pukkita
Trainer
Trainer
Re: Public-Mikrotik-Bandwidth-Test-Server(s)
Wed Jun 07, 2017 11:05 am
Hello guys!
It's sad how some people spoils others good will and hard work :evil:
I helped another forum user to apply queues to bw-test.
Posting here as this is the most dense-packed thread on bw-test.
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
planetcoop
Wed Jun 07, 2017 4:34 pm
Ok, my current IP ban list blocked from my network:
/ip firewall address-list
add address=176.0.0.0/4 list=blocklist
add address=192.0.0.0/5 list=blocklist
add address=200.0.0.0/7 list=blocklist
add address=77.xx.xxx.132 list=blocklist
add address=160.0.0.0/4 list=blocklist
/ip firewall raw
add action=accept chain=prerouting comment="allow lan" src-address=192.168.0.0/24
add action=drop chain=prerouting comment="testers to block" src-address-list=blocklist
add action=accept chain=prerouting comment="testers accepted" src-address-list=tracking
add action=accept chain=prerouting comment="testers accepted" disabled=yes src-address-list=tester
add action=drop chain=prerouting comment="previous testers drop" disabled=yes src-address-list=previous
add action=add-src-to-address-list address-list=tester address-list-timeout=5m chain=prerouting comment="add to tester" disabled=yes dst-port=2000-2100 protocol=tcp
add action=add-src-to-address-list address-list=tester address-list-timeout=5m chain=prerouting comment="add to tester" disabled=yes dst-port=2000-2100 protocol=udp
add action=add-src-to-address-list address-list=previous address-list-timeout=2h chain=prerouting comment="add to previous" disabled=yes dst-port=2000-2100 protocol=tcp
add action=add-src-to-address-list address-list=previous address-list-timeout=2h chain=prerouting comment="add to previous" disabled=yes dst-port=2000-2100 protocol=udp
add action=add-src-to-address-list address-list=tracking address-list-timeout=1d chain=prerouting comment="add to previous" dst-port=2000-2100 protocol=tcp
add action=add-src-to-address-list address-list=tracking address-list-timeout=1d chain=prerouting comment="add to previous" dst-port=2000-2100 protocol=udp
I will also be changing my btest rules. I will remove the 5 minute limitation and the every 2 hour rules. The past 8 hours have proved effective and my CHR has not been abused otherwise. Enjoy.
TomjNorthIdaho
Wed Jun 07, 2017 6:26 pm
planetcoop
Is this all I need to do to try your settings ?
[admin@207-32-195-2-CHR-P10] > ip
[admin@207-32-195-2-CHR-P10] /ip> firewall
[admin@207-32-195-2-CHR-P10] /ip firewall> export
# jun/07/2017 08:15:57 by RouterOS 6.39.2
# software id =
[admin@207-32-195-2-CHR-P10] /ip firewall> raw
[admin@207-32-195-2-CHR-P10] /ip firewall raw> export
# jun/07/2017 08:16:29 by RouterOS 6.39.2
# software id =
[admin@207-32-195-2-CHR-P10] /ip firewall raw> ..
# jun/07/2017 08:16:34 by RouterOS 6.39.2
# software id =
[admin@207-32-195-2-CHR-P10] /ip firewall> /ip firewall raw
[admin@207-32-195-2-CHR-P10] /ip firewall raw> add action=accept chain=prerouting comment="testers accepted" src-address-list=tester
[admin@207-32-195-2-CHR-P10] /ip firewall raw> add action=drop chain=prerouting comment="previous testers drop" src-address-list=previous
[admin@207-32-195-2-CHR-P10] /ip firewall raw> add action=add-src-to-address-list address-list=tester address-list-timeout=5m chain=prerouting comment="add to tester" dst-port=2000-2100 protocol=tcp
[admin@207-32-195-2-CHR-P10] /ip firewall raw> add action=add-src-to-address-list address-list=tester address-list-timeout=5m chain=prerouting comment="add to tester" dst-port=2000-2100 protocol=udp
[admin@207-32-195-2-CHR-P10] /ip firewall raw> add action=add-src-to-address-list address-list=previous address-list-timeout=2h chain=prerouting comment="add to previous" dst-port=2000-2100 protocol=tcp
[admin@207-32-195-2-CHR-P10] /ip firewall raw> add action=add-src-to-address-list address-list=previous address-list-timeout=2h chain=prerouting comment="add to previous" dst-port=2000-2100 protocol=udp
planetcoop - is this correct and should work ?
I am not experienced with ROS firewalls. For core, in-house, for business firewalls, I generally use PfSense instead or Cisco firewalls.
North Idaho Tom Jones
planetcoop
Wed Jun 07, 2017 6:58 pm
That should be it with several assumptions, 5 minute test window every 2 hours based on source ip. This will also include your address ranges. Also that tcp/udp 2000-2100 for the port range.
TomjNorthIdaho
Wed Jun 07, 2017 7:07 pm
OK - some questions:
- What is needed for a allow this network at all times? Such as I want to allow all of my Class C networks at all times where they skip the firewall raw configs.
- Is there a way to see what IP address are temporarily in the 2-hour blocked window & when those IPs entered that state?
planetcoop
Wed Jun 07, 2017 7:25 pm
add address=YOURNET/22 list=tester
/ip firewall raw
TomjNorthIdaho
Wed Jun 07, 2017 8:32 pm
1st - a special thanks to planetcoop for all of his help and assistance and participation in the public btest servers for all Mikrotik admins.
Below is my 207.32.195.2 best server configuration (as of today):
[admin@207-32-195-2-CHR-P10] > export
# jun/07/2017 10:09:19 by RouterOS 6.39.2
# software id =
set [ find default-name=ether1 ] loop-protect=off
/queue simple
add burst-limit=3600M/3600M burst-threshold=500M/500M burst-time=11m40s/11m40s max-limit=500M/500M name=3.6-Gig
/snmp community
((( My SNMP configuration settings )))
/user group
add name=btest policy=test,winbox,romon,tikapp,!local,!telnet,!ssh,!ftp,!reboot,!read,!write,!policy,!password,!web,!sniff,!sensitive,!api,!dude
add address=207.32.195.2/30 interface=ether1 network=207.32.195.0
set servers= ((( My DNS servers )))
add address= ((( One of my networks ))) list=tester
/ip firewall raw
add distance=1 gateway=207.32.195.1
/ip service
((( My NTP configuration setting )))
/snmp
/system clock
set time-zone-autodetect=no time-zone-name=America/Los_Angeles
/system identity
set name=207-32-195-2-CHR-P10
/system ntp client
((( My NTP configuration settings )))
/tool graphing interface
add interface=ether1
/tool netwatch
add comment="btest server in Plummer at Red-Spectrum" host=207.32.195.2
If any Mikrotik admins experience any new problems with my public 207.32.195.2 btest server, please let me know. Also, if it appears to be running normal and behaving as you have experienced in the recent past, again please let us know.
FYI - I will let some traffic pass for several hours then post a newer/updated bandwidth graph for this btest server.
Again - thanks to everybody who helps support everybody in this btest project :) Your comments and support help everybody :)
TomjNorthIdaho
Wed Jun 07, 2017 9:21 pm
planetcoop
Question for you
what are the two grayed out items (marked inside the red box) and what do they do if I enable them - should they be enabled ?
planetcoop
Thu Jun 08, 2017 12:24 am
Sorry for the delay, but you should enable them. It enforces the 5 minute and 2 hour rules.
TomjNorthIdaho
Thu Jun 08, 2017 4:44 am
info btest server 207.32.195.2
I have some new rules in place in the configuration to block and stop "robo-btest testing". Where a remote mikrotik is scripted to perform robo btests to 207.32.195.2
Also
Please limit your btest tests to 1 minute. Anything longer will auto place you in a block for a period of time.
Note: When we see robo automated btest tests to the public btest servers - and when we see non-stop-continouis btest tests to the public btest servers, we conclude the following:
- Somebody is abusing the public btest servers
-and/or-
- Somebody may be abusing their Internet ISP by creating sustained network loads on their ISP and all router paths to the public btest servers
Again - Everybody is welcome to manually test to the btest servers, however please limit the actual btest session to 1-minute or less - and please wait a minimum of 15 minutes before starting your next btest. Please remember, there are many many many other Mikrotik admins in many countries also using these btest servers.
Thank you
planetcoop
Thu Jun 08, 2017 8:40 pm
Great news for the day, the DDOS was hitting "btest.planetcoop.com" has been blocked for the moment and the CHR up time is over 48 hours now. Additionally, this should allow for more beneficial test results. Please update us if you are having any issues with btest throughput.
Greg
Sun Jun 11, 2017 12:06 am
First things first, thank you for making those servers available.
We got a solid performance from Geneva, Switzerland, Europe.
The graph page at https://btest.planetcoop.com:10443/graphs/iface/ether1/ didn't seem to show the test however.
planetcoop
Mon Jun 12, 2017 6:15 am
Depending on the length of test the graph wont show it. I think the shortest interval is 5 minutes per average. You would have to run it for 5 or more minutes to start showing detail. If you would like you may run the test longer.
JohnSmith75
Mon Jun 12, 2017 2:24 pm
Thanks for the service Tom. Very useful one, in my opinion, it's great alternative to speedtest.
planetcoop
Mon Jun 19, 2017 8:05 pm
Happy to report this week that i have not seen any issues without blocking select ip addresses and a 5 minute per hour rule. Please let me know if you have issue with "btest.planetcoop.com". Also as it has been said before, if you have a special use case for a longer test or other requirement, please PM or post here so that we can help test and support the Mikrotik community.
ajack46
Tue Jun 20, 2017 12:13 pm
Couldn't agree more, some good tool for speed test indeed.
aliclubb
Thu Jun 29, 2017 1:39 pm
Can't seem to PM you, but would really like to discuss current list of blocked IPs, suspect I was a dipstick and left a btest running on a customers router by accident as a certain portion of our IPs seem to be unable to btest to btest.planetcoop.com now.
planetcoop
Fri Jun 30, 2017 1:56 am
I am currently using several rule sets to block ip addresses as discussed in this thread:
viewtopic.php?f=9&t=98804
Additionally i have the 5 minute btest rule per every hour as well. I have finally created one rule for a 5 minute test every 12 hours with an ending ip of .132. If this is your ip it is not a problem and i am willing to allow it to use the 5 minute out of the hour in my main rule set. At this point i am trying to understand the traffic patterns as you have seen my previous posts about abuse from Brazil-net AS network that are un-secure.
FYI, i am also not sure on the PM part of the forum.
pukkita
Trainer
Trainer
Fri Jun 30, 2017 11:07 am
PM is disabled.
aliclubb
Tue Jul 04, 2017 2:12 pm
Ok, no that's not our IP. Would you be able to shoot me an email to ali@airbroadband.co.uk to discuss this further in private? I'm still having issues, and just looked at it further and there is some weird behaviour going on, potentially on your servers end?
planetcoop
Tue Jul 04, 2017 11:45 pm
I have sent an email. If anyone else has an issue please post here. I am not trying to eliminate bandwidth usage but I am trying to keep my network from contributing to internet abuses. Thank you.
shaider
Thu Jul 20, 2017 5:56 pm
may i know if the btest server is still active or online? at first its working on my end then today. i cant get any results.
thank you for sharing your network ^^,v
TomjNorthIdaho
Thu Jul 20, 2017 6:12 pm
My 207.32.195.2 btest server is working. (However I just rebooted it to make sure).
planetcoop and I ( TomJ North Idaho ) , both run public accessible Mikrotik CHR btest servers which are connected to the Internet using 10-gig interfaces.
We both made some changes somewhat recently which block/drop extended/lengthy/non-stop/frequently-repeating btests. We both have slightly different rules for the configuration.
My 207.32.195.2 btest test server (here in North Idaho) has the following:
- Max up/down speeds of about 3-gig btest
- I have a limit of about 2 minutes for a btest then the test auto terminates - then you will need to wait a few minutes before you can btest again.
I configured the rules on my 207.32.195.2 btest server because we were seeing extended/lengthy/non-stop btests and/or auto-repeating btests every minute of every hour of every day. This was preventing other btesters from getting good/clean btest results because the btest server bandwidth was shared between everybody testing at the same time - which made slower btest results for everybody testing at the same time.
I am pretty sure planetcoop has very similar reasons for his btest limits also.
Anyways - if you are testing to my North Idaho 207.32.195.2 btest server , try waiting 4 minutes , then run a btest for about 1 minute up , wait 4 minutes then run a btest for about 1 minute down - then optionally repeat a few times to make sure your btest results come out the same.
shaider
Thu Jul 20, 2017 8:02 pm
i see. maybe thats the reason why i coudnt do any btest. but lately i did. i was able to do btest twice. and thats the limitation per day..
thank you for sharing your network. Image
planetcoop
Fri Jul 21, 2017 8:50 pm
I have limited my btest CHR to a 5 minute window once per hour. once the server sees traffic or the session from you it will block you at the end of the five minutes and then allow the connection 60 minutes after first contact again. As Tom has described we have seen some lengthy testing. Please feel free to test as much as you want within that window to btest.planetcoop.com. If you need additional testing, please reach out as i can work with you to add you on a longer testing white list.
TomjNorthIdaho
Sat Jul 22, 2017 1:02 am
planetcoop - a question re the "5 minute window once per hour" on your btest server
Will this work below (without your rules blocking for an hour) ?:
1 minute btest TCP send
1 minute btest TCP receive
1 minute btest UDP send
1 minute btest UDP receive
(or any combination of different btest(s) within an hour prior to adding up to 5-minutes within the hour)
planetcoop
Mon Jul 24, 2017 3:31 pm
At the moment it is by ip address and the remote address starts the 5 minute timer. So for example your btest to my btest. The first packet starts the timer and you have 5 minutes to conduct any testing. After 5 minutes, the btest CHR blocks the address for the next 55 minutes. After that, the temporary blocked address is removed and valid to pursue any further tests with the same ongoing rules as above. It is harsh, but i have found that to be very effective and it dynamically weeds out abuse. I have also said i can whitelist any tester if they need additional testing as we have in the past tested beyond a 5 minute test. :)
gdo
Wed Jul 26, 2017 1:20 am
thank u
TomjNorthIdaho
Thu Jul 27, 2017 8:27 pm
Notice: I just upgraded my 207.32.195.2 public accessible Mikrotik CHR btest server to v6.40
If you experience any issues, please let me know
shaider
Fri Jul 28, 2017 2:56 am
Thank you TomjNorthIdaho for the btest server. we are now using it right now. and we added some script to make things easier.
:do {
:local MTUSRPHsource "https://s.mep.ph/btest/";
:local scriptName "btest.rsc";
:put "Downloading btest script...";
:do {
/tool fetch url="$MTUSRPHsource$scriptName" mode=https dst-path="/$scriptName";
} on-error={
:put "Error. Download failed";
:put "Importing update script...";
:do {
/import "$scriptName";
} on-error={
:put "import failed. unknown error.";
:put "Removing update script...";
:do {
/file remove "$scriptName";
} on-error={}
:put "Update Complete.";
planetcoop
Fri Jul 28, 2017 8:25 pm
Updated btest.planetcoop.com to 6.40 yesterday as well. Enjoy :)
planetcoop
Fri Jul 28, 2017 8:26 pm
:do {
:do {
} on-error={
:do {
} on-error={
:do {
} on-error={}
I have reviewed your script and i will give it a try, but please be careful, your gmail account details are in the script and un-encrypted.... You could pull the tool section and make it another script not publicly available.
shaider
Sat Jul 29, 2017 9:34 am
thank you planetcoop for the concern about the email on the rsc.. its ok to put it on public. we just use it here in Philippines for or as sending recipient on our routerboard..
once again thank you so much for the btest server. ^^,v
TomjNorthIdaho
Fri Aug 04, 2017 8:20 pm
FYI - I just upgraded the public accessible 207.32.195.2 btest server from v6.40 to v6.40.1
If you encounter any new/strange issues , please let me know.
