uldis
Re: v6.35rc [release candidate] is released, new wireless package!
Mon Mar 14, 2016 11:09 am
Please make a support output file after the reboot and then another file when you see that the board has taken a lot of memory - this will help us to identify what causes the memory usage.
Send both files to support@mikrotik.com
Rc26
My hex increases the use of mem whitout reason until it hangs. Need to reboot to work again and do the same again.
12 hours more or less until it uses all the memory and need reboot.
No config changes before update. Only from rc 19 to rc 26
Update to include image.
uldis
Mon Mar 14, 2016 11:12 am
In rc26, and it has been in CAPsMAN configuration, from the DHCP Server, which is activated in the other RB, has been confirmed a phenomenon in which the IP address is not passed.
Moreover, instead of immediately occur, but after the elapse of a few hours if you are using.
It has not been output, especially something like anxious to log.
If you have enabled local forwarding, it seems this phenomenon is likely to occur.
Please provide more detailed info on the problem. What RouterOS version and wireless package you had were this all was working fine?
What setup you have on the CAPsMAN and the CAP?
Please send the support output files and also information how to reproduce this problem to support@mikrotik.com
kometchtech
Mon Mar 14, 2016 11:48 am
Hello, uldis.
I have to be reported in the following ticket.
[Ticket#2016031466000342]
Routerboard Users Group JP
http://www.rb-ug.jp/
CCR1009-8G-1S-1S+, RB750Gr3, CRS226-24G-2S+, RB850Gx2, RB960PGS, CRS317-1G-16S+,
RB2011UAS, CRS125-24G-1S, RB962UiGS-5HacT2HnT, CRS212-1G-10S-1S+, RB3011UiAS
MAYAKNET
Mon Mar 14, 2016 12:07 pm
Доброго дня Всем.
1. Очень серьёзная проблема, не могу от версии что обновился на 6.35rc19 ни дальше обновиться ни откатится назад. Пытался через НЕТИНСТАЛЛ 6.35.3 - не получилось. Не видит НЕТИНСТАЛЛ Микротик в состоянии BOOT
2. Около 2-х месяцев проблема с 2-йными сессиями в Микротик, во вложении скриншот. Авторизация у нас PPPoE через РАДИУС. Порой 2-х сессий так много, приходится по 2-3 раза в день перезагружать Микротик.
Siona
Mon Mar 14, 2016 1:50 pm
Доброго дня Всем.
English please
strods
Mon Mar 14, 2016 1:59 pm
Version 6.35rc28 has been released.
Changes since previous version:
*) l2tp - implemented l2tp and lns fastpath/fasttrack support;
*) pppoe-client - implemented fastpath support;
*) console - allow unknown scan-list names on wireless configuration to fix import;
*) console - sort completions/hints in natural order;
*) health - swap fan2 and fan3 on CCR1072;
*) ipsec - take into account ip protocol in kernel policy matcher;
*) led - turn on fault led on CCR1072 if CPU too hot;
*) lte - changed AT command processing;
*) mac-winbox - try to aggregate packets & resend all pending packets on timeout;
*) ppp - do not crash when received multiple CBCP packets;
*) winbox - correctly recognise if there is need to report fan information uder system health;
*) winbox - do not use area v2 names instead of ospf v3 area names;
*) winbox - make additional-network-mode optional for lte interface;
*) winbox - make mac-winbox work with RB850;
*) wireless - fix crash on nstreme-dual interface stats update.
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after crash.
incahex
Mon Mar 14, 2016 2:46 pm
Rc26
Sorry I downgrade to 6.34.3 and now all is ok.
I will wait for new RC to try upgrade in a future.
amokkatmt
Mon Mar 14, 2016 3:13 pm
This issue with memory started for me on rc25. I have RB750GL.
Already upgraded to rc28. If issue reoccur, will try to make Supout.
strods
Mon Mar 14, 2016 3:31 pm
incahex, amokkatmt - Do you have some kind of tunnels on your devices? For example, L2TP and/or PPPoE?
MAYAKNET
Mon Mar 14, 2016 3:59 pm
Доброго дня Всем.
English please
Good day everyone.
1. Very serious problem, I can not from the version that was updated on 6.35rc19 no further update or rollback. Tried through NETINSTALL 6.35.3 - it did not work. He does not see NETINSTALL Mikrotik able BOOT
2. About 2 months is a problem with 2-ynymi sessions in Mikrotik, screenshot as an attachment. Authorization we PPPoE via RADIUS. Sometimes 2 sessions so much, we have 2-3 times a day to restart the Mikrotik.
amokkatmt
Mon Mar 14, 2016 4:08 pm
I have 1 PPPoE outgoing, 2 L2TP outg., 1 PPTP incoming running almost all the time.
Now waiting:
uptime 1.5 hours.
Few last days:
amokkatmt
Mon Mar 14, 2016 4:27 pm
Good day everyone.
Also have this issue on CCR1036-12G-4S.
Our real 800 pppoe clients turned into 2400 pppoe sessions with "kernel failure" random reboots and fail to up/down grade RouterOS. But netinstall worked for me. CCR just "kernel failure" and rebooting instead of flashing ROS. Same with restoring backups - "kernel failure". I have 3 supouts, 2 auto, and 1 created manually when uptime was 5 minutes. Where should I send this?
MAYAKNET
Mon Mar 14, 2016 7:19 pm
Good day everyone.
And Mikrotik CCR1036-12G-4S and Mikrotik CCR1016-12S-1S + I have them more reached the 10 pieces, and all this problem.
incahex
Tue Mar 15, 2016 2:24 am
I have a pppoe client for the wan connection.
Also I have a pppt server configured for my private use as tunnel when I use plublic hotel wifis. But normaly is not in use.
I update to RC28 and is also the same problem. Memory use increases whitout reason.
I will send you a support file before and after do reset right now.
strods
Tue Mar 15, 2016 8:25 am
We are currently working on fixes for PPP problems. Please wait for upcoming release candidate versions which will include fixes for problems introduced in latest 6.35rc versions.
strods
Tue Mar 15, 2016 9:30 am
Version 6.35rc29 has been released.
*) RB3011 - fixed time keeping
nz_monkey
Tue Mar 15, 2016 9:51 am
Thanks Mikrotik support and developers.
