GHz.
Simply with 1GHz it does not heat up as much as with 1.2GHz.
sjokotof
Tue Jan 05, 2016 2:16 pm
Thank you, I suspected the passive cooling might have had something to do with this.
But have you altered the actual product or has this always shipped out with CPUmax @ 1GHz?
I'm watching the product listings page (to see when the HAP AC comes up) and this was shown a change in the listing.
normis
Tue Jan 05, 2016 4:25 pm
It was always 1GHz, but it is the same CPU, just clocked lower
sjokotof
Tue Jan 05, 2016 4:29 pm
Thank you, 100% clear.
Quindor
Wed Jan 06, 2016 8:14 pm
Just to add for people who aren't aware. I've been running my CCR1009 at 600Mhz for a while now and performance is still stellar (Easily still more then 10x of a RB2011). I'm using it in a big home setup and really don't need to the power 1.2Ghz gives.
Most routerboards support this feature! Overclock (with decent cooling) or underclock to suit your needs. :)
http://www.campzone.nl World's Largest Outdoor LANParty, http://intermit.tech Intermittend Technology blog, My blog about the ESP8266, IP Camera's and other tech related subjects!
chechito
Wed Jan 06, 2016 10:23 pm
+1 im running it at 400mhz
Users browsing this forum: No registered users and 37 guests