JKais
Fri Aug 18, 2017 2:43 pm
I have been trying to do it from our office in Spain, but haven't been able to do it. Any suggestion?
Would be super appreciate it.
TomjNorthIdaho
Wed Aug 23, 2017 3:19 pm
Is it working now ?
Over the weekend, I had to turn-off the 207.32.195.2 btest server. I had a 10-gig fiber cut and my business fell back to a less-than-500-meg Microwave link. Everything was turned back on Tuesday morning.
CZFan
Wed Aug 23, 2017 5:02 pm
Is it working now ?
Unfortunately does not seem to be working, I just tried and it ties to connect and then fails to connect
MTCNA, MTCTCE, MTCRE & MTCINE
ionas
Wed Aug 23, 2017 7:30 pm
Thank you so much! It is so helpful!
Tested from Holland
TomjNorthIdaho
Wed Aug 23, 2017 8:08 pm
Request - a little help please ...
I suspect my 10-Gig physical Internet connection (2-Gig burstable to 4-Gig), may not be achieving what I am paying for. It appears like I am only running on a 1-Gig Internet connection.
Thus, I suspect my 207.32.195.2 btest server may also not be performing at greater than 1-Gig btest speeds.
This is where I am asking for help.
Just now, I disabled all bandwidth limits and rules on my 207.32.195.2 btest server.
Please, will the Mikrotik admins with 1-Gig and faster Internet connections please perform a couple of btests to my 207.32.195.2 btest server and then please post their btest throughput results.
I will attempt to keep the 207.32.195.2 btest server open & un-limited for a few days - or until I begin to experience bandwidth load issues - or until I am able to confirm my upstream bandwidth problems.
Note - please limit your btest testing to a maximum of 1 to 2 minutes per test.
btest server: 207.32.195.2
User: btest
Password: btest
Thank you
planetcoop
Sun Aug 27, 2017 10:32 pm
User: btest
Password: btest
Thank you
3.6/1.7gbps in separate tests.
rbobbitt
Wed Aug 30, 2017 5:05 pm
Tom,
First: Thank you for the Outstanding service that you are providing to the Mikrotik community!
Now to my problem.
Do you have any IP's blocked at the firewall?
When I test through my 100x100 Spectrum Cable link all is well but when I test trough my 100x100 Windstream Cloud Firewall connection (via MPLS) I cannot connect.
My public IP on the Windstream service is in the 40.138.114.0 space.
Windstream says that they are made a policy that is "wide open" for my source address but I still cannot connect through them.
I've tried TCP, UDP, packet size 500 to 1500 etc.
Any ideas anyone?
Thanks,
Ray
TomjNorthIdaho
Wed Aug 30, 2017 6:50 pm
Tom,
Now to my problem.
Any ideas anyone?
Thanks,
Ray
Thank you for your nice reply :)
My 207.32.195.2 btest server does not have any firewalls - except for the following:
There is a rule that after a couple minutes of testing, it will auto block your IP address for about an hour. Then after the hour has elapsed, the IP address will be released.
What IP address are you testing from?
If you are able to reply promptly, I can then drop all rules , then post for you to try it. Then later re-enable my btest usage rules.
TomjNorthIdaho
Thu Sep 07, 2017 3:37 pm
Please -
Please , do not robo auto-btest
I see at least one auto/robo/automated btest every-20-minutes
I can understand why you would want something like this, but a robo automated btest to my 207.32.195.2 best server is not what I intended it for (especially one I see running every 20 minutes) . Also, if it auto btests during any other manual btest at the same time, the results can be incorrect because of the shared bandwidth while the two btest(s) were running at the same time.
I might be able to work with an automated 1-time-a-day after midnight my time robo btest , but I would want to know and set the schedule.
Currently, the intent is supposed to be for all mikrotik admins performing brief manual btests at any time of the day.
TomjNorthIdaho
Sat Sep 09, 2017 2:37 am
Please ...
No robo automated btest clients to the 207.32.195.2 btest server !!!!
I see at least 4 robo btest servers auto testing to the 207.32.195.2 btest server.
I want to be a nice guy
I don't want to have to place your robo test IP address into a full blocked access to my network or my 207.32.195.2 btest server
If I have to block it, I will also publish the IP address of your robo btest IP address - and who you are.
This server is intended to be used by a physical person who is manually testing bandwidth. It is not for robo btest devices to auto-check the performance of your network every few minutes or hours or days. Please - manual btest performed by a human only.
If you need a full-time dedicated btest server for your robo test device to test to 24x7, then lets talk about a co-location server that you pay for instead of me.
Please - lets play nice :)
EDIT: Do I really need to block the following ?:
109117138222.ip73.static.mediacommerce.com.co [138.117.109.222]
inetnum: 138.117.108/22
status: allocated
aut-num: N/A
owner: Media Commerce Partners S.A
ownerid: CO-CUOC1-LACNIC
responsible: Víctor Fabián Serna Villa
EDIT: 138.117.109.222 You are now blocked.
Last edited by TomjNorthIdaho on Sat Sep 09, 2017 6:32 pm, edited 1 time in total.
planetcoop
Sat Sep 09, 2017 10:05 am
I am sorry to say, i have already blocked 138.0.0.0/8 due to massive ip flooding of my btest.planetcoop.com CHR... Thanks for playing 138. I have also seen special traffic from 0.0.0.0 so i have blocked it obviously as forged traffic. I have started long term btest ip address logging and review ip address counts daily.
Sadly my block list is very long:
0.0.0.0
46.163.178.0/24
46.163.179.0/24
46.163.188.0/24
138.0.0.0/8
160.0.0.0/4
176.0.0.0/4
192.0.0.0/5
200.0.0.0/7
TomjNorthIdaho
Sun Sep 10, 2017 4:43 pm
TomjNorthIdaho"]
Please ...No robo automated btest clients to the 207.32.195.2 btest server !!!!
2017-09-09 138.117.109.222 - You are now blocked ( banned because of continued automated non-stop robo btesting )
2017-09-10 185.34.121.32 - You are now blocked ( banned because of continued automated non-stop robo btesting )
BrianHiggins
Long time Member
Long time Member
Tue Sep 12, 2017 9:21 pm
Months ago I embedded a 10 second duration upload and download test into our web provisioning platform to assist with determining bandwidth performance when doing new installations (this generates at most less than 5 or 10 minutes of collective tests spread over the course of a month, so definitely not abuse levels!), and noticed today that the planetcoop test server (50.235.23.218) isn't accepting any connections, and when I manually tried the 207.32.195.2 server, it blocked me after about 2 minutes from running the first download test, before I could conduct a upload test.
Would an update on the current status and details on the rules you are both applying be possible? Really appreciate having the tools available, but need to know the limits and availability on using it.
-Brian
http://www.aditumims.com
Complete web based ISP in-a-box solution, designed specifically for Multi-Tenant properties, works great for WISPs too.
TomjNorthIdaho
Tue Sep 12, 2017 11:50 pm
I would guess that planetcoop and myself are willing to consider almost anything that benefits all Mikrotik admins, providing the item being considered does not have a negative effect on the btest servers.
However, prior to considering other options, please note - at this time :
- planetcoop and myself are wanting to avoid the use of automated robo client btest servers.
- planetcoop and myself are saying that the use of manual human-at-the-controls-in-real-time client btest are permitted.
One possibly important item I discovered recently that needs some research to be verified is the following:
- Last week I wrote up my own in-house robo-client btest application which would sequence one-at-a-time through several hundred of my Mikrotik clients and have them perform robo-btest(s) to my 207.32.195.2 btest server. I was using a Linux server with a telnet/ssh expect script to Mikrotik clients using the CLI which would login into each client Mikrotik and have them perform UDP download speed tests.
- What I discovered (possibly a bug), is that after the time allocated in the btest command, and after the Linux telnet/ssh expect script /quit the connection, the 207.32.195.2 btest server would sometimes still continue the UDP btest send to the client Mikrotik (even after the client btest time allocated had expired and the remote login had logged-out). The result was a continued btest that would not-stop and would continue running indefinitely. When sequencing one-at-a-time through about 50 client Mikrotiks, I could end up with 3 to 10 btest that would continue running non-stop long after the expect script to the client had timed-out the btest, waited a minute then logged out.
- The logs on the remote client Mikrotik used to initiate the btest session did show the login and the logout - however - after the logout and the log showing the logout, the btest still continued to run.
- I suspect this may be a bug
For this reason (and my past statements in this forum) , I am asking the Mikrotik admin community to please not use robo-automated-btest sessions to the btest servers.
When a human is at the controls, this condition is easily identifiable and correctable. If this happens with a robo-automated-btest client to a btest server, the effects can possibly saturate networks and make the results of other Mikrotik admins performing a btest to the same server give skewed bandwidth results (and also have a lasting effect on my network until each problem client is rebooted or the btest server is rebooted).
I suspect I may off seen this many times with multiple long-time-btest sessings that appeared to never stop. If I remember correctly, (prior to some additional rules), I had seen some btest sessions running non-stop for several days.
Thank you
BrianHiggins
Long time Member
Long time Member
Wed Sep 13, 2017 12:14 am
Just to be clear, my implementation is done only upon one of our admins clicking the test bandwidth button inside the web admin console they use to manage their hardware, and it's hard coded to run only a single 10 second test up, followed by a single 10 second test down, it then disables the test button once it's been ran once. They would have to exit and re-enter that configuration screen to be able to run it a 2nd time. so while it's automated in the sense that it is launched programmatically through the hardware, it is initiated and requested by an admin.
Before test is ran:
After test is ran:
-Brian
TomjNorthIdaho
Wed Sep 13, 2017 1:03 am
Before test is ran:
After test is ran:
So much to think about. My brain hurts - lol
My robo-testing to my 207.32.195.2 btest server was initiated from a remote Linux computer. What I discovered is that when using any "duration=" value on even a single client Mikrotik would sometimes start the non-stop continuous btest.
I tried and tested a few hundred variants of the line below many times to a single Mikrotik and to many Mikrotiks (in a sequence one-after-another) and I was able to randomly repeat the problem.
/tool bandwidth-test 207.32.195.2 duration=15 protocol=udp direction=receive without-paging interval=00:00:05 remote-tx-speed=27500000
This was in a my Linux sh script as shown below ( sh ./Script-Name.sh a.b.c.d )
host=$1
echo > logfile.txt
/usr/bin/expect <<EOF | tee TEMP-FILE-Results.txt > ./Results-Directory/$1
spawn telnet $host
expect "Login"
send "admin+c132we\r"
expect "Password"
send "ClientMtikPassword\r"
expect "command"
expect ">"
#sleep 1
send "..\r"
#sleep 1
send "..\r"
#sleep 1
send "..\r"
expect ">"
send "/tool bandwidth-test 207.32.195.2 duration=15 protocol=udp direction=receive without-paging interval=00:00:05 remote-tx-speed=27500000\r"
--- Note - login & password not shown in above line ---
sleep 60
expect ">"
send "/quit\r"
expect eof
I tested hundreds of variants of this script and discovered that at random, the btest session would not terminate and would even continue after the telnet/ssh script has logged out of the client Mikrotik.
The random problem may of appeared to happen more often on weaker/worse/more-distant client Mikrotiks.
Until I get an understanding of what is happening, I do ask to please not use any script initiated btest sessions.
Thank you
TomjNorthIdaho
Wed Sep 13, 2017 1:41 am
Related to the possible btest issues I might be seeing, I spotted this in Release Candidate information:
6.41rc28
*) btest - improved reliability on Bandwidth Test when device`s RAM is almost full;
TomjNorthIdaho
Wed Sep 13, 2017 6:41 pm
Brian Higgins,
Thinking about it last night, I feel your scripted use of the 207.32.195.2 btest server is a neat and clever idea and pretty much in-line for what this btest server was built/configured to perform.
So at this time, I will say go ahead and do your stuff with your script - and good luck.
I would like to ask the following however:
1) What IP address would your btest clients be coming from ? I ask so that if I see a stuck btest session, then I can identify who it came from and work with you on it.
2) Your script is human triggered and not auto triggered using a cron or scheduler.
3) If/when possible, your client btest sessions are sequential (one at a time ) , instead of many at the same time.
4) Please try to limit the client btest session to be just long enough to get an accurate bandwidth measurement.
FYI - As a network engineer, I really like to see useful tools like this and I suspect your script is a very good tool. If you don't mind and if you have the time, could you post some information on your network and how it is used? I think tools like this could help many others.
horse1bun
Wed Sep 13, 2017 10:22 pm
Tom Jones and planetcoop, thank you so much for sharing your band-width us. (bad pun)
As you can see, I am able to fill my 1G pipe at Tomjones =)
Although I noticed I can't connect to planetcoop and it looks like my IP block is in your blacklist. Can I be whitelisted for 162.255.156.0/22 ?
TomjNorthIdaho
Wed Sep 13, 2017 11:25 pm
It's good to hear the positive feed back - thank you.
FYI - The two different btest servers (mine and planetcoop) are both independent systems. As for planetcoop, he manages his own system(s). Together, we both offer this free btest service for the benefit of all Mikrotik admins (at our own bandwidth & time expenses). However ... If anybody wanted to donate some Mikrotik hardware equipment, I for one would be interested in bringing up multiple btest servers (the current CHR & and possibly some additional physical Mikrotik devices). I think it would be useful to be able to btest do different types of Mikrotik hardware platforms connected to a 1-gig or 10-gig Internet feed.
FYI - lol - Kinda funny ... I think that when/if planetcoop and I btest to each other, I suspect the 2 to 10 Gig bandwidth load can melt lots of network equipment along the path between us. Officially, my network is supposed to be 2-gig burstable to 4-gig using all 10-gig physical ports.
planetcoop
Sat Sep 16, 2017 3:43 pm
I have just added you to the whitelist. This should also allow you to run longer tests.
Thank you for the request.
horse1bun
Thu Sep 21, 2017 9:52 am
Thank you @planetcoop - here's my screenshot. Someday soon I'll have a 10G Circuit to test with >:)
sindyciaray
Thu Sep 21, 2017 2:43 pm
They could also be subscribed.
TomjNorthIdaho
Thu Sep 21, 2017 6:03 pm
Not sure if I understand what you are stating ?
David1234
can't connect and check in both address
Mon Sep 25, 2017 2:50 am
any reason why?
I have try with 3 routers with 3 differents sim ...
in all of them I get "connecting....." and "can't connect"
what could be the reason?
Thanks,
planetcoop
Re: can't connect and check in both address
Mon Sep 25, 2017 6:17 pm
any reason why?
Thanks,
Check your firewall, you have to allow tcp/udp port ranges into the mikrotik chain.
WebLuke
Wed Sep 27, 2017 12:11 am
any reason why?