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet NSE7 | Extreme Networks ENA
RyperX
Tue Mar 15, 2016 1:39 pm
I have wireless problems since 6.35rc28, didnt changed any config about that
Has anybody else these problems?
uldis
Tue Mar 15, 2016 5:44 pm
With what wireless package you see this problem?
What configuration you have on the wireless and what wireless encryption you have enabled?
What is your wireless client hardware?
incahex
Tue Mar 15, 2016 8:00 pm
Not urgent but could you also update de RouterBOOT changelog in the wiki.
http://wiki.mikrotik.com/wiki/RouterBOOT_changelog
actual routerboot is 3.31 in mi hex and changelog wiki is still in 3.28
RyperX
Tue Mar 15, 2016 8:30 pm
Thanks for respone but i have to apology ;)
It wasnt the fault of the router or OS, one of my devices had a broken wifi chip.
darkprocess
Tue Mar 15, 2016 9:32 pm
I've also those errors with my laptop with the rep package. Deconnections every 5 mn in average. Using the router as a repeater
strods
Wed Mar 16, 2016 10:41 am
Version 6.35rc30 has been released!
*) ethernet - fixed Netmetal, QRT, DynaDish, SXT ac linking at 10/100Mbps (introduced in 6.35rc);
*) firewall - added experimental "action=route" in mangle prerouting - that forces packets to specific gateway by ignoring routing decisions (CLI only);
*) l2tp - fixed small memory leak on reconnects;
*) pppoe - make fast path receive work on tile, arm and x86;
*) proxy - fix ftp request url decode;
*) tile - fixed fast path related memory leak.
i4jordan
Wed Mar 16, 2016 10:46 am
Strange behaviour of a RB3011 with v6.35.RC28
It sometimes reports very high and strange interface usage:
[img]
[/img]
eth6 is connected to a LTE router (max.150/150Mbps)
eth7 is connected to a ADSL2 router (max. 10/1 Mbps)
eth8 is connected to a ADSL2 router (max. 10/1 Mbps)
docmarius
Wed Mar 16, 2016 12:40 pm
Now this is a nice addition. I assume it also initiates connection tracking for reverse path...
Torturing CCR1009-7G-1C-1S+, RB450G, RB750GL, RB951G-2HnD, RB960PGS, RB260GSP, OmniTIK 5HnD and NetMetal 922UAGS-5HPacD + R11e-5HnD in my home network.
mjs
Wed Mar 16, 2016 10:45 pm
I'm running 6.35.rc30 on RB3011 I have been getting these errors for sometime now, they go away if I back-grade to 6.34.3.
KentornoS
Thu Mar 17, 2016 12:46 am
Hello everyone, found bug with radius - Acct-Input-Octets always equal to 54 bytes:
Here is session history from freeradius db:
sessions are shown in desc order (newest on the top). Were used 6.35rc15, then downgraded to 6.34.3, then upgraded to 6.35rc30. As I can see, problem still exists in 6.35rc30, but all works perfect on 6.34.3.
Devices were used:
RB750UP r2 - 3 pcs
RB750
RB911G-5HPnD
Problem exists on all devices.
strods
Thu Mar 17, 2016 11:43 am
Version 6.35rc31 has been released.
*) fasttrack - fixed timer updating in connections table for fasttrack connections;
*) ppp - fixed crash when ppp interface gets disconnected and user gets authenticated at the same time (most probable with slow RADIUS server);
*) ppp - fixed memory leak high number of pppoe clients to the same server;
*) route - fix filter by routing table;
*) winbox - allow to set additional-network-modes;
*) winbox - allow to show revoked & authority flags at the same time;
*) winbox - do not show "enable-jumper-reset" setting on devices without serial port;
*) winbox - do not show real-tx-power column in current-tx-power by default;
Cha0s
Thu Mar 17, 2016 5:44 pm
After upgrading mAP Lite to 6.35rc31 from 6.34.2 the clock is off by ~1.8seconds every 15minutes.
I don't know if that was the case before or if it's a new bug but now that SNTP will log the time change it floods the logs with messages like
juanvi
Thu Mar 17, 2016 5:52 pm
Happened here too with rc29 in x86 but stopped after a day. Normal behavior?
NTP SERVERS: 150.214.94.5 - 176.31.53.99
¡vʞvdnX puv ···SOɹǝʇnoɹ ʞıʇoɹʞıW oʇ sʞuvHʇ
Cha0s
Fri Mar 18, 2016 12:24 pm
Probably not related with the problem on mAP Lite.
I just checked numerous devices with various versions and only mAP Lite does not keep time properly consistently.
It's always faster by 1.8seconds every 15minutes. I tripled checked it on 3 different mAP Lite devices (with 3 different versions of routeros - so the problem seems to always have existed on this device)
The following devices which I have available here at the moment do not show any problems with time keeping (max offset is ~ 18ms, min offset is a few μs)
RB433AH - MIPSBE (2 of them)
SEXTANT G - MIPSBE (2 of them)
SXT 5HPnD - MIPSBE (2 of them)
Groove A-52HPn - MIPSBE (2 of them)
2011UAS-2HnD - MIPSBE
hAP Lite - SMIPS (2 of them)
CCR1036-8G-2S+ - TILE (2 of them)
RB850Gx2 - PPC
RB3011 - ARM (OK as of v6.35rc29)
x86 (ESXi VM)
strods
Fri Mar 18, 2016 12:38 pm
Version 6.35rc32 has been released.
*) bonding - fix crash on bonding slave release;
*) hotspot - fix possible deadlock;
*) l2tp - fixed kernel failure (introduced in 6.35rc);
*) snmp - fix getbulk result ordering with multiple request OIDs;
*) winbox - make mrru disabled and set mtu+mru to auto by default on new servers
notToNew
Re: Intel 5300AGN ping loss
Fri Mar 18, 2016 12:47 pm
I use 6.35rc26 wireless-rep (AP mode), my laptop (WIN7 INTEL wireless 5300AGN) had a lot of PING loss, when I changed to WIRELESS-CM2, everything is normal.
Can reproduce this with 6.35rc31 on Basebox2. Switched back to WIRELESS-CM2 as well.
