MUM Europe 2020
daggerCVN
Need RB2011 dimensions (height is missing)??
Wed Jan 13, 2016 11:27 pm
Product brochure only gives LxW of 214mm x 86mm, but I can't find the Height spec anywhere (I need to calculate clearance in an IDF enclosure). Thanks!
chechito
Re: Need RB2011 dimensions (height is missing)??
Thu Jan 14, 2016 4:07 am
on wireless version brochure the height is shown, i dont know why but has different dimensions
http://i.mt.lv/routerboard/files/RB2011 ... 111539.pdf
be aware of rack mount version has different dimensions
daggerCVN
Thu Jan 14, 2016 6:19 pm
Thanks chechito - I hope the 25mm/1" height dimension is correct (and not the 1RU/1.75"/44mm that the rack mount 2011 router is) as I only have 1.5" of clearance in my SWB location..
Looking at the product sheets and the quick start guides, it doesn't say if the RB2011xxS versions with the SFP port is a combo-port design (ie., if you use the SFP port then you can't use the corresponding ethernet port) or can be used as a standalone WAN uplink port... Sure wish these 2011's had all Gig ports :-(
acidsas
Mon Jan 18, 2016 7:16 pm
SFP port is an independent port connected to internal gig switch. Look at block diagram — http://i.mt.lv/routerboard/files/Block-RB2011.pdf
BTW, 3011 got all gig ports.
daggerCVN
Mon Jan 18, 2016 8:22 pm
Thanks acidsas on the independent SFP port. I'm hoping to hear Mikrotik will release a desktop RB3011 series soon.
Mikrotik support was kind enough to send me the dimensions info:
RB2011 - 230x90x25mm
RB2011 with antennas - 230x113x25mm
RB2011-RM - 443x92x44mm
Users browsing this forum: No registered users and 89 guests