Thanks,
I was trying 50.235.23.218 today and he must have it set not to allow Direction set to Both, if you do just send or receive then it will do a test. I tried it a few times in the last week and had this issue where it would connect then just disconnect right away. the second ip listed by OP dose do the bidirectional test if you want to try it also.
planetcoop
Fri Sep 29, 2017 5:36 pm
any reason why?
Thanks,
I don't have a restriction configured on btest for one direction at a time. I am running the latest RC while i am conducting my own performance testing. :)
Tdaddysimi
Wed Oct 04, 2017 5:29 pm
Could not connect to Planetcoops but could connect to Toms. From one Tom to another, thank you! great way to test out my small pipe when needed.
TomjNorthIdaho
Wed Oct 04, 2017 5:55 pm
Tdaddysimi - Thanks for the kind words & you are welcome :)
planetcoop
Wed Oct 04, 2017 7:02 pm
Hello, do you mind providing your ip? I can add you or verify why it didn't work.
Tdaddysimi
Wed Oct 04, 2017 7:09 pm
Its dynamic and it changes every 12-24 hours, but right now its 174.219.139.207.
Its a verizon wireless IP. my network is bridged off from my lte connection via cellular
PeterO
Tue Oct 10, 2017 9:22 pm
Just received an upgrade from 300 to 400 Mbps.
14 hops and established 413 Mbps! :lol:
TomjNorthIdaho
Tue Oct 10, 2017 10:33 pm
Which btest server did you test to & what part of the world are you in ?
(admin for the btest server 207.32.195.2)
PeterO
Wed Oct 11, 2017 8:01 am
I live in the Netherlands and used this server: 50.235.23.218
[update]
Just tried also your server:
TomjNorthIdaho
Wed Oct 11, 2017 6:03 pm
[update]
I must be getting old ...
I remember back in the late 70s , I was a tech working on a large multi-state SNA banking computer network and we were screaming fast at 1,200 Baud (Bits per second).
ghostsZA
Mon Oct 23, 2017 11:43 am
Test from Durban, South Africa.
Nick Kett
Wed Oct 25, 2017 6:17 pm
Thoughts on Bandwidth testing and Mikrotik.
Using mikrotik you can get two very different results depending on if you use TCP or UDP... basically:
UDP will give faster result because it ignores any smaller packet loss and just keep stuffing packets down the link until it is full.. Not a very useful test in my opinion.
TCP has a default settings of 20 individual TCP connections, so its like several PCs working together on the same link, good to see what you may expect from say an office connection with several users (combined usage).
For end user testing I like to use TCP with just two Individual TCP connections, this gives a good indication what a single end user will experience, and will give much the same result as a good speedtest.net server.
Another note, TCP bandwidth testing put more strain on the Mikrotik routers/CPU, and can give a false slow result.
TomjNorthIdaho
Wed Oct 25, 2017 7:53 pm
UDP us a fire and forget protocol.
TCP is a fire and wait for an answer that the packet(s) was properly received.
I believe then when a Mikrotik is performing a btest (UDP or TCP), the remote device being tested to is also sending summary packets to the originator of the Mikrotik btest device. The summary packets may include drops, good & bandwidth during the test.
When performing a UDP (receive) btest, look at the "Lost Packets:" count. If it constant changing/increasing number, then your UDP receive btest session is slightly outrunning the throughput capability of the total end-to-end network between both Mikrotik devices. At this point, set your local Mikrotik "Remote Tx Speed:" to a slightly slower speed than what you are actually measuring (about 75 percent) and run the test again. If you still see drops on the UDP receive btest, then try 70 percent. Raise or lower your "Remote Tx Speed:" until you no longer see any errors. This is your clean error-free maximum UDP receive bandwidth rate.
Note: It is normal to see some "Lost Packets:" on the Mikrotik originating the UDP receive btest.
Note: If you see "Lost Packets:" on the Mikrotik originating a UDP send test, or a TCP send-or-receive test, then you may be experiencing some possible network problems.
Note: TCP uses RED (Random Early Detect). When a packet is lost/dropped during transmission and a response was never received, the TCP sending device performs some brief random timeouts and resumes sending TCP traffic at a slightly slower rate. You might want to google "RED -aka- Random Early Detect" and also google "TCP ACK" and google "Delayed ACK".
EDIT: additional notes -
With UDP (fire and forget), it is possible to have more-than-one/several/many UDP packets in transit going through the network at the same time. Example, a UDP packet could be 10 percent through the network and another UDP packet at 50 percent and another UDP packet at 85 percent through the network.
There is no guarantee a UDP packet made it through the network to the remote device.
With TCP (fire and wait for a received ACKnowledgement), (((Not using delayed ACK))), the TCP sending device fires one TCP packet (through the network) then waits for the ACKnowledgement packet before sending the next TCP packet.
There is a guarantee a TCP packet made it through the network to the remote device. If the device sending the TCP packet does not receive a ACKnowledgement packet, then it assumed the packet was lost and may wait a random amount of time and possibly slow down the sending of TCP packets. When all/many ACKnowledgement packets are properly received by the TCP sending device, the TCP sending device may start to increase the speed at which TCP packets are sent.
FYI - most ISP bandwidth governing devices (such as Mikrotik simple-queues for example), start automatically dropping packets when a certain bandwidth is reached. This causes bandwidth to/from an ISP customer to conform to the speed the ISP has the customer set to (RED).
BRMateus2
Fri Oct 27, 2017 12:15 am
Hello, an big thank you for the btest!
Its great having that server for testing purposes, I did some tests for 2 or 3 minutes to verify the %CPU of the MikroTik rules and QoS and optimizations (wasn't necessary), I'm using my first MikroTik bought from a month, RB951G-2HND, an great product! Best of that price here, had to learn a bunch shit of networking LOL.
I am from Brazil and there's the results and traceroute :D, by the way, my internet is 20/4mbps (2500KBps/500KBps) *and this MikroTik is running 1xMIPS@500MHz, the default is 600MHz*, I underclocked it because it has so much power for my own internet that I don't need even the default clock, its for long durability.
1 1 ms <1 ms 1 ms 10.0.8.1
2 <1 ms <1 ms <1 ms 172.16.104.229
3 1 ms <1 ms <1 ms 10.12.0.9
4 1 ms 1 ms 1 ms 10.99.99.45
5 1 ms 1 ms <1 ms 10.5.5.2
6 1 ms 1 ms 1 ms 10.5.10.33
7 13 ms * * 201.16.219.9
8 21 ms 27 ms * 170.84.33.110
9 20 ms 19 ms 19 ms 170.84.34.177
10 19 ms 19 ms 19 ms 168.197.21.141
11 137 ms 137 ms 137 ms 168.197.20.189
12 159 ms 163 ms 159 ms 206.126.236.8
13 199 ms 199 ms 200 ms 65.50.198.85
14 200 ms 199 ms 199 ms 174.127.136.98
15 199 ms 199 ms 199 ms 174.127.141.176
16 200 ms 200 ms 202 ms 174.127.136.97
17 205 ms 208 ms 204 ms 174.127.138.144
18 200 ms 199 ms 200 ms 216.243.28.158
19 209 ms 208 ms 208 ms 66.35.5.246
20 * * * Esgotado o tempo limite do pedido.
https://drive.google.com/open?id=0BxFQ1 ... WpMMmVuQlE
TomjNorthIdaho
Tue Oct 31, 2017 5:11 pm
Its great having that server for testing purposes, I did some tests for 2 or 3 minutes to verify the %CPU of the MikroTik rules and QoS and optimizations (wasn't necessary), I'm using my first MikroTik bought from a month, RB951G-2HND, an great product! Best of that price here, had to learn a bunch **it of networking LOL.
Re under clocking ...
I understand your reason for under clocking. However , in general , faster CPUs tend to offer faster/quicker propagation delay times when going through routers & firewalls & bridges. Even a 1 ms (or .05 ms) per packet delay starts to add up when sustaining full network speeds.
TomjNorthIdaho
Wed Nov 01, 2017 5:30 pm
This is a poll question for Mikrotik admins;
I assume most of you know about the two privately owned btest servers that are available for public btests.
We have had many thank-you(s) and received a lot of praise - and we know they are both often used hundreds of times every day from all over the world.
And for that , we are happy to provide this service.
Now for my questions:
- Who would be interested in an additional set of public accessible Mikrotik tools which use the Mikrotik "Traffic Generator" ?
- Does anybody have some suggestions for how to set one up ?
- Could a public accessible Mikrotik "Traffic Generator" be run on a 100 meg connection ?
- Should it be short period high-traffic testing ?
- Should it be long period slow traffic testing ?
- Who would be interested in also hosting a public accessible Mikrotik "Traffic Generator" site ?
In my opinion, the two current public accessible btest servers work well to help determine peak up/down TDP/TCP bandwidth. However, I am thinking a "Traffic Generator" site should be low & slow sustained traffic which might run for example at 1-to-5 meg over an hour or 24 hours or possibly even a full week. And be able to sustain traffic testing to possibly 100 or more simultaneous testers at the same time.
Any thoughts and/or input and/or consideration for other types of other Mikrotik public accessible test functions/features ???
Chupaka
Fri Nov 03, 2017 9:16 am
You should be very carefull providing Traffic Generator service: no authorization, one can freely generate 'test stream' to faked address, thus providing kind of DoS attack. If you allow testing only to caller's IP address, then he should be NATed by router's address - not everywhere it's possible.
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
saraohyland
Sun Nov 05, 2017 3:42 pm
Brian Higgins,
planetcoop
Fri Dec 22, 2017 6:49 pm
Bumped to 6.41, enjoy.
alaskanjackal
Fri Dec 22, 2017 7:25 pm
I can't get through (to either you or Tom J's, oddly); just unable to connect. It works from another device on a different network I have access to.
I have a new 1gbps symmetrical connection I'd like to test. IP address is 38.131.218.243 -- is it blocked on your end, perhaps?
planetcoop
Fri Dec 22, 2017 9:17 pm
The last test i saw was here: Dec/21/2017 22:26:32 I let you test for 5 minutes and then block for the next 55 minutes. I have added your ip to my always allow list for 72 hours.
alaskanjackal
Sat Dec 23, 2017 6:20 am
Huh, strange...that probably was me; I'm in Central time, so assuming you're reporting that in Pacific time, my last test being at 1:26am here sounds about right. No traffic was passed, though, and all I ever saw was something like this:
[admin@MikroTik] > /tool bandwidth-test 50.235.23.218 user=btest password=btest protocol=tcp
status: can not connect
duration: 0s
rx-current: 0bps
rx-10-second-average: 0bps
rx-total-average: 0bps
random-data: no
direction: receive
Same exact command from a MT on a different network (Suddenlink 1gbps cable):
status: running
duration: 30s
rx-current: 141.8Mbps
rx-10-second-average: 150.0Mbps
rx-total-average: 144.0Mbps
random-data: no
direction: receive
The ISP serving my apartment management company (~5,000 units) uses CGNAT so it's _possible_ someone else has a MT and is running btests and is appearing to be coming from my same IP address (resulting in the 55-minute block), but a) I think the chances of that are unlikely and b) you put me on the always-allow list. The ISP assures me they do not do any filtering--I assume CGNAT doesn't break btest, but clearly something's wrong, here...
Anyway, I had looked forward to seeing what the MT btest could do, but I've done plenty of other speed tests and am finding a consistent ~600mbps down and ~925mbps up from regional speedtest servers here in the midwest, so a btest isn't strictly necessary, just informative.
jarda
Sat Dec 23, 2017 8:59 am
Try udp protocol.
alaskanjackal
Sun Dec 24, 2017 2:56 am
Try udp protocol.
I did try both TCP and UDP on both planetcoop and tomj's...no go.
Not a big deal, though. But I may pop back by when the local MDU ISP that manages the complex turns IPv6 on (they assure me it's soon) to do some IPv6 speed/peering testing. :)
TomjNorthIdaho
Wed Dec 27, 2017 5:32 pm
btest server 207.32.195.2 was just upgraded to 6.41
Ho Ho Ho - hope you had a Merry Christmas and hope you will have a good New Year
jaytcsd
Thu Dec 28, 2017 2:45 am
I was able to do a send test from my cable ISP but my DSL hung. both worked on RX mode.
Now my PC is on my cable router to feed my cloud backup from my NAS, this test helped me cut upload time.
sergejs
Mon Jan 08, 2018 1:35 pm
Thanks for the link!
It was handy to test our 10Gbps connection,
jarda
Mon Jan 08, 2018 7:29 pm
Congratulations. What was the device on the mikrotiks side?
planetcoop
Mon Jan 08, 2018 11:58 pm
With the interface name i will say a Routerboard CCR?
TomjNorthIdaho
Tue Jan 09, 2018 10:28 pm
Which CCR ?
it looks pretty darn fast if this is a btest !!!
planetcoop
Tue Jan 09, 2018 10:37 pm
Which CCR ?
My NAT router pushing all this to btest is a ccr1036-2sfp+ with the same interface type names. Btest is obviously a CHR behind that ccr.
pukkita
Trainer
Trainer
Wed Jan 10, 2018 12:14 pm
The thing is which CCR was used as btest client... has btest been fixed???
planetcoop
Wed Jan 10, 2018 4:57 pm
I would say a CCR1036 or 1072... I may get a 1072 some day but i just picked up a cisco nexus 3064 for a tengb core.
jarda
Wed Jan 10, 2018 7:10 pm
Bingo. That was my concern. :-)
TomjNorthIdaho
Wed Jan 10, 2018 11:28 pm
Ditto - same question "... which CCR was used as btest client ..."
A CHR can do 10-gig with no problems. I have never seen a hardware CCR achieve anywhere near the btest speed as indicated in the graphical image a few posts ago.
planetcoop
Thu Jan 11, 2018 8:01 am
Tom, we will probably need a few samples to keep hosting btest servers... wink wink.
TomjNorthIdaho
Thu Jan 11, 2018 4:00 pm
planetcoop , Ya gotta admit - The amount of bandwidth and server resources we give/donate to the free/open btest project is totally way far beyond insane !!!
Combined together , we donate a 20-Gig physical Internet connection exclusevly for Mikrotik btest admins - and at no charge but with all of the headaches that go with any such high bandwidth projects.
So yea ... If Mikrotik ever has a new routerboard, please consider giving two to planetcoop and two to myself (Tom). ((( Two because one of the two would be dedicated as a 10-gig public btest server and the other would be put into production to front-end our 10-gig business networks.))) ((((( or would you really rather see a 10-gig btest mikrotik behind a 10-gig Internet connected Cisco router ? .)))))
Yo - planetcoop - lol , wadda you say that If we don't get two free mktiks each , that we break the Internet for a few days and run a multi-24-hour-day sustained 10-gig btest between our btest servers. :) - really - yup - serious - well just kidding - or am I ???
planetcoop
Thu Jan 11, 2018 5:11 pm
Tom, lets do it. it would remind me when the brazil based ISP or spoofing was 5+gbps and i only noticed due to interface monitoring... This is my home connection so nothing tested nothing lost.
https://observium.planetcoop.com/graphs ... 484147434/
This is cute, about 140TB in testing per year... :P
jarda
Thu Jan 11, 2018 5:13 pm
I don't think it would be so problematic to kill the communication between you two in that case for anyone in the middle. But anyway, you could do that to see what happens. Maybe none will notice that...