CCR1036-12G-4S, several 952Ui-5ac2nD, ...
ohitz
Fri Mar 18, 2016 1:21 pm
Excellent! I confirm this works, you can therefore close Ticket#2016030366000916.
Thanks,
Oliver
jondavy
Fri Mar 18, 2016 1:31 pm
dns cache stop work after some time
on RB2011UiAS with 6.35rc32
strods
Fri Mar 18, 2016 1:34 pm
Version 6.35rc33 has been released.
*) lte - changed AT parsing because supported Huawei modems use unsolicit events instead of polling
Florian
Fri Mar 18, 2016 3:00 pm
(Damn you're on fire today)
- Sorry for my english -
SiB
Forum Veteran
Forum Veteran
Sat Mar 19, 2016 1:28 am
Please add working 'Ctrl+F' at start of WinBox. I must always click on any managed or neighbors RB first.
MTCNA + MTCRE + MTCINE | ~600 users at ~150 RouterBoards in EMEA | Telegram: @SiB_PL
WinBox Tip: F6 works as ALT+TAB | Gliffy.com - free network schematic | prnt.sc - free ScreenShot software
I will be at MUMEUROPE Prague on ?? ?? 202?
raffav
Sat Mar 19, 2016 1:46 am
Hello
can any one have any clue what about this error
Beone
Sat Mar 19, 2016 3:47 pm
flashing haps with netinstall 6.34.3 and 6.34.3 packages doesn't work.
Trying to flash haps with netinstall 5.26 and 6.34.3 packages however does work.
anuser
Sun Mar 20, 2016 11:20 am
I have a kind of small feature request for wireless-rep package:
- Can you add the user name that is used by the wifi clients to CAPsMAN view?
Njumaen
Re: v6.35rc [release candidate] is released, new wireless package! Small feature request
Sun Mar 20, 2016 2:06 pm
Another small feature request: possibility to disable/enable single CAPsMAN's configurations
Thanks,
Ralf.
RafGan
Sun Mar 20, 2016 11:36 pm
I can confirm this issue. Two laptops Le... WiFi cards this same of type (first Win7, second Vista), 4 diffrents RBs and one this same problem (2,4GHz and 5GHz). Atheros card at the same time works fine on all of used RBs. Tested on rc33.
Regards, RafG.
Right now my daughter is telling me, that on her S6 is this same problem - I can confirm this, for sure, tomorrow.
Best Regards,
Raf G
Siona
Mon Mar 21, 2016 12:03 am
I have similar problem. On dual band AP (capsman) I have massive data loss on 5ghz. After switching 5g off everything works fine. Rc33, hap ac.
Edit
problem still persist in 2.4 but not so often.
whitbread
Mon Mar 21, 2016 9:58 am
My RB951UI constantly reboots every 10 to 11 hrs (watchdog enabled) due to lost connection to RB951G connected directly via ethernet. Both on RC32. No memory or cpu issue according to graphs. supout sent.
hedele
Mon Mar 21, 2016 11:00 am
I hoped that this might fix Ticket#2016031766000471 but unfortunately this just made it worse to the point that AT+CPIN? commands on the Huawei ME909s time out all the time, rendering the modem unusable as it is stuck in an initialization sequence loop. If I usb power-reset the modem, I get a response to AT+CPIN? once, but then the communication hangs at AT+CMEE=1 . I'll send in a supout.rif as well.
Quindor
Mon Mar 21, 2016 11:18 am
I too am having wireless client issues since running 6.35rc33. Using a hAP AC in CAPsMAN mode and my clients keep loosing their connection to the network, connection stays up, but not traffic locally or to internet possible anymore. Reconnect of the wireless link immediately solves it. Running 6.35rc22 before this all worked perfectly well.
In my CAPsMAN logs I see the following:
XX:XX:XX:XX:XX:XX@Access-point_1_1 disconnected, received death: unspecified (1)
It seems to mostly happen to my Intel N wireless laptop
http://www.campzone.nl World's Largest Outdoor LANParty, http://intermit.tech Intermittend Technology blog, My blog about the ESP8266, IP Camera's and other tech related subjects!
ivicask
Mon Mar 21, 2016 11:30 am
I have the same issue on Metal 2SHPn, running regular AP without CAPsMAN, all traffic simple stops, i cant even acces AP i get connection refused, turning on off wireless on my HTC phone fixes it, i was thinking its my phone issue..will get logs next time from router when it happens.
strods
Mon Mar 21, 2016 11:59 am
KentornoS - Your problem will be solved within RouterOS starting from 6.35rc34 version
strods
Mon Mar 21, 2016 12:21 pm
Version 6.35rc34 has been released.
*) capsman - added 802.11g/n band;
*) chr - added support for VLAN on Hyper-V;
*) hotspot - improved html page resistance against attacks;
*) l2tp & pppoe - fixed user traffic accounting when fastpath was used;
*) pppoe - fixed crash when removing <l2tp> pppoe service;
*) winbox - added init-delay option to routerboard settings;
*) winbox - added sfp-mac for GPON interfaces;
*) winbox - added support for route action in mangle rules;
heydude
Mon Mar 21, 2016 12:40 pm
I just loaded the newest rc Release on our Test equippment (6.35rc33).
-Central router (PC with x86 Router OS), acts as CAPsMAN Manager
-CAP (Groove A-52HPn) controlled by CAPsMAN
-Client (Groove 52HPn) set in station mode as client
First I tryied to test all available frequency modes on the AP without CAPsMAN.
2.4GHz-B/G/N and 5GHz-A/N are both working fine.
If I enable the CAPsMAN control on the AP, it successfully gets all settings from the central router.
The 2.4GHz-B/G/N mode is still working fine with CAPsMAN
If I try to set 5GHz-A/N mode in the CAPsMAN profile, the AP gets the settings and looks ok, but the client can not find any 5GHz network.
Why 5GHz is working in standalone AP mode and not if controlled by CAPsMAN?
uldis
Mon Mar 21, 2016 1:09 pm
heydude, what country setting you have specified in the CAPsMAN configuration as it selected 5740mhz as a center channel?
uldis
Mon Mar 21, 2016 1:13 pm
Hello
It looks like the connection before the CAPsMAN and CAP was lost and CAP initiated a new connection to the CAPsMAN.
heydude
Mon Mar 21, 2016 2:11 pm
Thanks for the tip. The country setting is really the problem. In the configuration I set it to Switzerland. So, strangely it selects 5740MHz as center channel, which is not allowed. If I set country to Germany it selects something like 5180, then it works fine. So, there might be a frequency table problem in the country settings.