TomjNorthIdaho
Thu Jan 11, 2018 6:48 pm
lol - I suspect a lengthy/extended/non-stop 10-gig btest UDP send and a second btest UDP receive between planetcoop and myself (20-gig sustained total) could very well be noticed and felt at many peer points and router-inter-connects on the Internet between us. I doubt that all of the L2 & L3 hops and peer points between us always have an extra/available/free 10-gig of un-used pipe just sitting around that is not being used during all periods of a 24-hour day. I would expect to possibly see some saturated networks and packet delay and packet loss would occur along the connection paths which could have some effects for everybody in the world having traffic to/from/through any of the servers & networks sharing the btest to btest Internet L2 L3 pathway.
I don't think it would bring the Internet down - but it would be very much noticed at many points if it was a sustained continous flood of traffic
FYI - I must be getting old !!! I remember when the Internet (arpa net) backbone was a 56 k DS0 pipe between the east coast and the west coast. I was on it back then with my 110 baud dial-up modem. DNS was not invented yet , you had to periodically download a host file which contained all of the connected machines.
jarda
Thu Jan 11, 2018 7:01 pm
Only the test will show.
planetcoop
Fri Jan 12, 2018 5:16 pm
sergejs,
If you need more than a five minute test. please let me know and i can whitelist your ip or a block for longer testing.
alaskanjackal
Wed Jan 17, 2018 7:15 am
Try udp protocol.
So it does seem that being behind NAT breaks btest: viewtopic.php?t=12137
I was able to confirm that btest tcp runs on TCP port 2000 and that I could access both TomJ's and planetcoop's servers on TCP port 2000, so a little more digging and inspiration led me to that thread.
Oh well, like I said, I'll try again when they get IPv6 turned on (which they assure me they're working on, though my asking was apparently slightly suspicious as according to them, only people with nefarious intent, like wanting to host/run business or other prohibited services on the residential network, care about IPv6 :roll: ).
biland
Mon Jan 22, 2018 10:17 am
shame, when mikrotik itself has to use another server to test their speed ,, you should offer this service from your side..... at least for europe
saludos from mexico
planetcoop
Tue Jan 23, 2018 6:52 pm
Updated to 6.42rc12 with legit open-vmware-tools.... So nice to suspend or gracefully shutdown a CHR.
TomjNorthIdaho
Sat Jan 27, 2018 5:09 am
Heads up
I think I broke the public btest server I am hosting.
This is the 207.32.195.2 btest server
FYI - I think I mistakenly blew out the P10 licence
I made a request to Mikrotik to see if I may get a (free) chr unlimited license. If they give me one, I will rebuild it with the new license.
I will be fixing it sometime mid next week.
Until then - it is kinda working , but the btest throughputs during a test may be quite slower than you are used to seeing.
iRakic
Sun Jan 28, 2018 8:05 pm
Tom,
I hope they will give you the license. Your Mikrotik BW test server is a very valuable asset for Mikrotik community.
Chupaka
Mon Jan 29, 2018 11:10 am
What's wrong with trial license? :)
planetcoop
Wed Jan 31, 2018 6:29 am
Heads up
Tom,
You can move your license. :)
TomjNorthIdaho
Wed Jan 31, 2018 11:11 pm
Heads up
It's back up and running again.
FYI - when I was activating a different new CHR, I made a mistake and blew out the license on this btest server.
Running on same license P-10 not P-unlimited
TomjNorthIdaho
Thu Feb 01, 2018 4:51 am
planetcoop
May I ask if you would please put the btest server 207.32.195.2 in an always allow list on your btest server ?
I will do the same tomorrow morning
I would like to run a 30 minute continous 1 to 2 gig sustained btest both-directions during my busy times - soon in the near future
thanks
BrianHeston
Fri Feb 02, 2018 7:02 pm
Hey guys, I'm new to the forum and fairly new to the world of Mikrotik devices. I was looking for a way to periodically test my bandwidth and keep a log of it so that I can have a little chat with my ISP at some point. That's when I stumbled upon this thread, which appears to be exactly what I need, but I'm having some problems.
I've tried using Tom's server today with no luck, but I can't figure out why it's not working, or at least why I'm getting 0s for my results.
I was able to use planetcoop's server, but it only shows TX figures, RX just returns 0s. Any ideas as to why or where I should be looking to start troubleshooting?
Thanks,
Brian
planetcoop
Tue Feb 06, 2018 2:36 am
planetcoop
thanks
Tom,
I have just added you. Sorry for the delay.
planetcoop
Tue Feb 06, 2018 2:39 am
BTEST users,
I am working on moving in the next few months and while the new home is built i will not be running btest.planetcoop.com. More to come and info here when available.
If you need specific tests prior to March, please let me know here so i can try to accommodate extra test time. Just a friendly reminder that my connect is a home connection and not related to any business.
Enjoy.
chechito
Thu Feb 15, 2018 2:20 am
planetcoop
thanks
OFF TOPIC
Tom please help me, someway i was testing at 50mbps udp and the test continues sending us data despite y stopped the test
I tried with firewall drop and reject rules ant traffic is is still incoming to my router
i rebooted the router and traffic still incoming
chechito
Thu Feb 15, 2018 2:24 am
forget it
traffic has stopped
THX again for the test servers very usefull
TomjNorthIdaho
Thu Feb 15, 2018 4:10 am
I have experience it myself many many times ...
when doing a btest (remote client to btest server -and/or/ btest server to remote clinet) , where you stop the btest and it continues no matter what.
I found that when this happens, the quickest fix is to just reboot one of the devices.
I suspect this is a un-documented-feature (aka bug). I've seen this on several versions now ...
jarda
Thu Feb 15, 2018 12:48 pm
I also suffer from this time to time. Unfortunately it was not so much painful for me to report a bug to mikrotik. Would you do so?
TomjNorthIdaho
Thu Feb 15, 2018 4:06 pm
Ya know , it would be kinda nice to see btest updated with some extra features
New features I would like to see include:
(Using Winbox to run btest)
- run for option (time and or amount of traffic to pass)
- Random simulator (all random at the same time - speed up - speed down - tcp - udp - packet size - pause - propagation delay). In other words , let btest really walk a test through it's paces. With the random function - there needs to be a maximum bandwidth setting to not exceed
- An auto ramp-up speed setting. A new function to test how fast the network is without any errors (zero packet loss) & how fast the network is maximum throughput while experiencing some normal packet loss
- In all cases have btest auto stop/quit running at some time. The only exception is if a run for option was specified
-- Reporting results - much much better results !!! something like an optional 100 line report indicating percent loss from 0 percent and bandwidth up/down tcp/udp and repeat for 1 percent loss & 2 percent loss up through 100 percent loss. And on the report indicate the acceptable effective useable speed of the network.
- Have the btest server better log what it is doing !!!!!!!!!!!
admin for 207.32.195.2 btest server :)
Funny lol - FYI -
Back around 1990, I wrote up an email/smtp type of btest server. You email it a command line in the body of the email and the server would start sending massive amounts of email back to you until you email the turn-off command to stop the test. It was a great tool for lighting up the network with massive massive sustained traffic for testing. Well - that is .. until I was hacked and somebody stole my /etc/passwd file and used it to send political spam email to my ISP customers !!! The person that stole my /etc/passwd file was running for county commissioner. Well --- you can guess what happened when he sent an email from his ISP to my special diagnostic email address. Lets just say he turned on the test on a Friday and I found out the test was running Monday morning when I came into the office. The system was full flat line on non-stop emails for days. This event got me (yes me) on the front page of the "Wall Street Journal" and on every local news tv/newspaper it was headlines. The person that triggered the test said "It was like walking down the street and inserting flyers into mail boxes - then opening a mail box with a nuclear bomb rigged to go off!". I told the news agencies he committed a felony crime and stole private data and by his criminal actions is the person who crashed 2 ISPs here in town over the weekend. He was later un-successful in his run for county commissioner.
Anyways - a note to chechito , I know what it is like to start a bandwidth test and not have it stop :)
TomjNorthIdaho
Re: Public-Mikrotik-Bandwidth-Test-Server(s)
Thu Feb 15, 2018 6:06 pm
Thinking about my just previous post containing ..."It was like walking down the street and inserting flyers into mail boxes - then opening a mail box with a nuclear bomb rigged to go off!"...
I guess the moral of my story is:
Don't start something you can't stop
planetcoop
Tue Feb 20, 2018 6:53 am
Team,
Sorry to say, as i had posted before. I will be moving soon and i found out today that i will not be able to move my current service. btest.planetcoop.com will be offline in the first week of march. If you have any special requests, please let me know.
Thank you for allowing me to host the btest server and participating in the community. If i get better news int the future, i will bring it back.
alaskanjackal
Tue Feb 20, 2018 8:40 am
I've always been curious--how on earth do you have a 10G connection at home?! :O
Or at least that's what TomJ's post #1 in this thread implies. IIRC somewhere in this thread it was speculated that you have Comcast Gigabit Pro (i.e. 2-3Gbps), which would make more sense (traceroutes to you do indicate you're on Comcast). Tom's may be on a real 10G connection, since he's an ISP...
Unfortunately with the way that my ISP implements carrier-grade NAT, I never was able to test my speed to you from here. (I was hoping that they'd get IPv6 implemented this winter so I could try.) Ah, well. Enjoy your move, and I hope there's at least some kind of decent Internet service at your new place.
planetcoop
Tue Feb 20, 2018 4:12 pm
Yes, i am on comcast. Yes, it was home service. The sad news is that the new home is just too far away from the network for the fiber build out. As i had said, if anything changes, i will let you guys know. As to how it is 10g, well. That will be a great story for another day.
In these final few weeks, i have removed all restrictions for testing. The 10g link is wide open for testing.
BrianHeston
Tue Feb 20, 2018 9:05 pm
I'm still not seeing useful results. Can anyone help?
MikroTik
feb/20/2018 10:56:32
Result :
TX speed 0.576 Mbps/s
RX speed 0.0 Mbps/s
TX total average 0.625 Mbps/s
RX total average 0.0 Mbps/s
Thanks,
Brian
TomjNorthIdaho
Wed Feb 21, 2018 2:17 am
MikroTik
Result :
RX speed 0.0 Mbps/s
Thanks,
Brian
Brian,
Q1 - What is the IP address of your Mikrotik ?
Q2 - Is your Mikrotik behind another firewall / and or behing another wireless router ?
Q3 - Is the WAN IP address of your Mikrotik a live Internet IP address ?
Q4 - When testing to my btest server 207.32.195.2 , have you tried waiting for 1 hour and a few minutes prior to re-trying the btest ?
Q5 - Do you have some Mikrotik firewalls running on your Mikrotik ?
Re Q1 & Q2 & Q3 , I want to know your Mikrotik is the last device you go through to your ISP to get out to the Internet.
Re Q4 , Continued test and repeated tests are auto blocked for 1 hour , then auto released
Re Q5 , If you are running btest through a firewall , you might be only able to send and not receive. To receive, your firewall has to be turned off -or- your firewalls need some port forwards. When you receive a btest, the remote btest server will send to some TCP and/or UDP ports on your Mikrotik. If you have firewalls without port forwards, then your firewalls will block/prevent an Internet connection from the btest server to your Mikrotik.
If you have no firewalls & your Mikrotik is the last device connected to your ISP & you have waited 1-hour and a few minutes & it still will not receive btest , then there is a possiblility your ISP might have a firewall on your Internet connection. You can test this by setting up a web server & port forward port 80 to someting and see if you can http://you-ip-address and see if it works.
You can check/look/see your firewalls by looking at your Mikrotik IP firewall settings. You can make a backup and then delete all firewall rules and test it , then restore the config to put your Mikrotik back the way is was prior to purging the firewall rules.
FYI - the 207.32.195.2 btest server has no firewalls (other than the auto block after an IP has exceedeed the alloted time for btest - then after an hour it will auto purge. If you try withing the hour , the timeout to auto purge starts at 1 hour again.
North Idaho Tom Jones
BrianHeston
Fri Feb 23, 2018 11:31 pm
MikroTik
Result :
RX speed 0.0 Mbps/s
Thanks,
Brian
Brian,
Tom, thank you for your very detailed response. I see what you are driving at and I'm guessing that my topology is the issue.
My Mikrotik sits behind my ISPs DSL modem/router. Within said device, my Mikrotik is listed as a DMZ device, but it does not have its own public IP. As such, connections are theoretically not filtered in any way, but they are obviously still NATed. I'm guessing that this is why when I use planetcoop's server, I can't get RX results, but I can get TX results. However, it still doesn't explain why I get no results at all from your server.
Here are the answers to your questions:
Q1 - What is the IP address of your Mikrotik ? 192.168.0.181
Q2 - Is your Mikrotik behind another firewall / and or behing another wireless router ? It sits behind my ISP provided DSL modem / router
Q3 - Is the WAN IP address of your Mikrotik a live Internet IP address ? No
Q4 - When testing to my btest server 207.32.195.2 , have you tried waiting for 1 hour and a few minutes prior to re-trying the btest ? Yes
Q5 - Do you have some Mikrotik firewalls running on your Mikrotik ? I do have some rules running on my Mikrotik, but as stated above, there is no external firewall between the Mikrotik and the internet. Are there rules required on the Mikrotik to open the ports for the testing? What TCP / UDP ports are used?
Again, I truly appreciate the detailed response.
Thanks,
Brian
TomjNorthIdaho
Sat Feb 24, 2018 12:32 am
MikroTik
Result :
RX speed 0.0 Mbps/s
Thanks,
Brian
Brian,
Thanks,
Brian
Re - your Mikrotik behind your ISPs router
I assume your Mikrotik gateways to your ISPs router Ip address of 192.168.0.1 (The inside ethernet LAN connection to your Mikrotik 192.168.0.181
I am also guessing , that that same ISP router at your home just might have a outside live-IP-address. Thus it is natting your network to the ISPs router at your location.
Sometimes - it may be worth checking out - ... The ISP router at your location might have a user-login account so that you can configure the ISP's LAN ethernet & wireless connection to you.
If so, it might be simple to login into the ISP router at your location and disable NAT and simply turn the ISP's router at your location into a bridge (IP passthrough). If so , then your Mikrotik just might get a live-internet-IP address instead. --- resulting in something your probably want.
AND/OR ....
There might be a DMZ/port forward settings in your ISP's router so that you can port-forward some ports to your Mikrotik.
If this is possible, then you could port forward the following ports to your Mikrotik
ssh
telnet
remote desktop
VPN
FTP
http
https
winbox
btest ports (I think this is a port range)
Then your Mikrotik could then use some ports for itself (winbox & btest ports) and then port-forward the other remaining ports to another computer (a linux web server for example)
modsx
Wed Feb 28, 2018 9:27 am
Hi!
Many thanks for the courage and charity.
If someone has the opportunity to do the same - welcome!
I tested from Latvia (EU).
This is not the best way to test from EU, because both servers are located in the USA.
The first server is 50 hops (devices between) second 14. With both of them there is no objective measure, sometimes connecting, sometimes not, the second works better.
TomjNorthIdaho
Wed Feb 28, 2018 5:48 pm
Hi!
The 207.32.195.2 btest server (the one I operate), might be a little problematic right now. I am turning up some BGP circuits and testing various loads on my routed networks right now.
TomjNorthIdaho
Wed Feb 28, 2018 9:28 pm
Heads-Up ... FYI
info...
The 207.32.195.2 btest server for public Mikrotik admin use has been on-line since January 2016
During the last two years, I estimate it has performed somewhere between 1/4 million to 2 million btest(s).