Hope this will be fixed soon...
raffav
Mon Mar 21, 2016 4:12 pm
what is the usage of this new action ?
like a round-map on Cisco ?
juanvi
Mon Mar 21, 2016 7:40 pm
Cant' find:
[juanvi@xxx] /caps-man> configuration set channel.band=
2ghz-b  2ghz-b/g  2ghz-b/g/n  2ghz-onlyg  2ghz-onlyn  5ghz-a  5ghz-a/n  5ghz-a/n/ac  5ghz-onlyac  5ghz-onlyn
RafGan
Tue Mar 22, 2016 12:20 am
Next problem with wireless-rep and 6.35rc: point to point - one bridge with eth & wlan on both sides. Two VLANs on bridge, one of them is a multicast VLAN (IPTV, IGMP on switch connected to AP), second VLAN is an unicast VLAN. When STB is off, unicast works really great - about 160Mbs (AC mode, tcp speedtest on PC), but when STB is turning on, all trafiic goes down to minimal rate (max 6Mbs). Almost no access to AP, station RX & TX rates looks good (866Mbs) but on AP, TX is 6Mbs. Telnet waits "for a caffe", winbox too. Revert back to 6.34.2 and CM2 - all works OK on this same configuration (from a long, long time on A/N and AC devices).
I was trying: /system routerboard upgrade, multicast helper, multicast buffering, bridge filters, wireless channels and wireless channel width, wireless NV2, nstreme, 802.11 - nothing better. On eoip tunnel is ok (6.35RC) -but I don't like it with IPTV.
Any ideas?
Regards,
RafG
Best Regards,
Raf G
Siona
Tue Mar 22, 2016 7:44 am
Problem with disconnecting wifi under capsmana with Intel cards introduced in rc33 is still persist in rc34. It occurs less frequently. I noticed it only once whole yesterday evening.
iakor
Tue Mar 22, 2016 10:03 am
Good day!
With wireless-rep package there is a problem: http://forum.mikrotik.com/viewtopic.php?t=81750#p528087
I have trouble with connection to router - time after time connection is interrupted (i can not ping, winbox disconnects after less then 10 min), but wifi is not (i did not see any messages with "wireless" in log).
I tried to understand root cause:
I did reconfigure my router - WiFi interface configured only like AP (internet is on ethernet interface) - i still gots disconnects from WiFi.
I do not change configuration of the router, but disabled wireless-rep package and enabled wireless-fp package - and WiFi becomes stable (i did not lost pings, winbox connected a long time.)
I updated to the last release (6.35rc34 (testing)). But the result is the same - From time to time router disconnects.
strods
Tue Mar 22, 2016 10:53 am
juanvi - Do you use wireless-rep package?
juanvi
Tue Mar 22, 2016 10:58 am
Using cm2
darkprocess
Tue Mar 22, 2016 11:01 am
Same issue here with the rep package
strods
Tue Mar 22, 2016 11:28 am
You must have at least 635rc34 and wireless-rep package on CAP device and also on CAPsMAN:
*) wireless-rep - added 802.11g/n only band;
Cha0s
Tue Mar 22, 2016 12:27 pm
Any news about mAP Lite clock drift?
http://forum.mikrotik.com/viewtopic.php ... 31#p527731
http://forum.mikrotik.com/viewtopic.php ... 80#p527880
strods
Tue Mar 22, 2016 3:16 pm
Version 6.35rc35 has been released.
*) chr - fixed kernel crash when virtual ethernet was not connected to anything in Hyper-V;
*) chr - implemented kernel crash saving to autosupout.rif (will utilize additional 24Mb of RAM);
*) romon - fix romon discovery after of romon ID change;
*) userman - fixed www crash;
*) wireless - fix crash on nstreme-dual interface stats update;
kometchtech
Tue Mar 22, 2016 4:26 pm
Flapping to and to apply RB3011 to the ROS35rc35 interface.
And trying to get the supout.rif file at the same time, it is LCD display buggy restarted without permission.
[Ticket#2016032266000631]
juanvi
Tue Mar 22, 2016 6:07 pm
What a small changelog with big (for me) things inside! I thought would never come! Can't wait for testing!
_______________________________________________________
 by strods » 22 Mar 2016, 10:28
Running 6.35rc34 with cm2 package I've found the gn mode under capsman provisioning but is missing under config:
[juanvi@xxx] > caps-man provisioning set hw-supported-modes=
a  a-turbo  ac  an  b  g  g-turbo  gn
Can explain it better please?
Siona
Tue Mar 22, 2016 10:05 pm
Still the same - disconnecting laptop with intel card.
strods
Wed Mar 23, 2016 11:49 am
Version 6.35rc37 has been released.
*) chr - fixed Hyper-V booting from SCSI;
*) chr - fixed Hyper-V on windows 8/10 reboot loop;
*) chr - implemented automatic storage increase on disk image size increase;
*) chr - no more installation on first boot;
*) lte - supported modems now use unsolicit events for network monitoring;
*) rb3011 - fixed high cpu load breaks ethernet stats;
*) rb3011 - fixed link down messages;
*) winbox - hotspot default-trial user shows profile as "unknown" in Winbox;
Siona
Wed Mar 23, 2016 12:03 pm
What about disconnecting issue?
kometchtech
Wed Mar 23, 2016 12:10 pm
Just my environment has confirmed the phenomenon might end up flapping from the ether6 to the ether10 interface.
Routerboard:RB3011
ROS6.35rc37
My best regards.
hedele
Wed Mar 23, 2016 1:53 pm
Unfortunately, this still breaks compatibility with Huawei ME909s (Ticket#2016032166000454)
jdsousa
Version 6.35rc37
Wed Mar 23, 2016 3:54 pm
When I install Version 6.35rc37 x86 and when HD boot gives kernel panic and can not start the system again.
Thanks.
strods
Thu Mar 24, 2016 9:23 am
Version 6.35rc40 has been released.