The current average systained bandwidth is about 30 meg , which also includes those btest(s) that peak over 3-Gig and sustain 512-Meg and the btest(s) that run less than 1-Meg.
Todays btest server changes...
Because my ISP business is growing and always adding new high-speed Internet customers (3-Meg to 512-Meg accounts), I now need to reduce the amount of bandwidth I have been donating to the 207.32.195.2 btest project , so that I can keep a reserve burstable bandwidth capacity for all my customers , and not saturate my up-stream Internet feeds.
The 207.32.195.2 bandwidth limiters (simple queue) are now set at the following:
Target: ether1 (the CHR ether1 interface with IP address 207.32.195.2)
(Simple Queue , Target Upload & Target Download)
Max Limit: 105M
Burst Limit: 1250M
Burst Threshold: 50M
Burst Time: 500
The simple queue operates this way:
#1; allow sustained btest of 105-Meg
#2; If the recent bandwidth average has been below 50-Meg for (Burst-Time seconds), then allow up to 1.25-Gig (untill this this #2 line no longer is valid).
Thus , if nobody has very recently (or currently) used the btest server, then you should be able to btest up to 1.25-Gig for a short duration then auto-fall back down to 105-Meg.
If more than one person is using the 207.32.195.2 btest server at the same time, then the bandwidth limitations apply to all btesters combined. Thus if 10 users are using it at the same time, your results might be 1/10th the results you might of been expecting.
Also - keep in mind that the btest server often places a block on your IP which makes you wait for a period of time until you can continue btesting. This is done to help prevent the btest campers to start a btest and never stop their btest.
I hope to keep the 207.32.195.2 btest server on-line for many more years to come (providing I always have available bandwidth).
I/we would welcome anybody to also place their one btest server on-line for public access.
It could be a max of 10 meg or 100 meg or 1-Gig or even a 10-Gig. I am sure the community would be thankfull for any additional btest servers (especially in different locations throughout the world).
planetcoop
Fri Mar 02, 2018 3:42 am
Heads-Up ... FYI
info...
Max Limit: 105M
Burst Limit: 1250M
Burst Time: 500
I have managed to keep btest.planetcoop.com online yet. During my new home move, i have made arrangements to keep it online. I expect to take my btest.planetcoop.com down around June first now. if i can keep it online in any capacity, I will let you know.
Thank you,
Planetcoop
lrl
Sun Mar 04, 2018 11:06 am
Thanks for the resource! I can't tell you how many times it's been very useful for us!
We're currently building out a new 10G datacenter in our head-end and once we have the new ESXi cluster going I'd like to host a btest server. We'll have plenty of upload available and it's not going to be used.
TomjNorthIdaho
Thu Mar 22, 2018 8:56 pm
btest server change effective immediately , aka - right now (March 22, 2018)
btest server 207.32.195.2 was moved to 207.32.194.24
Same server , same settings .. Just IP renumbered now to 207.32.194.24
btest user:btest
btest password: btest
FYI: My business is growing. We needed the entire 207.32.195.0/24 Class C netblock for some new networks we are building. Normally , I would of given a prior notice but something came up today and I had to rush a re-number on this btest server.
planetcoop
Mon Mar 26, 2018 8:28 pm
The planetcoop btest is back up. it was down last week due to an unexpected server hardware failure. All good now. Enjoy. Also bumped to latest RC. :)
billjellis
Tue May 08, 2018 1:43 am
Thanks for this works great,
Bill
TomjNorthIdaho
Sat May 19, 2018 12:18 am
Heads up , on the btest server 207.32.194.24 server , I just added some IP services Available-From settings.
I think the btest server is still running for everybody on the internet - however , for the IP services such as telnet , ssh , winbox , www , ftp connections , they are now blocked (except by my networks).
If I am correct - btest uses ports from 2000 on up , which is not one of the Mikrotik - IP - Services listed services.
If btest stops working , please let me know.
EDIT - added the note below:
Whoever is winbox/dude 213.57.88.215 , I am seeing a repeated connection every 30 seconds (every 30 seconds !)
Stop it , or explain it or I will have to block your network.
Or ... I may assume you are a potential hacker trying to break into my Mikrotik (possibly trying to use a recent vulnerability in ROS which Mikrotik has informed us about)
14:31:38 warning denied winbox/dude connect from 213.57.88.215
14:32:08 warning denied winbox/dude connect from 213.57.88.215
14:32:38 warning denied winbox/dude connect from 213.57.88.215
14:33:08 warning denied winbox/dude connect from 213.57.88.215
14:33:38 warning denied winbox/dude connect from 213.57.88.215
TomjNorthIdaho
Fri Jun 08, 2018 10:13 pm
Recently , I was asked for a copy of the configuration I use on the 207.32.194.24 btest server.
Below is an export of the configuration. Note - the addres-list part of the export configuration was originally created by planetcoop who runs the other public btest server.
So for Mark Dyer and everybody else interested :
[admin@207-32-194-24-CHR-P10] /system package> print
Flags: X - disabled
# NAME VERSION SCHEDULED
0 X dude 6.42.3
1 routeros-x86 6.42.3
2 system 6.42.3
3 X ipv6 6.42.3
4 X ups 6.42.3
5 X wireless 6.42.3
6 X hotspot 6.42.3
7 X dhcp 6.42.3
8 X mpls 6.42.3
9 routing 6.42.3
10 X ppp 6.42.3
11 security 6.42.3
12 advanced-tools 6.42.3
[admin@207-32-194-24-CHR-P10] > export
# jun/08/2018 11:33:54 by RouterOS 6.42.3
# software id =
set [ find default-name=ether1 ] loop-protect=off
/queue simple
add burst-limit=1250M/0 burst-threshold=50M/0 burst-time=8m20s/0s max-limit=105M/0 name=Ether1-A-From-Internet target=ether1
add burst-limit=0/1250M burst-threshold=0/50M burst-time=0s/8m20s max-limit=0/105M name=Ether1-B-To-Internet target=ether1
/snmp community
###### If you use SNMP - then set your SNMP community settings here
/user group
add name=btest policy=test,winbox,romon,tikapp,!local,!telnet,!ssh,!ftp,!reboot,!read,!write,!policy,!password,!web,!sniff,!sensitive,!api,!dude
/user
add comment="system default user" group=full name=admin
add group=btest name=btest
#### set your admin password
#### set the password for the btest user to btest
add address=207.32.194.24/26 interface=ether1 network=207.32.194.0
####### You need to change the above IP address for your network ether1 Internet connection
###### You need to insert your DNS servers here
/ip firewall address-list
add address=z.b.c.d/24 comment=00-00-Permanently-Allow-These-IP-Addresses list=tester
### You need to modify and add-repeat the aboce line for your IPs in your networks that you want to "Permanently-Allow"
add address=10.0.0.0/8 comment=01-06-Permanently-BLOCK-These-IP-Addresses list=blocklist
add address=172.16.0.0/12 comment=01-07-Permanently-BLOCK-These-IP-Addresses list=blocklist
add address=192.168.0.0/16 comment=01-08-Permanently-BLOCK-These-IP-Addresses list=blocklist
add address=138.117.109.222 list=blocklist
add address=185.34.121.32 list=blocklist
add address=162.253.51.242 comment=00-RS-BGP-Permanently-Allow-These-IP-Addresses list=tester
add address=50.235.23.218 comment=00-2btest-Permanently-Allow-These-IP-Addresses list=tester
add address=66.35.7.130 comment=00-RS-BGP-Permanently-Allow-These-IP-Addresses list=tester
add address=207.32.194.6 comment=00-00-Permanently-Allow-These-IP-Addresses list=tester
add address=207.32.194.26 comment=00-00-Permanently-Allow-These-IP-Addresses list=tester
/ip firewall raw
add action=accept chain=prerouting comment="testers accepted" src-address-list=tester
add action=drop chain=prerouting comment="previous testers drop" src-address-list=previous
add action=add-src-to-address-list address-list=tester address-list-timeout=2m chain=prerouting comment="add to tester" dst-port=2000-2100 protocol=tcp
add action=add-src-to-address-list address-list=tester address-list-timeout=2m chain=prerouting comment="add to tester" dst-port=2000-2100 protocol=udp
add action=add-src-to-address-list address-list=previous address-list-timeout=15m chain=prerouting comment="add to previous" dst-port=2000-2100 log=yes protocol=tcp
add action=add-src-to-address-list address-list=previous address-list-timeout=15m chain=prerouting comment="add to previous" dst-port=2000-2100 log=yes protocol=udp
add distance=1 gateway=207.32.194.17
/ip service
set telnet address=192.168.0.0/16,10.0.0.0/8,172.16.0.0/12,a.b.c.d/24,a.b.c.e/24
set ftp address=192.168.0.0/16,10.0.0.0/8,172.16.0.0/12,a.b.c.d/24,a.b.c.e/24
set www address=192.168.0.0/16,10.0.0.0/8,172.16.0.0/12,a.b.c.d/24,a.b.c.e/24
set ssh address=192.168.0.0/16,10.0.0.0/8,172.16.0.0/12,a.b.c.d/24,a.b.c.e/24
set www-ssl address=192.168.0.0/16,10.0.0.0/8,172.16.0.0/12,a.b.c.d/24,a.b.c.e/24
set api address=192.168.0.0/16,10.0.0.0/8,172.16.0.0/12,a.b.c.d/24,a.b.c.e/24
set winbox address=192.168.0.0/16,10.0.0.0/8,172.16.0.0/12,a.b.c.d/24,a.b.c.e/24
set api-ssl address=192.168.0.0/16,10.0.0.0/8,172.16.0.0/12,a.b.c.d/24,a.b.c.e/24
##### Note - you need to change/modify the above ip-service a.b.c.d/24,a.b.c.e/24 so that a.b.c.d/24 and a.b.c.e/24 IP blocks are actually your IP networks
/snmp
set contact=207-32-194-24-CHR-P10 enabled=yes location=207-32-194-24-CHR-P10
### set the /snmp for your snmp information
/system clock
set time-zone-autodetect=no time-zone-name=America/Los_Angeles
##### set your system clock time-zone
/system hardware
set multi-cpu=no
##### Although this is a CHR running on a VmWare ESXi server , I only allocate 1 CPU core for me btest server to run with
/system identity
set name=207-32-194-24-CHR-P10
#### set your system identity
/system ntp client
##### Set your ntp client settings here
/system package update
set channel=release-candidate
/tool bandwidth-server
set max-sessions=500
/tool graphing interface
add
/tool netwatch
### I might suggest putting some of your gateway and upstream router IP address here
If I missed anything - please let me know
TomjNorthIdaho
Re: Public-Mikrotik-Bandwidth-Test-Server(s) ROS 6.42.4
Wed Jun 20, 2018 4:07 am
June 19, 2018
Heads Up - FYI - I just updated the 207.32.194.24 btest server to version 6.42.4
If you have any problems with btest , please drop a posting here
TomjNorthIdaho
Thu Jun 28, 2018 6:48 pm
June 26, 2018
Heads Up - FYI - I just updated the 207.32.194.24 btest server to version 6.42.5
shujanster
Sat Jul 14, 2018 9:27 pm
June 26, 2018
Show me Can't Connect. i use 6.40.8. Thanks.
TomjNorthIdaho
Fri Jul 20, 2018 9:24 pm
A typical Internet speedtest ( FYI - We use Mikrotik CHR routers )
Killian
Sat Jul 28, 2018 10:34 am
Firstly thanks to Tom for providing this Service
I dunno if you guys can help me out, we have a 360Mb connection here based in Europe. I believe that we are having a few issues on the network where as we don't seem to be able to max out the connection from normal internet use, I am unsure if the issue is with the tcp bandwidth test having so many hops to Toms server or is the issue with our provider, before I call them out i would like a bit of reassurance that i am correct.
When testing to Tom's server I can pull the full 360Mb no problem at all but by TCP I can only pull ~200Mb across the link (Am taking the figures from the Ethernet Port "Combo 1")
UDP Test Result
https://imgur.com/a/cKCv71U
TCP Test Result
https://imgur.com/JFKziaW
Chupaka
Mon Jul 30, 2018 10:51 am
Check CPU load (per-CPU)
Killian
Tue Jul 31, 2018 12:51 am
Thanks Chupaka, I have multi-queue-ethernet-default enabled for the interfaces combo1 and ether1-local "mq piffo" 100 packets.
CPU's included in screenshots below
UDP test
https://imgur.com/h84JwYJ
TCP Test
https://imgur.com/4LcP4k1
planetcoop
Wed Aug 15, 2018 6:14 pm
Sorry to say, btest.planetcoop.com is no longer available. I have completed my move and will be connecting the fiber service ASAP. It has been fun. If i am able to get the service at my new location i will bring it back up.
TomjNorthIdaho
Wed Aug 15, 2018 7:07 pm
It would be nice of others offered free public accessible btest servers in other locations around the world.
Although 1+ gig bteset servers are nice, I suspect that even some 100 meg btest servers would be very much welcome.
Any body interested in volinterring some bandwidth for some btest servers ?
(my btest server is 207.32.194.24 btest/btest)
angboontiong
Mon Aug 20, 2018 1:29 pm
i just test, it run for awhile and now when i ping it become request time out..
TomjNorthIdaho
Tue Aug 21, 2018 6:04 pm
I have a firewall rule in the btest server. Connections to the btest server will eventually get blocked. Then the remote admin will need to wait for a timer to expire. After the btest FW timer expires, then the remote btest user can test again. Then is to help prevent abuse and/or excessive use - thus freeing up bandwidth for other btesters.
macsrwe
Forum Veteran
Forum Veteran
Thu Aug 23, 2018 6:33 pm
Can't get connected to this any longer. Haven't used it previously, so it's not a hog timeout. Last time I used it, you had a different name and password, so it's been some time. Now I just get a long "connecting" and a "can't connect."
TomjNorthIdaho
macsrwe re: Can't get connected to this any longer.
Thu Aug 23, 2018 10:09 pm
What IP address are you testing from ? I can look at the fw logs and see if your IP address shows up in there.
North Idaho Tom Jones (207.32.194.24 btest admin)
TomjNorthIdaho
Thu Aug 23, 2018 10:15 pm
FYI - btest bandwidth usage
About an hour ago , I rebooted the 207.32.194.24 btest server
Now an hour later after I rebooted it , it has sent over 10+ Gib Bytes and received 3+ Gib Bytes in btest(s).
lol - take that 1 hour of time and stretch it out over 3 years , the btest(s) send -and- receive Bytes really start to add up to one heck of alot of Bytes.
macsrwe
Forum Veteran
Forum Veteran
Re: macsrwe re: Can't get connected to this any longer.
Thu Aug 23, 2018 10:16 pm
198....
TomjNorthIdaho
Thu Aug 23, 2018 10:35 pm
198.233.88.218
I do see it is trying to connect - but no btest is starting ...
Hmmm , Try updating the ROS version of your Mikrotik to the latest. I am currently running 6.42.7
I think you might need to be on the same version
After you upgrade - give it a try again and let me know
North idaho Tom Jones
macsrwe
Forum Veteran
Forum Veteran
Thu Aug 23, 2018 11:37 pm
I upgraded a non-critical unit on my network and it worked. Then I tried a non-upgraded router and it also worked. Then I retried it from my edge router where it failed this morning, and this time it worked.
I blame Russians.