*) bonding - fixed crash when creating vlans on bonding interface;
*) bonding - fixed mac-address disappearance after reboot in specific setups;
*) chr - fixed reboots with license and queues;
*) fastpath - improved vlan fastpath;
*) map lite - added hardware WPS button support;
*) ppp - fixed ppp interface reconnect when uPnP was used;
*) quickset - fixed situations when hidden password was passed as ******* from winbox and webfig;
*) quickset - fixed wan interface selection on CCR1009-8G-1S-1S+;
*) quickset - use 5Ghz interface instead of 2GHz interface on SXT Lite5 ac;
*) routing - fixed routing-marks were not erased from memory when they are not being used;
strods
Thu Mar 24, 2016 9:24 am
Version will require at least Winbox 3.4:
http://forum.mikrotik.com/viewtopic.php?f=21&t=106142
strods
Thu Mar 24, 2016 12:27 pm
Version 6.35rc41 has been released.
*) quickset - fixed invalid date adjusted the signal threshold for the signal chart and refresh rate;
nkourtzis
Thu Mar 24, 2016 1:39 pm
After upgrading, the option has dissapeared from routerboard settings.
Passionate about networks
Enthusiastic about Mikrotik
MTCNA | MTCRE | MTCINE
No trees were killed to send this message,
but a large number of electrons were terribly inconvenienced.
pietroscherer
Trainer
Trainer
Thu Mar 24, 2016 1:56 pm
Thanks especially for RoMON fix :D
Pietro Scherer
http://www.tchesolutions.com.br [ISPs Consulting and Training]
http://www.routermage.com [Backup and Automation System]
:D
strods
Thu Mar 24, 2016 2:35 pm
nkourtzis - At first we implemented checkbox. Afterwards we improved it and now it shows up only on devices which has this feature.
kometchtech
Thu Mar 24, 2016 2:41 pm
It does not resolve the behavior to flapping at the RB3011 interface.
[Ticket #2016032466000172]
Siona
Thu Mar 24, 2016 2:50 pm
Still problem with rep package with disappearing wifi access (wifi interface shows as connected but not work).
darkprocess
Thu Mar 24, 2016 2:58 pm
Same here. Connected but no traffic. Has to disconnect and reconnect
strods
Thu Mar 24, 2016 3:10 pm
Version 6.35rc42 has been released.
*) chr - fixed bridge firewall;
*) chr - make shutdown request from hyper-v work (might fix other hypervisor as well);
*) dude - fixed dude login logging, no more shows as winbox login;
*) timezone - fixed reboot by watchdog when selecting timezones from the end of list
Siona
Thu Mar 24, 2016 3:15 pm
Where can I find previous version of rc files? Need 6.35rc19.
Zorro
Long time Member
Long time Member
Re:
Thu Mar 24, 2016 10:37 pm
http://download2.mikrotik.com/routeros/ ... e-6.19.zip ?
Siona
Fri Mar 25, 2016 12:37 am
Thanks!
bajodel
Long time Member
Long time Member
Fri Mar 25, 2016 1:11 pm
..[CUT]..
Version 6.35rc42 ..port flapping on 3011 persist (ports 6-10), device unusable
mszulc
Fri Mar 25, 2016 8:31 pm
I had the same 'non working' wifi problem as described by others with rep package.
End user device works good for some time and suddenly looses connectivity while showing wifi as connected. Simple disconnect/connect solves the problem for some time (5-10 minutes). If left with no intervention for some time the connectivity comes back in a few minutes - and this cycle happens again.
Revert to cm2 solves permanently.
Tested on 2011 and hap ac for 2 and 5 ghz with wpa2 psk, local config, no capsman.
I'm not sure but I feel like this mostly happens (or is more frequent) on iOS devices, but this could be not true - more testing required.
benoga
Fri Mar 25, 2016 9:27 pm
i can confirm the wifi disconnect some times with all our 4 android devices. router is ccr1009 with capsman to hap ac wifi. look like not only iOS problem.
installed version 6.35rc42 rep package.
Beone
Sat Mar 26, 2016 1:24 pm
V6.35rc42 with cm2 package and capsman also results in regularly wifi latency spikes to 1 sec and 2 seconds.
Reverting back the CAPSMAN to v6.34.3 while leaving the caps on v6.35rc42 resolves this latency spike issue. We use centralised forwarding on CCR
Cha0s
Sat Mar 26, 2016 2:01 pm
..[CUT]..
Also confirmed here.
Downgraded back to 6.35rc29 and the problem was resolved.
bajodel
Long time Member
Long time Member
Sat Mar 26, 2016 2:27 pm
I'm quite new to 3011 so I went back to 6.34.3, flapping resolved but I've encountered some strange 'loop' alert on bridges witch have VLANs (temp "bad fixed" moving VLANs onto real interfaces instead of bridge ones)
Thanks Cha0s for hint ..since I'm actually on lab testing, I can move to 6.35rc trunk again stopping at rc29 (for now).
Also, I cannot succeed in partitioning my lab 3011, probably a known issue but better to note here..
IntrusDave
Re: Re:
Sun Mar 27, 2016 5:40 am
actually...
http://download2.mikrotik.com/routeros/6.35rc19/all_packages-mipsbe-6.35rc19.zip
change the "mipsbe" to the platform you need.
David Joyce
Network & Security Engineer
Intrus Technologies, LLC.
Rancho Cucamonga, CA, USA
KBV
Mon Mar 28, 2016 9:13 am
CRL do not work correctly
Self-signed certificates do not contain CRL when working through winbox - CRL field not available.
When signing via CLI this is no problem.
But CRL is still not working correctly when you export / import the certificate- then CRL contains inappropriate information.
Zorro
Long time Member
Long time Member
Re: Re:
Mon Mar 28, 2016 12:41 pm
actually...
yeah, right. i just picked MIPSBE because probability and propagation between gear.
year later that might be "ARM", for example.
nkourtzis
Tue Mar 29, 2016 4:04 pm
Requests for CAPsMAN bug fixes and new features, based on my experience with the current RC version:
1. {Nice to have} Add "CCQ", P Throughput" and "Signal to Noise", "Encryption" and "Group Encryption" and "WMM Enabled" fields to CAPsMAN Registration Table.
2. {Feature} Add "Frequency Mode", "WMM Support", "Multicast Buffering", "Keepalive frames", "Adaptive Noise Immunity" and "AMPDU Priorities" to CAPsMAN Config Settings.
3. {BUG} Make "Multicast Helper=full" in CAPsMAN slave interfaces work (now the interfaces stay in default setting).
4. {BUG} Make "Country=no_country_set" work on CAPsMAN 5GHz 802.11ac interfaces (it works on 2.4GHz, but on 5GHz ones it results in "no supported band" error message, regardless of the band and frequency settings).
5. {Feature} Add a scan/freq usage feature in CAPsMAN, with an aption to run in the background. Right now, if one wants to scan, they have to detach the physical interface from the Manager, do the scan and re-attach it. [In the future, use this info to auto-adjust CAP channels and power levels.]
6. {Annoying} Stop CAPsMAN from creating virtual interfaces on CAPs with name "wlanXXX" where XXX is a number which is incremented every time the interface is disabled and re-enabled.
7. {Nice to have} Let the user rename the virtual interfaces on the CAPs, like he/she can do with physical interfaces.
m94646602
Tue Mar 29, 2016 6:05 pm
+1 +1 +1 Band Steering. Many times, I often need to complete the work by hand. :( :( :(
diorges
Tue Mar 29, 2016 9:50 pm
MikroTik dont recognize ospfv3 bits from edgerouter, mikrotik should ignore unrecognized bits and process the packet normally as decribed in the RFC,
Look at RFC https://tools.ietf.org/html/rfc5340#appendix-A.2
napismizpravu
Tue Mar 29, 2016 11:59 pm
6.35rc42 - RB433UAH (power 24V 2A)
uptime 5 days error system ...crash proxy, drive disk add duplicate USB1 ...FTP to USB1 void...ftp to disk6 contents USB1
reboot RB433UAH disk OK... disk6 disappeared, USB1 functional
jondavy
Wed Mar 30, 2016 7:40 am
+1
and too, show Radio-name(for mikrotik stations), Distance, Traffic graphic, signal-sthrength table,ping, mac-ping, torch, mac-telnet buttons
bug: in winbox gui, on wireless interface, not show button CAP if package wireless-cap is not installed/enabled
bug: in winbox gui on interfaces in the "+" button rename the latest interface type for "interfaces" to "Controlled AP, or CAP"
strods
Wed Mar 30, 2016 11:18 am
Version 6.35rc43 has been released.
*) fastpath - fixed show rx-bits-per-second on all VLAN interfaces;
*) nand - implemented once a week nand refresh to improve stored data integrity (will increase sector writes);
NetworkPro
Wed Mar 30, 2016 11:38 am
Also for USB Flash in x86 ?
wiki.mikrotik.com/wiki/NetworkPro_on_Quality_of_Service
macgaiver
Wed Mar 30, 2016 11:41 am
uuuu...
looks like v6.35 suddenly become my new favorite version.
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
slv
Wed Mar 30, 2016 12:12 pm
Hi
I have 3011 and strange issues with port based VLANs [Ticket#2016031766000506] - could someone confirm same problems?
I have separate topic for that problem http://forum.mikrotik.com/viewtopic.php?f=2&t=106049
Regards
Slawek
sam1275
Wed Mar 30, 2016 1:52 pm
When will this version become release?
uldis
Wed Mar 30, 2016 6:10 pm
What setup you have on the CAPsMAN for the CAP interface?
What is your wireless client and what OS you use?
Beone
Wed Mar 30, 2016 9:10 pm
when upgrading back to v6.35rc42 to try to reproduce, we didnt see the same behavior anymore.
CAPSMAN platform: ccr1009
caps: rb951g/rb951ui/hap ac lite
client: MacOS 10.11.4 - macbookair 7,2 - Broadcom BCM43xx 1.0 (7.21.95.175.1a6)
diorges
Wed Mar 30, 2016 10:16 pm
@strods
And what about the problem with OSPFv3 with EdgeRouter, mikrotik reject EdgeRouter OSPFv3 because of a flag AF which EdgeRouter sends, but in RFC says that unrecognized bits should be ignored.
ofca
Thu Mar 31, 2016 7:09 am
Was central user control/access point protection/locking from capsman already suggested?
It's kinda boring to login to 40+ access points to password protect them. ;)
Awax
Thu Mar 31, 2016 1:07 pm
FastTrack doesn't work at RB750G.
strods
Fri Apr 01, 2016 10:04 am
Version 6.35rc44 has been released.
*) chr - try to renew expired license once a hour instead of 100h;
*) defconf - fixed default configuration for SXT LTE;
*) lte - improve situation when SXT modem never finds operator;
*) lte - supported modems now use unsolicited events for network monitoring;
*) rb3011 - make ether6-ether10 work if SFP module is present on bootup;
*) trafficgen - fixed console arguments;
PatrickKan
Fri Apr 01, 2016 12:11 pm
There is a serious bug introduced in rc44 for my CCR1036. After upgrade reboot, the L2MTU values for both sfp+ ports changed to 1580 from their original values of 9014. To make matter worse, neither Winbox nor console allows you to change the L2MTU back to their original values.
strods
Fri Apr 01, 2016 3:05 pm
Version 6.35rc45 has been released.
*) hotspot - make video tag work properly on hotspot login.html page
*) ipsec - fixed crash on policy update;
*) ppp - fixed ppp crash if lcp packets were lost and authentication got delayed;
RafGan
Fri Apr 01, 2016 11:08 pm
My two STX 5AC are death after upgrade to this version! No access, so no suppot.rif. Tomorrow netinstall.
Best Regards,
Raf G
nz_monkey
Fri Apr 01, 2016 11:58 pm
Since rc42 our test CCR1036 has stopped on "starting kernel" when rebooting after the update.
fallenwrx
Sat Apr 02, 2016 1:51 am
same issue, upgraded from 6.35rc44 to 6.35rc45, fails to boot falls back to backup partition
mkorban
Sat Apr 02, 2016 6:29 am
same issue with 91xG 2HPnD
After the update the router is unavailable.
netinstall not help restore operability
reset is also not effective - sound can be heard, blinking LEDS forming, but a router is not available.
cREoz
Sat Apr 02, 2016 11:33 am
On update from 6.35rc43 to 6.35rc45 my RB951G-2HnD got boot-loop :?