Thanks for your help.
planetcoop
Thu Sep 06, 2018 12:05 am
Tom,
I was averaging 30TB total monthly in/out traffic with it on the 10gbps link. Crazy busy.
TomjNorthIdaho
Thu Sep 06, 2018 1:38 am
Tom,
Same monthly averages here - 20 to 60 TB every month on the 207.32.194.24 btest server
Temorizador
Tue Sep 11, 2018 3:31 am
Gracias por el servicio ofrecido ,es muy útil para probar los mikrotiks , para ver su poder y si el ISP ofrece realmente lo que venden tan caro :-) .
saludos
Thanks for the service offered, it is very useful for testing the mikrotiks, to see their power and if the ISP really offers what they sell so expensive :-).
regards
TomjNorthIdaho
Tue Sep 11, 2018 5:56 pm
saludos
regards
TomjNorthIdaho
Tue Sep 11, 2018 6:02 pm
The public access btest server 207.32.194.24 was just now updated to 6.43
tabate47
Fri Sep 14, 2018 12:42 am
We've used the public server for a long time with no issues. For the last few days we are unable to connect. We use tcp. We are getting either connect which just hangs, or Device incompatible . We tried to set the connect count to 1 and it immediately disconnects. Did something change recently? We are on the latest bug fix release.
TomjNorthIdaho
Fri Sep 14, 2018 4:40 am
I might be wrong here - but I believe I recently read that a Mikrotik btest client (one of your Mikrotiks) now needs to be the same ROS version at the Mikrotik btest server (if passwords are used).
My 207.32.194.24 btest server uses user=btest and password=btest , thus I suspect the client Mikrotik needs to be the same ROS version.
I am currently using ROS version 6.43
So - as a test , try upgrading a client btest Mikrotik to ROS version 6.43 and see if it works.
Note 1: A couple of days ago , I had somebody pm me about their btest not running to my btest server , they then upgraded to 6.43 and the btest worked.
Note 2: I think I also read that if there is no btest password configured on the btest server (or authentication not enabled "don't remember exactly" ) that any cleint of any ROS version can then perform a btest
Please try upgrading a client btest Mikrotik and test it - and - please post her to let me know if I am correct about the matching ROS versions if btest passwords are used.
Also of note - a possible work-around with different ROS versions might be for me to create a second btest user on my btest server that does not have a password. I will have to look into what security issues that opens up if not configured correctly on my btest server.
tabate47
Fri Sep 14, 2018 5:24 am
Tom,
You are correct. Here is the changelog:
MAJOR CHANGES IN v6.43:
!) api - changed authentication process (https://wiki.mikrotik.com/wiki/Manual:API#Initial_login);
!) backup - do not encrypt backup file unless password is provided;
!) btest - requires at least v6.43 Bandwidth Test client when connecting to v6.43 or later version server except when authentication is not required;
!) cloud - added IPv6 support;
!) cloud - added support for licensed CHR instances (including trial);
!) cloud - reworked "/ip cloud ddns-enabled" implementation (suggested to disable service and re-enable after installation process);
!) radius - use MS-CHAPv2 for "login" service authentication;
!) romon - require at least v6.43 RoMON agent when connecting to v6.43 or later RoMON client device;
!) webfig - improved authentication process;
!) winbox - improved authentication process excluding man-in-the-middle possibility;
!) winbox - minimal required version is v3.15;
Would you be able to create another user? It doesn't seem like it would be an issue because everyone knows the password anyway. If you can't, then everyone would need to be on your ros version which won't work for a lot of setups. If you could, that would be great. Thanks for all the help.
jarda
Fri Sep 14, 2018 1:35 pm
Maybe the authentication requirement on the public btest servers should be switched off. What is its meaning when the user and password is publicly known?
TomjNorthIdaho
Fri Sep 14, 2018 6:09 pm
Wow - somebody has a fast Internet connection :)
This image is from my 207.32.194.24 btest server just a few minutes ago.
TomjNorthIdaho
Tue Sep 18, 2018 5:51 pm
This morning I upgraded the 207.32.194.24 btest server to 6.43.1
HMHackMaster
Tue Sep 25, 2018 4:37 pm
Thanks for running this bandwidth test server by the way!
I was able to get a 1.5Gbit test from my newly acquired 10G line but I wasn't able to grab a screenshot of it in time. Just waiting patiently for the rate limiting to settle down so I can try again.
It's hard nowadays to validate that ISPs actually deliver on what they promise, so I really appreciate you running this for free!
[If ya wanna break some graphs, I would love to schedule a time and see what happens without a rate limit! :) ]
TomjNorthIdaho
Tue Sep 25, 2018 5:55 pm
I just upgraded the 207.32.194.24 btest server to : Ver 6.43.2
As always , you may want to consider upgrading your Mikrotik also to 6.43.2 and then run a btest
780user
Mon Oct 01, 2018 11:07 pm
Thanks a lot for hosting and maintaning this service!
Any idea what could be wrong? Tried connecting the last 3-4 days..
jarda
Tue Oct 02, 2018 12:02 pm
Could be beneficial to someone if I would open the 100/100 Mbit/s public btest server in Europe? Just asking in advance...
TomjNorthIdaho
Tue Oct 02, 2018 6:20 pm
I know a btest server in Europe would be used by many :)
jarda
Tue Oct 02, 2018 8:27 pm
For sure, but the 100mbits limitation might be problematic. Also I couldn't guarantee such speed to be achievable always, which could lead to lower measurements. Therefore the question if such thing makes sense.
TomjNorthIdaho
Wed Oct 03, 2018 4:34 am
On the forum , your server could be listed as the following limitations (what ever you want worded)
- no guarantee on bandwidth availablility for btest (ing)
- no guarantee on low/hi measurements
EDIT: Below is an export of my btest config. It includes a simple-queue which can be changed for your limits:
set [ find default-name=ether1 ] advertise=1000M-full loop-protect=off
/queue simple
/user group
add address=207.32.193.0/24 comment=00-05-Permanently-Allow-These-IP-Addresses list=tester
/ip firewall raw
/ip service
set telnet address=192.168.0.0/16,10.0.0.0/8,172.16.0.0/12,207.32.193.0/24
set ftp address=192.168.0.0/16,10.0.0.0/8,172.16.0.0/12,207.32.193.0/24
set www address=192.168.0.0/16,10.0.0.0/8,172.16.0.0/12,207.32.193.0/24
set ssh address=192.168.0.0/16,10.0.0.0/8,172.16.0.0/12,207.32.193.0/24
set www-ssl address=192.168.0.0/16,10.0.0.0/8,172.16.0.0/12,207.32.193.0/24
set api address=192.168.0.0/16,10.0.0.0/8,172.16.0.0/12,207.32.193.0/24
set winbox address=192.168.0.0/16,10.0.0.0/8,172.16.0.0/12,207.32.193.0/24
set api-ssl address=192.168.0.0/16,10.0.0.0/8,172.16.0.0/12,207.32.193.0/24
add
jarda
Wed Oct 03, 2018 1:07 pm
Thanks Tom, I am still far from the moment I could use it, I need to see if there is any demand first.
Chupaka
Wed Oct 03, 2018 1:28 pm
Why not just start from opening it in 'demo' mode and look at BTest traffic? :)
jarda
Wed Oct 03, 2018 1:34 pm
Because it requires some effort and costs.
TomjNorthIdaho
Wed Oct 03, 2018 3:38 pm
jarda , if you decide to open up a btest server …
--- You will become rich
--- Women will flock around you for your attention
--- You will win every game at casinos and lottery
--- Your network will run faster
--- You will have lots of free time
----------or----------
--- You will go broke paying for the additional bandwidth of a btest server
--- Other that your wife , nobody knows who you are
--- You will still be a looser at everything you do
--- Your network will be slower because it now experiences high bandwidth btest loads
--- You will be busy answering questions (via this forum, email, facebook and PM) about why they can't btest to you
--- Somewhere between the maximums there is a medium
lol
Chupaka
Wed Oct 03, 2018 4:21 pm
Huh, it's just about me :)
TomjNorthIdaho
Wed Oct 03, 2018 5:46 pm
lol :lol:
TomjNorthIdaho
Wed Oct 03, 2018 5:53 pm
Anybody remember my original post that eventually led to a public btest server ?
I made a suggestion about everybody participating in a btest day for everybody to btest to/from to measure bandwidth around the world. Then somebody made a post stating
"The day the Internet broke".
Anyways , I believe all of us Mikrotik admins would welcome any public access btest servers of any speeds/capabilities.
jarda
Wed Oct 03, 2018 8:42 pm
Tom, it might be even much worse anyway.
The public btest server could be one of the side effects of other of my ideas, and it might take a while, but I believe I will open it finally.
datispro
Fri Oct 12, 2018 6:49 pm
i need bandwidth test server from Turkey location . please help me is is there any server in turkey.
We thinks Mikrotik is the best solution for network Jobs.
Mikrotik Course - mikrotik
TomjNorthIdaho
Fri Oct 12, 2018 11:01 pm
As for public btest access and posted here in this forum about any Mikrotik btest server(s) , My 207.32.194.24 btest server is the only one I know of at this time.
dadoremix
Sat Oct 27, 2018 7:10 pm
@North Idaho Tom Jones
btest dead ?
Khuseyn
Sat Oct 27, 2018 10:28 pm
Thanks for running this bandwidth test server :!: :!: :!:
Please tell me how to create a script to record the test results to the log or send to the mail?
Khuseyn
Sat Oct 27, 2018 10:32 pm
after what time can repeat testing?
I think re-check for a short time is blocked.
zakynthoswifi
Sun Nov 25, 2018 12:51 am
Hi tom,
I'm getting after a speedtest on your server several incoming attempts from port scans from your ip. please check your router... currently I have blocked your ip. Thanks for this server
Ilias Theodosis
Network & Security Engineer
Cisco CCNA,CCNP,CCIE
Network Solutions Ltd.
Zakynthos, Greece
TomjNorthIdaho
Mon Nov 26, 2018 8:20 pm
Hi tom,
hmmm, My btest server should be clean and normal. I just rebooted it.
However , I have sometimes seen a stuck btest. Example - a remote btest is started and the remote Mikrotik device looses connectivity to the Internet which a few times has resulted in the btest server still running. This is rare when it happens. The solution is normally to reboot the btest server or the btest client then the problem stops. This used to happen only when under loads greater than 2-gig sustained - however I have not seen btest get stuck in at least 1/2 a year now...
Of note - I have mostly seen stuck btest(s) on x86 Mikrotiks or slower physical Mikrotiks devices running btest. I have never seen a CHR to CHR stuck btest with vmxnet3 10-gig network interfaces - but in the past , I have seen it a few times with just about everything else (other than a CHR) when a btest is saturating a link.
brahma
Tue Nov 27, 2018 7:58 am
i made a btest server ip-103.80.55.2 with no user and password . take a test and enjoj
TomjNorthIdaho
Tue Nov 27, 2018 5:52 pm
Nice :)
I just ran some btest(s) from my 207.32.194.24 btest server to your 103.80.55.2 btest server.
UDP send test and UDP receive btest each way comes close to 150 meg (130 to 148 meg).
TCP send test and TCP receive test each btest at around 80 meg.
Is this going to be a perminate btest server ?
Where are you located ?
What kind of Mikrotik hardware/software are you using ?
How fast under perfect conditions should somebody be able to btest to ?
Are you using any rate-limiting queues fire-wall rules so that you do not have continous never go away sustained btest (btest abusers) ?
Do you have a btest policy/user-rules you would like to state ?
Would you like me to post/edit-add information about your btest server on the 1'st post in this btest forum?
TomjNorthIdaho
Re: Public-Mikrotik-Bandwidth-Test-Server(s) now 6.43.7
Tue Dec 04, 2018 2:47 am
December 3rd 4:45 PM (Idaho time)
I just now upgraded the 207.32.194.24 btest server to version 6.43.7
netflow
Wed Dec 05, 2018 12:17 am
Hi Tom,
This is a great service, thanks for offering to the community.
For me it works about 20 sec, then traffic is completely blocked for XX minutes. I am not sure if it is by design but this turns out to be a bit short to do any sort of stability controls. Tested using UDP with a 100mbps symmetrical connection.
netflow
Wed Dec 05, 2018 12:35 am
My bad actually, I have an automatic synflood rule that kicks in.
Maybe BTest is not behaving nicely with this regards. Sorry.
TomjNorthIdaho
Wed Dec 05, 2018 1:36 am
Yea - I have a Simple-Queue that kicks in. Below is my Simple-Queue in detail
TomjNorthIdaho
Mon Dec 24, 2018 7:13 pm
Heads up
I just upgraded the 207.32.194.24 btest server from 6.43.7 to 6.43.8
TomjNorthIdaho
Mon Dec 24, 2018 7:57 pm
Yo , heads up to --> 131-161-104-26.rev.netcorporativa.com.br
The btest server 207.32.194.24 is intended for brief btest speed testing to show your maximum peak throughput. When any btester holds executes and holds an extended continouis btest, the simple-queue settings will kick in and limit all btest sessions for all btesters to a combined 105 Meg maximum. This means that a Mikrotik admin that would may normally acheive 1-Gig on a btest to my server will now get 105 Meg or less (because somebody is not performing a brief btest and instead keeping an extended btest session running which will then have negative slower results for anybody else also measuring a btest throughput speed test.
FYI
Chupaka
Tue Dec 25, 2018 11:32 pm
What about using PCQ Bursting for this? So it will affect only bad IPs, and total bursting can be relaxed or removed :)
TomjNorthIdaho
Wed Dec 26, 2018 6:52 pm
I like the idea of PCQ , however (if I am correct in my thinking) it would then be possible to have a degrading effect on my Internet feeds to my customers. With PCQs, it would then be possible to have a combined total btest throughput load greater than my Internet feeds can support which could then possibly have a negative impact effect on my many customer connections to the Internet.
Chupaka
Wed Dec 26, 2018 7:08 pm
You can still leave max-limit and total queue burst in place, just with possibly higher values
TomjNorthIdaho
Wed Feb 06, 2019 5:51 pm
Feb 6th (7:50 AM PST - North Idaho USA time) , I just now updated the public btest server 207.32.194.24 from ROS version 6.43.8 to ROS version 6.43.11
If you notice any strange problems after the btest server ROS upgrade , please let me know
neutronlaser
Sun Feb 17, 2019 9:33 pm
How do you host a server?
TomjNorthIdaho
Mon Feb 18, 2019 10:43 pm
Re: How do you host a ( btest ) server ?
Answer - From North Idaho Tom Jones - admin for btest server 207.32.194.24
Hosting a btest server:
- 1st ; Mikrotik does not oficially endorse or host any btest servers that I know of. Back in 2016, I just made a btest server and posted it to the Mikrotik forums.
- 2nd ; All you need to do is the following:
-- a) configure a Mikrotik (I use a CHR) with a live IP address (so that remote Internet btest-ers can test to it ( TCP send & receive and also UDP send & receive )
-- b) disable any firewalls on the btest server (My btest server does not have any firewalls , I did this so that remote btesters and performs btests to/from it).
--c) on the new btest server you are creating , crease a " btest " user and a " btest " group.
My " btest " user is a member of the " btest " group
My " btest " group has only the following Policies checked " test & winbox & romon & tik.app "
--d) under IP Services , modify every IP Service to only have your IP addresses.
example: winbox Port 8282 should have one or multiple entires for your IP addresses
Note: Use IP Services to pervent others out on the Internet from telnet-ing and/or ssh-ing and/or winbox-ing (an entry for each service)
Then after your new btest server is up and running , simply post here in this forum your IP address and btest user name and password ( I would assume btest and btest ) along with information about where you are , who you are, and what speeds your server can handle for btesting , also include any policy you would like to state so that others can follow your desired btest server policies.
I will then add your btest server to the first posting of this Mikrotik btest forum topic.
If/when you have your btest server running, you are welcome to private message me so that I can take a look at it to make sure everyting looks OK.
If you would like some help , just PM me and I can winbox into your new btest server and configure it for you.
TomjNorthIdaho
Mon Feb 18, 2019 10:50 pm
Info - I just updated the 207.32.194.24 btest server from 6.43.11 to 6.43.12
agusttt
Wed Feb 20, 2019 9:46 pm
i cannot thank you enough for this
gotsprings
Forum Veteran
Forum Veteran
Fri Feb 22, 2019 8:09 pm
THANK YOU!!!
"It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
TomjNorthIdaho
Tue Feb 26, 2019 9:59 pm
Info - I just updated the 207.32.194.24 btest server from 6.43.12 to 6.44
- and - also check this out …
Martooo has spun up a btest server
Here is a link to his Mikrotik forum topic: viewtopic.php?f=2&t=145303
neutronlaser
Fri Mar 01, 2019 3:47 pm
How do you run a bandwidth server on linux?
TomjNorthIdaho
Fri Mar 01, 2019 5:56 pm
Hmmm … How do you run a bandwidth server on linux?
Well , If I were to run a " btest " server on a Linux operating system , I would do it this way:
- 1st , install VMware ESX. This is a free hypervisor for systems such as Linux.
Note - not to be confused with VMware ESXi (which also has a Unix/BSD/Linux operating system)
- 2 , with VMware ESX , you should now be able to run several different guest operating systems at the same time.
- 3 , next , I would purchase a 64-bit Mikrotik router operating system ( CHR )
- 4 , that's 99 percent what to do , the other 1 percent is just basic configuration.
--- Another possible way to do this at zero cost , I have not tested this but it should work ---
- 1st , install Wine on your Linux operating system (Wine lets you run in a near windows environment)
- 2nd , download from Mikrotik something called " btest ". This is a Mikrotik program which will perform btest's both as a client and as a server. ( I've used Mikrotik's btest program on my Windows computers to test network throughput ).
neutronlaser
Tue Mar 05, 2019 3:05 am
Bizarre there is no linux program from mikrotik that does this
TomjNorthIdaho
Thu Mar 14, 2019 5:05 pm
1st - As of this posting right now (March 14th 2019) , this forum topic "Public-Mikrotik-Bandwidth-Test-Server(s)" which was started around 3 years ago currently has 332,700 views.
Anybody have a prediction when this topic will hit 1/3 of a million (333,333) views ?
My guess is around the last day of this month.
2nd - This is more of a Mikrotik new-feature wish list:
I would like to see a new optional Mikrotik ROS package which can perform http speedtests between Mikrotiks and client connected computers (something similar to http://my-mikrotik-IP-address/speed-btest).
… Where an optional login/password could be used to perform a http UDP-or-TCP up-or-down bandwidth test
… Where a client computer behind NATted Mikrotik could perform speedtests to their inside Mikrotik gateway IP address , and/or to any Mikrotik IP address out on the Internet.
… Where the Mikrotik admin has some control for maximum bandwidth, number of simultaneous speed-btest testers, and setting to limit how often a client can perform a http speed-btest.
… The Mikrotik http speed-btest should be a simple TCP-up, then TCP-down, then UDP-up then UDP down, followed by a round-trip-ping response time.
… The output after the http speed-btest could then report all kinds of information , including the number of dropped packets during each test -and- it would also be nice to show at what speeds RED ( Random Early Detection ) begins kicking in with dropped packets.
I suspect this type of a Speed-btest server could become very very popular. And the http speed-btest web page could show some pre-configured ISP hosting information and a URL indicating "Powered by Mikrotik" which links to Mikrotik. Mikrotik just might get a boost in sales from something like this.
TomjNorthIdaho
Thu Mar 14, 2019 6:57 pm
FYI - I just now (March 14th 2019) updated the public btest server 207.32.194.24
was ROS version 6.44
now ROS version 6.44.1
If you experience any issues after the update - please let me know
neutronlaser
Thu Mar 28, 2019 10:48 pm
Mikrotik provide test servers
TomjNorthIdaho
Fri Mar 29, 2019 1:35 am
Re : Mikrotik provide test servers
Are you asking " Does Mikrotik provide public btest servers to test to ? "
Answer: No (at least I don't think so)
Are you asking " Does Mikrotik provide (free) physical routers to host a public btest server ? "
Answer: No
Are you asking " Does Mikrotik provide free ROS (CHR) software to host a public btest server? "
Answer: No
Are you asking " Does Mikrotik offset your expense to host a public btest server? "
Answer: No
Are you asking " What are the benefits of hosting a public btest server? "
Answer: You will help hundreds/thousands/tens-of-thousands of network admins by letting them test to your public btest server.
Are you asking " Do I need permission from Mikrotik to host a free public btest server? "
Answer: No
private owner of the public btest server 207.32.194.24 since January 2016
neutronlaser
Fri Mar 29, 2019 2:01 am
No, telling them to provide servers like ubiquiti do
Chupaka
Fri Mar 29, 2019 10:45 am
I think it's much easier to add speedtest.net client - they have servers all over the world :)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
vic45708
Wed Apr 03, 2019 2:44 am
Are any of the servers still available to test 2 routers?
TomjNorthIdaho
Wed Apr 03, 2019 6:23 pm
My btest server 207.32.194.24 is still available to btest to.
TomjNorthIdaho
Wed Apr 03, 2019 6:27 pm
It would be nice if Mikrotik came out with an optional ROS server package which would allow computers to perform http speedtests to a Mikrotik.
TomjNorthIdaho
Thu Apr 04, 2019 6:05 pm
FYI - the public access 207.32.194.24 btest server was just now upgraded from ROS 6.44.1 to ROS 6.44.2
azol
Wed Apr 10, 2019 12:10 pm
Any IPv6 btest servers?
phin
Sat Apr 13, 2019 8:04 pm
Unable to connect as of today.
Tonete
Sun Apr 14, 2019 12:12 pm
System upgraded, but unable to connect Tom's btest Server.
neutronlaser
Sun Apr 14, 2019 2:39 pm
Be good if they came up with a simple Linux script you could run to host a test server, or have RouterOS test using standard files that the Speedtest web sites use like 100MB bin files.
apetryk
Sun Apr 14, 2019 8:26 pm
Same here.
TomjNorthIdaho
Mon Apr 15, 2019 5:45 pm
Re : unable to connect
Try it now
I just rebooted the btest server
TomjNorthIdaho
Mon Apr 15, 2019 5:49 pm
Holey smokes …
5 seconds after rebooting the btest server ( 207.32.194.24 ) , I had 3 btesters connected to it.
Either we have some automated bot btesters running or some in this forum are very fast at reading my prior post and then btesting -or- a combination of both.
deathandtaxes
Wed Apr 24, 2019 11:12 pm
unable to connect to 207.32.194.24
TomjNorthIdaho
Thu Apr 25, 2019 12:00 am
FYI - just now ( April 24th 2019 @ 2PM North Idaho time )
I updated/upgraded the 207.32.194.24 public access btest server
To: ROS version 6.44.3
TomjNorthIdaho
Thu Apr 25, 2019 1:07 am
FYI
On average, per every 15 minutes , my 207.32.194.24 btest server will have around 30 different/unique IP addresses of remote Mikrotik devices which have performed a btest.
That's an average of a btest session starting every 30 seconds.
For the last 30 days , the 207.32.194.24 btest server as a 30 day sustained average rate transfer of :
35 meg-bits-per-second to the remote btest client
20 meg-bit-per-second from the remote btest clinet
Combined up/down is 55 meg-bits-per-second
Now a little math to calculate bits per year at current rate : ( ( ( ( 55 meg-bits-per-second * 60 ) * 60 ) * 24 ) * 365 ) = 1,734,480,000,000,000 bits
- that's 1,734 terra-bits !!! also known as 217 terra-bytes
- - - Question - When is the last time you moved 217 terra-bytes to/from the Internet that was not directly related to your Internet customer traffic ?
Note - the above data is "average" not "peak" !
dadoremix
Wed May 01, 2019 12:31 pm
btest still working ?
from croatia not working
207.32.194.24
TomjNorthIdaho
Wed May 01, 2019 5:45 pm
207.32.194.24
I had to reboot it ?
Strange , this is the 3rd time in the last few months I had to reboot it.
The problem started 1 or 2 or 3 ROS versions ago.
What happens is the "BTest-Server-Settings" [x] Enabled and the [x] Authenticate check boxes both somehow become un-checked.
When I reboot my 207.32.194.24 CHR btest server, it comes back with both settings checked again.
Strange … … …
I have not made any changes to the btest server for more than a year - except when a new version of ROS comes out , then I upgrade it.
Is anybody else seeing other strange problems with btest servers or related strange things since the last version (or two) of ROS ?
If it happens again in the near future , I'll send info to Mikrotik's tech support and let them know what I am experiencing with the 207.32.194.24 btest server.
TomjNorthIdaho
Wed May 01, 2019 5:57 pm
Little help here …
I am just now starting to work with IPv6 , grrrrrr
Although I've been doing IP networking for almost 30 years now , I've never played with IPv6
My bad
Anyways, I have setup a test Mikrotik running IPv4 and IPv6 ( not the 207.32.194.24 server) , and I wish to ask if somebody has a IPv6 Mikrotik I can perform a few IPv6 btest(s) to/from.
If somebody is willing to assist, you can post here or PM me.
(FYI - my test IPv6 Mikrotik is on another ISP network I do not manage)
When I get IPv6 running on my network, I may create two more btest servers so that I end up with 3 btest servers. 1-Only IPv4 , 2-Only IPv6, 3-IPv4&IPv6 btest servers. (If Mikrotik is willing to donate the CHR software when I have IPv6 running on my ISP network).
sims
Tue May 21, 2019 1:29 am
is btest 207.32.194.24 working? I tried from 3 different locations with 6.44.1 and 6.44.3 but without any luck.
TomjNorthIdaho
Tue May 21, 2019 2:09 am
Nope - The 207.32.194.24 btest server was down again.
I just rebooted it - it is now up again
It looks like it quit working May 16th at about 8PM PST (Los Angeles time)
The 207.32.194.24 btest server somehow had both the btest enabled & authenticate unchecked.
A reboot of the btest server got it back on-line without making any changes.
I am pretty sure this is a Mikrotik CHR ROS problem - because I have not made any changes to it this year.
Hey Mikrotik - you reading this - I suspect there may be something going on ….
sims
Tue May 21, 2019 7:54 pm
Thanks all good :)
Hope mikrotik will fix this bug, keep on the good job
TomjNorthIdaho
Thu May 23, 2019 6:52 pm
Well - rather strange - but It looks like a found a Band-Aid solution temp fix which appears to keep the 207.32.194.24 btest server on-line and available without the random problem where the btest server keeps disabling itself.
What I did was this:
- disable all IP services on the Mikrotik CHR except for www
- change the default www port from 80 to another port number
If you encounter problems with the 207.32.194.24 btest server not responding, please post & let me know.
FYI - I suspect other tik devices could possibly be experiencing the same issue where the IP service (btest in my case) for no reason suddenly quits.
danriis
Thu May 30, 2019 9:40 am
Thanks for making this available, unfortunately I'm not able to make it work. I have the latest packages and firmware, just updated today.
Any thoughts on why it's not working?
jimvam
Tue Jun 04, 2019 7:58 am
For me is out as well!
MTCNA, MTCTCE, MTCUME Mikrotik Certified GREECE-CRETE
TomjNorthIdaho
Tue Jun 04, 2019 5:14 pm
K - I just rebooted it - give it a try now
danriis
Wed Jun 05, 2019 1:54 am
Tried again, no luck, it does seem to connect now but no throughput, here's a screenshot:
[mod@MikroTikLV] > /tool bandwidth-test 207.32.195.2 user=btest password=btest protocol=udp duration=30 direction=receive
status: connecting
rx-current: 0bps
rx-10-second-average: 0bps
rx-total-average: 0bps
lost-packets: 0
random-data: no
direction: receive
rx-size: 1500
connection-count: 20
TomjNorthIdaho
Wed Jun 05, 2019 2:27 am
status: connecting
rx-current: 0bps
lost-packets: 0
random-data: no
direction: receive
rx-size: 1500
hmmm - Some time ago it was 207.32.195.2 - but it was changes around a year ago to 207.32.194.24 ( read the posts )
North Idaho Tom Jones :)
danriis
Wed Jun 05, 2019 4:17 am
Thanks Tom, I did browse through many pages trying to find the latest syntax but apparently missed it. Works great now, really appreciate it.
Dan
TomjNorthIdaho
Wed Jun 05, 2019 5:58 pm
Dan
Dan - you're a good man :)
I don't care about any mistakes and/or overlooks you make - lol
Happy to know yer working now
dadoremix
Wed Jun 05, 2019 6:07 pm
Again not working??
User pass btest
Disconnected
Without pass say auth faild
evince
Thu Jun 06, 2019 2:28 pm
Same problem today, unable to connect :(
kuklei
Wed Jun 12, 2019 3:06 pm
same today. Btest server down. I guess its because this is the only server available and many users flood it. Sorry to see only North Idaho Tom Jones hosting one. Someone should step up and offer more severs for the community. We cant realistically expect that only one server will quench the thirst of mikrotik users worldwide.
Thanks NITJ for the service so far. KUDOS
TomjNorthIdaho
Tue Jul 02, 2019 2:14 am
Some good news :D
The btest server 207.32.194.24 is now also IPv6 :)
IPv4 address: 207.32.194.24
IPv6 address: 2605:4e40:0:1fe::
user: btest
password: btest
If I do not see any abuse , then I will keep the IPv6 address also
TomjNorthIdaho
Wed Jul 03, 2019 10:39 pm
FYI - update on the btest server(s) for:
A few moments ago , I made the following changes to the public accessible btest server:
#1 - Instead of having a single ether1 with both IPv4 and IPv6 addresses , I changed the server so that it is now:
ether1: IPv4 address: 207.32.194.24
ether2: IPv6 address: 2605:4e40:0:1fe::
I did this so that I can get clear graphs for IPv4 traffic and another graph for IPv6 traffic
#2 - I changed the firewall rules (for IPv4 and IPv6) where the wait-time-delay was 15 minutes , the new wait-time-delay is 1 hour.
This is the time a previous btester must wait until they can btest again. I made this test because I see there are some remote users who had scripts that would auto-script a best to my btest server every 15 minutes. This btest server is not intended to be used as a traffic graphing system for other networks. It is intended for Mikrotik admins to be able to manually perform brief btest(s) to verify and test their network reliability and throughput (from time to time - not automatically tested on a pre-configured script schedule).
I would like to ask for some feedback if you don't mind …
--- Who and where-are-you to those who use the btest server ?
--- Does the new IPv6 btest address appear to be working correctly ?