How i can recover him?
mistry7
Sat Apr 02, 2016 12:09 pm
On my CRS too, need to netinstall
Shak7
Sat Apr 02, 2016 12:58 pm
Same thing here with RB2011UiAS-2HnD-IN. Tried many times to Netinstall. The router always tries Ethernet boot, fails then says kernel failure before rebooting itself.
raffav
Sat Apr 02, 2016 5:39 pm
same thing on BASEBOX2 and RB450G
on RB450 using serial pot i get the kernel panic information that no system found
so i think that when start the process uninstalling the old one an installing the news on it crash so there is no system at all
via netinstall i was able to put rc45 up with no problem
RafGan
Sat Apr 02, 2016 8:03 pm
Netinstall to 6.34.4 - works good again :D
Best Regards,
Raf G
easyspot
Sat Apr 02, 2016 8:23 pm
Last time using 6.35rc, ended with link dead for 1 day. Must do netinstall on both side. Now using 6.32.4 to keep out of trouble. No more rc version for me :D
Shak7
Sat Apr 02, 2016 9:01 pm
Worked flawlessly with Netinstall 6.34.4
Thanks to Raf G ! :D
Cha0s
Sun Apr 03, 2016 11:04 am
Does this resolve the port flapping issue that appeared on some rc after rc29?
If yes, did anyone manage to upgrade to the latest rc without 'bricking' their board?
There are a few reports not being able to boot afterwards.
Florian
Sun Apr 03, 2016 9:02 pm
I'm staying on rc43, rc45 seems risky...
upower3
Sun Apr 03, 2016 11:10 pm
Well, (at least) on weak devices like hAP lite I used to see 0 volts as voltage. Very sad to see that:
http://prntscr.com/anqej6
But as far as I know this is not even this RC problem. Any fix to come?
By the way when it comes to voltage if it is possible to see which power source is used on more powerful devices that have both PoE-in and power source? I'd be pretty happy to see "voltage" and "Power input" as two separate value (to have it in SNMP will be the best idea, great to monitor the power source health).
bajodel
Long time Member
Long time Member
Mon Apr 04, 2016 2:03 am
My lab rb3011 is working flawlessly with this new rc ..port flapping fixed
mbfound
Mon Apr 04, 2016 5:36 am
Anyone lose wireless on 6.35rc45?
It completely disappeared on a 951Ui-2HnD. Reboot and resetting didn't help. Downgrading to stable fixed it.
Upgrading to RC again now to see if it happens again.
IntrusDave
Mon Apr 04, 2016 5:53 am
Not here. I have 3 RB's with wifi running with no issue.
David Joyce
w0lt
Long time Member
Long time Member
Mon Apr 04, 2016 5:55 am
Upgrading to ROS v6.35rc45 has caused so many problems (bricking units), packages missing that I have spent the past few days just cleaning up the mess.
I have downgraded all but one router (that I can't reach now) to v6.34.4. So far, so good.
I realize this is rc revisions but is someone at Mikrotik deliberately trying to sabotage the firmware? :(
Think I'll stick with non-rc for a while till I'm convinced Tik is releasing nonvolatile firmware.
MTCNA - 2011
" The Bitterness of Poor Quality Remains Long After the Sweetness of Low Price is Forgotten "
PeterDoBrasil
Mon Apr 04, 2016 6:03 am
yes, rc 45 is very problematic
nkourtzis
Mon Apr 04, 2016 8:56 am
Keep in mind that is is called release CANDIDATE, that is, not released yet. If you want stability, stay with the stable version.
whitbread
Mon Apr 04, 2016 11:08 am
Sure but RC is not Test; so a bricked unit is not be expected usually...
If something is not working you rather expect to downgrade to your last working version and not to start from scratch.
PatrickKan
Mon Apr 04, 2016 11:18 am
I tried both 6.35r44 and r45 on my ccr1036 and crs226. Here were the combinations of problems:
6.35r44:
1. On CCRr1036 - it messed up the MTU and L2MTU values for both SFP+ ports and broke both SFP+ links. The worst of all, neither Winbox nor console was able to restore the original L2MTU values.
2. On CRS226 - it sent the unit into bootloop after reboot and netinstall had to be used to restore to older releases.
6.35r45:
1. On CCRr1036 - it messed up the MTU and L2MTU values for both SFP+ ports and broke bothl SFP+ links. The worst of all, both Winbox and console were unable to restore the original L2MTU values.
2. On CRS226 - it didn't cause bootloop.
I am back to 6.35r43 now.
Hope it helps.
juanvi
Mon Apr 04, 2016 11:19 am
I disagree: For me RC=TEST
normis
Mon Apr 04, 2016 11:24 am
RC are essentially "Nighty Builds", don't rely on them in important networks.
whitbread
Mon Apr 04, 2016 2:27 pm
No problem for me apart from the naming. I am a SOHO user only and nobody else than me is relying on my infrastructure.
vortex
Mon Apr 04, 2016 2:39 pm
Then they are not RC. Similar naming problem as "Current".
notToNew
Mon Apr 04, 2016 2:55 pm
Right! Current RC-Branch should go to "development"...
vortex
Mon Apr 04, 2016 3:14 pm
And I am thinking "Current" is maybe 2 things in one: Feature + RC
Nightly -> Beta -> RC -> Feature -> Bugfix
kometchtech
Mon Apr 04, 2016 3:38 pm
+1
macgaiver
Mon Apr 04, 2016 3:43 pm
Each developer of software have it's own unique way to classify software releases.
Big thanks to MikroTIK to transfer to 3 stage release (RC, Current, bugfix) it is sufficient for all my needs.
I'm testing new RC mainly because of
i have upgraded ~50 oldest devices in the network and it looks like 4 of them was too far gone, so netinstall was necessary, after it all devices worked perfectly, i was even able to keep config on all of them. Anyone else have noticed something similar? after v6.35rc43
nkourtzis
Mon Apr 04, 2016 4:25 pm
My experience was similar. Two out of around 40 devices were "bricked" by RC45, requiring a netinstall. One of them (a RB2011UiAS-RM) stuck on reboot and when power-cycled it came up but the system was corrupted (it was not even reporting a ROS version) but basic (hardware) interfaces and bridges were working. Not the ppp ones though. The other one, a hAP AC, was bootlooping no matter what. Retaining the current config during netinstall worked, at least in the hAP AC (for the other one I had kept a config file).