--- And comments are always welcome ……
JimRockford
Fri Jul 05, 2019 3:42 am
Hi Tom,
Hope to be near you in Northern Idaho very soon, but for now NE Texas. When I connect to other MikroTiks on our WAN, I get a speedtest back as I would expect, but when I connect to yours, I get a flatline zero. Do I need to change any settings? Thanks for the server.
macsrwe
Forum Veteran
Forum Veteran
Sat Jul 06, 2019 1:06 am
I've used it perhaps a dozen times over the past 18 months from the region surrounding Wickenburg, Arizona, to ensure periodically that WAN providers are (still) offering the speeds my clients are paying for. This would be much more difficult to do without the service you offer, so thank you so much.
JimRockford
Sat Jul 06, 2019 5:15 am
I just don't get it. If I connect to another MikroTik on our WAN, I see a normal throughput graph, but if I connect to this one, it's a 0 flat-line like a patient in asystole. What am I missing?
macsrwe
Forum Veteran
Forum Veteran
Sat Jul 06, 2019 3:59 pm
Sorry for what may be an obvious question, but are you connecting to it with the bandwidth test tool, or just connecting to it?
JimRockford
Sat Jul 06, 2019 7:38 pm
Thanks for the reply, and no apology necessary. I realize you have to ask in these situations. I am connecting under Tools > Bandwidth Test. When I get a connect while attached to the MikroTik via a browser I get a flat line. If I connect to a remote MikroTik across on of our VPN tunnels, I get 35 Mbps which is the upload bandwidth limitation for the remote MikroTik. Last night I found that I could connect to this one via Winbox, but when I did, I got 1200 bps (12kbps). Today if I connect via Winbox I get 0 just like browser based. Again, if I connect to our other MikroTik across the VPN via Winbox I get 35 Mbps.
aeroclown
Tue Jul 09, 2019 7:59 pm
Is the firmware out of date by chance? I'm running 6.45.1 on a CCR but when I try to do a test to 207.32.194.24 it just sits at the connecting phase. I'm located in Central Texas trying to check the throughput of a new service upgrade on the wan.
mbfound
Tue Jul 16, 2019 3:06 pm
Not working for me now, the other btest server that you linked in your original post works.
TomjNorthIdaho
Tue Jul 16, 2019 7:19 pm
If you post your WAN IP address, I can check the btest server and see if there is something stuck in my auto-updating queues and fw auto-timeout rules.
mbfound
Wed Jul 17, 2019 2:41 pm
Probably something in the following range: 129.205. 144.0/24
They are changed around so can't give you a 100% on the last digit.
TomjNorthIdaho
Wed Jul 17, 2019 7:00 pm
There simply just has to be a bug in the Mikrotik ROS !!!
On the public btest server 207.32.194.24 ( also IPv6 2605:4e40:0:1fe:: ) , the btest server settings somehow changed to :
btest server DISABLED (check box not checked)
btest server Authenticate DISABLED (check box not checked)
I re-enabled the two settings and rebooted the btest server
Give it a try and see if the btest server is now working.
((( This simply just has to be a bug in ROS )))
I have two CPUs assigned to my VMware ESXi btest server
I have 1-Gig of RAM assigned to my VMware ESXi btest server
Last time - I made a band-aid fix by disabling Winbox on the server - I will again disable it and see if those two settings again somehow get disabled
mbfound
Thu Jul 18, 2019 3:01 pm
Still no joy, goes straight to disconnected.
Can traceroute to site although it looks like you have ICMP rate limiter on?
matuss
Fri Jul 26, 2019 3:29 pm
Hello, I've just tested to both IPv4 and IPv6 addresses from one of my RB2011 (Slovakia, Central Europe) on ROS 6.45.11 and both worked great, Thank you!
On IPv4 I've got approximately 75/65Mbps and IPv6 was even 95/85Mbps (UDP both way).
Those speeds are good enough for the installation site, but I wonder what would cause such a difference?
Could it be just my provider prioritizing IPv6? Configuration issue on my side? Is it to be expected?
TomjNorthIdaho
Fri Jul 26, 2019 7:17 pm
In my opinion …
There are two methods to implement IPv6 routers/networks (with the current IPv4 networks).
- use/build Dual-Stack routers/networks ( were routers in a network are both IPv4 and IPv6 at the same time )
- Add IPv6 routers/networks next to existing IPv4 routers/networks (where you have a mix of only IPv4 routers/networks -and- only IPv6 routers/networks)
Both methods to implement IPv6 work well. ( I'm building both types in my IPS/WISP networks - where some networks use only IPv4 sitting next to only IPv6 routers/network … and other parts of my network are Dual-Stack ( both IPv4 and IPv6 ). There are advantages of both methods to implement IPv6 into your network.
If an IPv4 router is pretty busy/saturated then you have two options , upgrade hardware to support both IPv4 and IPv6 - - - or - - - add additional IPv6 only hardware next to your existing IPv4 hardware. There are pros and cons of both methods.
Edit: Also , IPv6 traffic through the Internet may use different paths (hops) through the Internet verses IPv4 paths (hops). Thus IPv6 traffic has a high possibility of going through totally physically different routers/switches/networks that IPv4 traffic goes through.
In answer to your question - I suspect it simply comes down to what method each Internet hop and built and how busy each device is.
TomjNorthIdaho
Thu Aug 08, 2019 6:02 pm
btest server managed by North Idaho Tom Jones
Upgraded from ver 6.45.2 to newer ver 6.45.3 (upgraded a few minutes ago)
Tdaddysimi
Sun Sep 08, 2019 12:59 am
Hey Tom,
I can't connect to 207.32.194.24
Is it up?
Tdaddysimi
Sun Sep 08, 2019 1:01 am
I have a feeling my public got accidentally put on a ban list. I can ping it from a different connection.
Can you please see if 173.27.22.214 got put on a block list?
mbfound
Mon Sep 09, 2019 4:29 pm
Tom, did you ever get to fixing the speed test server?
Having a similar issue on my CCR and it only works after a reboot for a while.
Says "connecting" "disconnected" whenever I try testing.
apetryk
Mon Sep 09, 2019 6:47 pm
Are others having issues with tcp based testing? My udp tests are fine but tcp getting zero throughput.
A
apetryk
Mon Sep 09, 2019 10:04 pm
FYI - re: TCP testing. I believe this is a config issue for Tom's server as I just tested successfully using TCP using Martooo's public server.
mrmut
Tue Sep 10, 2019 3:31 pm
I confirm issues with BW testing server; TCP test doesn't connect at all, and UDP connects, but doesn't show let anything through.
TomjNorthIdaho
Fri Sep 13, 2019 6:34 pm
North Idaho Tom Jones - Public btest server
Sorry about not responding to some of the posts here. I've been busy on some ISP/WISP/networking projects.
FYI - I just now ( September 13th 2019 ) updated the btest server from ROS version 6.45.3 to version 6.45.6
I also cleared out some of the btest Address-Lists ( this list auto populates when you perform a btest and is supposed to auto-unpopulated after a time-out period and elapsed )
apetryk
Wed Sep 18, 2019 6:45 pm
I can confirm post upgrade the server is working again for both TCP and UDP traffic
A
TomjNorthIdaho
Thu Sep 19, 2019 11:08 pm
Just checked 09/19/2019
This Mikrotik forum topic "Public-Mikrotik-Bandwidth-Test-Server(s)" has 408,463 Views
Soooo, do I win a free cup of coffee when it hits 1/2 million views ?
TomjNorthIdaho
Re: Re:
Tue Sep 24, 2019 2:51 am
Great idea if You have a good infrastructure and inet line! Thank You!
I was always wondering why MikroTik didn't do that with few bunch of load balanced servers.
I will test it in the evening CET.
Poslano sa mog Mi-4c koristeći Tapatalk
- Sustained traffic is limited to 100 Meg up/down (after about 30 to 60 seconds)
This btest server was not designed or intended for any sustained continuous long-running btest(s). A firewall rule will kick in to prevent saturation of my ISP/WISP bandwidth.
Please only perform brief btest(s) to measure your peak Up/Down traffic.
Normally peak btest measurements can be performed in under 20 seconds.
monfi
Tue Oct 01, 2019 12:16 am
Thank you friend for this resource i wish you the best of luck!, please tell me, still is working! , nowdays!
kindly regards from Ecuador-SouthAmerica
TomjNorthIdaho
Tue Oct 01, 2019 5:49 pm
Hello to South America :)
I currently have the btest server off-line.
I am doing some server updates on my network.
It should be back on-line in a couple of hours.
CZFan
Thu Oct 10, 2019 3:18 pm
Hi Tom,
From South Africa, I make use of this service every now and then (once or twice a week), typically when a customer says he is not getting full speed.
Currently only use IPv4 for testing
Thank you
MTCNA, MTCTCE, MTCRE & MTCINE
TomjNorthIdaho
Fri Oct 11, 2019 1:03 am
Hi Tom,
Thank you
Hello CZFan
That's what my public btest server is for :)
Happy btest-ing :)
TomjNorthIdaho
Mon Oct 28, 2019 6:35 pm
Just now updated the public access btest server from "Installed Version 6.45.6" to "Latest Version 6.45.7"
Happy btest (ing)
danunjaya123
Tue Oct 29, 2019 12:59 pm
I have tried to check btest but it was not connecting?
user: btest
password: btest
Torontobb
Fri Nov 08, 2019 10:22 pm
Tested, not connecting. Can't find any working public server on this forum.
:shock: :?
Torontobb
Wed Nov 13, 2019 12:21 am
Is this thread and its usefulness fully dead?
TomjNorthIdaho
Thu Nov 14, 2019 2:12 am
This is an active thread.
The btest server is normally running 24 hours a day 7 days a week 365 days a year
The btest server is running right now. I just checked it.
If you are unable to connect to the btest server ..
- wait a few hours
- after waiting , try performing a 30 second btest
- If you are still unable to connect to the btest with the server , then check your firewalls. The btest server only has one firewall configuration which makes recent remote btest-ers have to wait until they can btest again.
--- Are you testing from behind a firewall ?
--- Is your Mikrotik a firewall ?
shuguet
Tue Nov 26, 2019 4:56 pm
Hello team,
Any chance there is a 10G btest server out there I could use for a quick bandwidth test?
It would be a one time thing, I have recently upgraded my home fiber connection to a 10G one, just trying to push it all the way to make sure the ISP is really delivering.
Here are the latest test results I achieve with the current btest server mentioned in the first post (Thank you @TomjNorthIdao!).
[mikrotik] > /tool bandwidth-test 207.32.194.24 user=btest password=btest direction=both
                    ;;; results can be limited by cpu, note that traffic generation/termination
                        performance might not be representative of forwarding performance
                status: running
              duration: 21s
            tx-current: 584.0Mbps
  tx-10-second-average: 584.2Mbps
      tx-total-average: 574.6Mbps
            rx-current: 1222.9Mbps
  rx-10-second-average: 1224.4Mbps
      rx-total-average: 1243.7Mbps
          lost-packets: 14441
           random-data: no
             direction: both
               tx-size: 1500
               rx-size: 1500
        local-cpu-load: 23%
       remote-cpu-load: 92%
Best regards
TomjNorthIdaho
Tue Nov 26, 2019 6:52 pm
Hello team,
                status: running
              duration: 21s
          lost-packets: 14441
           random-data: no
             direction: both
               tx-size: 1500
               rx-size: 1500
        local-cpu-load: 23%
Best regards
shugnet - I wish I had the ability to briefly drop my bandwidth queues on the 207.32.194.24 public btest server. However , I do not have the extra reserve capacity to offer a btest server at anything beyond what it is already doing because as an ISP, WISP , I am already running near capacity on my Internet connection feeds.
TomjNorthIdaho
Fri Dec 06, 2019 6:29 pm
FYI - I just upgraded the ROS firmware on the public access btest server.
It's now; 6.46
If you encounter any issues with the btest server, please post and let me/us know.
user: btest
password: btest
Thor187
Thu Dec 12, 2019 5:16 pm
[admin@MikroTik] > /tool bandwidth-test 207.32.194.24 user=btest password=btest direction=both
status: can not connect
TomjNorthIdaho
Fri Dec 13, 2019 12:54 am
- wait a few hours
WIth your IP information, I can look at my logs
Tdaddysimi
Wed Dec 18, 2019 6:15 pm
Ran a btest this morning with my new ccr1036-12g-4s and reached 438 mbps of the 500 i'm paying for. Not bad!!! Thanks!!!
You provide a beautiful service to the Mikrotik community and I appreciate having a resource like this to test against from time to time.
TomjNorthIdaho
Thu Dec 19, 2019 10:40 pm
Tdaddysimi - Thank you for your kind comments
apetryk
Tue Dec 31, 2019 5:02 pm
Is the bandwidth test server down? The last successful test I ran from two different routers on three different WAN connections was Dec 28.
TomjNorthIdaho
Fri Jan 03, 2020 11:42 pm
can you ping the btest server ?
Acerorosso
Sat Jan 04, 2020 7:50 am
Hi all, I tried this morning a speed test but the router seem to be unable to connect ... "Connecting" is the last step i see in the process.
I'm running last Firmware 06.46.1 and Router Model :SXT R
There's some issue with server or is my side not properly working ?
Test server 207.32.194.24 is pingable but no connection from Mikrotik router test utility.
Thank you for some ideas,
Marco
apetryk
Sat Jan 04, 2020 4:19 pm
Tom,
I could ping the btest server when it wasn't able to connect for the bandwidth test.
Not sure if you changed something but this morning was the first time since Dec 28 where I'm now able to successfully run bandwidth tests again.
Adam
CharlieD
Thu Jan 30, 2020 3:23 pm
1st - today, I changed the bandwidth allocated to the 207.32.195.2 btest server
Info here: viewtopic.php?f=2&t=104266&p=645201#p645201
Max Limit: 98M
Burst Limit: 1250M
Burst Threshold: 50M
Burst Time: 500
apetryk
Mon Feb 03, 2020 3:19 pm
207.32.194.24 test server may be down.
It doesn't respond to ping. Traceroute shows the last reachable hop as 207.32.194.6
TomjNorthIdaho
Tue Feb 04, 2020 6:10 pm
Hmmm , this morning I had to reboot the btest server.
For some reason, the btest settings got un-checked ( login and service ).
I've seen this CHR based btest server do this a few times last year.
While I was at it, I upgraded from 6.46.1 to 6.46.2
Anyways, it should be running now.
supercap
Wed Feb 12, 2020 11:19 pm
today your server not work: no ping and traceroute stop at 207.32.194.6.
TomjNorthIdaho
Thu Feb 13, 2020 8:31 pm
The IPv4 address of my btest server is 207.32.194.24
FYI , This morning , I upgraded this CHR btest server from 6.46.2 to 6.46.3
supercap
Fri Feb 14, 2020 2:50 pm
Yes i tried right now and worked for two times: both direction and send direction.
Third time i tried with a send direction, was not work.
Now i wait a bit and i try again.
zakynthoswifi
Sat Feb 29, 2020 3:22 pm
I can't connect to your btest server...
it says connecting and after 12 seconds disconnected...
Ilias Theodosis
Zakynthos, Greece
dadoremix
Sat Feb 29, 2020 3:24 pm
yep
207.32.194.24 down
TomjNorthIdaho
Tue Mar 03, 2020 6:49 pm
Tuesday March 3rd 2020 at 8:50 AM PST , I updated the chr btest server from Version 6.46.3 to Version 6.46.4
Users browsing this forum: Bing [Bot], nazimkhan10172, stvnm, Znevna and 101 guests