One other thing that I noticed (not related to the above problem) was that when all three chains are enabled on the 2.4GHz interface of the hAP AC, not all devices can associate. For example two phones, one with Android and the other with Windows Phone could not connect. When I turned off chain 2 (the third chain) devices which were not associating before, could connect successfully. Same with chain 1, although sync speeds seemed to be lower in this case. The 5GHz interface does not seem to have such a problem. I think (I am not sure though) that this is something that occured lately. Unfortuantely, it was not reported earlier so I cannot give any further info. But my observation above was made yesterday.
vortex
Mon Apr 04, 2016 5:06 pm
Given by the regressions and the number of iterations on the Current stream, I would say it is Beta+Feature, actually.
Which would be more damning evidence of the bad RC naming.
vortex
Mon Apr 04, 2016 5:29 pm
Basically:
- Almost all the fixes in the Current stream should be for new features or bugs still present in Bugfix.
- Most of the time RC should move to Current with 0 or 1 iterations.
BartoszP
Mon Apr 04, 2016 5:31 pm
It is much, much better than older approach.
Real admins use real keyboards.
vortex
Mon Apr 04, 2016 5:39 pm
But it seems it is still not good enough for some people who can't just stay on Bugfix.
vortex
Mon Apr 04, 2016 5:56 pm
Actually, there should be 2 real RC streams, one for Bugfix, and one for Current.
macgaiver
Mon Apr 04, 2016 6:00 pm
Vortex and co. You can't keep everyone happy, and you never will.
Please, find the old topic about the release system and post your feelings about it there. Hijacking technical topics only delays the problem solving.
vortex
Mon Apr 04, 2016 6:07 pm
Yes, people can be made happy.
The current release approach is still bad compared to the typical lifecycle of popular products and projects.
RyperX
Mon Apr 04, 2016 6:12 pm
I also had the problem that the router couldnt reboot after the update (2011UiAS-2HnD)
Unplugged power and after replug the router startet.
I know it was my fault that i didnt checked the forum before installation but i dont understand why mikrotik still deliver this update when there are much more problems then normal.
It would be enough to disable the update and wait for next release.
juanvi
Mon Apr 04, 2016 6:53 pm
Stop this debate and enjoy RC releases! Feel proud yourselves because you're helping Mikrotik in making best networking products ever seen! They let us be a part of the developement with the RC channel! As the others do? ;-)
RafGan
Tue Apr 05, 2016 12:43 am
That is true. If you install RC, you must think about risk and revert back to working versions in unusually issues. My SXTs are on top of the roofs - no such a big thing with it - 30 minutes per one, but I can tell people on this forum, that something wrong is with this version of ROS RC. Next RC will be installed on my home MT, then on SXTs. I don't know other marks that releases RC firmwares. Maybe MT should do RC for registered RC/beta testers?
Best Regards,
Raf G
vortex
Tue Apr 05, 2016 1:41 am
The problem is not that it is RC, but that it is NOT.
It is not even beta, because Current is beta-level, IMHO.
pbr3000
Tue Apr 05, 2016 3:37 am
I need to echo macgaiver: go to the right topic (or create a new) and post your complains in there. No offenses, just to don't mess up this topic.
And to all who are experiencing bugs: send your reports to support@mikrotik.com because (repeating mikrotik staff) this forum is officially "from and to" mikrotik users only.
My latest bug report was:
From 6.34 changelog:
*) snmp - add oid from ucd mib for total cpu load OID 1.3.6.1.4.1.2021.11.52.0;
And this oid don't works anymore on the v6.35rc42 (CCR1009) and above. Untested in prior 6.35rc versions.
I had some lab gears bricked too on v6.35rc45, but I don't sent bug reports because it should be too obvious to mikrotik team.
vortex
Tue Apr 05, 2016 4:24 am
I already created a new topic, but people keep discussing the issue here instead.
paoloaga
Tue Apr 05, 2016 11:50 am
Too many branches encumber the devs. I think that actual situation is far better than before, we should just understand the naming convention used by MT or maybe they can just change it:
RC => Development
Current => Latest features
Bugfix => Long Term/Stable
I am very happy about the new management of software releases.
strods
Tue Apr 05, 2016 1:27 pm
Version 6.35rc46 has been released,
*) lcd - fixed branding packet logo drawing on startup;
*) lte - replaced signal-strength with rssi in info command;
*) nand - fixed reboot loop after upgrade to >v6.35rc43;
*) ppp - fixed some clients can not connect due to LCP restart;
*) tool fetch - fixed https cleanup on user stop while handshaking;
*) winbox - make build with latest lte changes;
*) wireless-rep - fixed latency issues with Intel 2.4GHz wireless clients
napismizpravu
Tue Apr 05, 2016 3:39 pm
RB433UAH (power 24V 2A) upgrade 6.35rc43 > 6.35rc46 = netinstall (karnel panic)
netinstall all_packages-mipsbe-6.35rc46 working
Siona
Tue Apr 05, 2016 3:57 pm
same here. after downgrade to 6.34.4 and installing 6.35 rc46 working fine util usb lte (3372) connecting.
BartoszP
Tue Apr 05, 2016 5:11 pm
RB411 .. no problems
raffav
Tue Apr 05, 2016 6:01 pm
Is any one having problem with vlan/trunk on the RC46? on CRH?
PeterDoBrasil
Wed Apr 06, 2016 5:07 am
I threw my router in the trash, 2011UiAS-2HnD :(
IntrusDave
Wed Apr 06, 2016 5:21 am
LOL haven't heard about Netinstall?
David Joyce
2frogs
Long time Member
Long time Member
Wed Apr 06, 2016 6:23 am
I have 2x 951Ui-2HnD that are non-responsive after updating to v6.35rc45. One of them came back up partially, it had the the entire RoS Package disabled in it. I made a supout.rif and re-enabled the package and now it is completely non-responsive.
pbr3000
Wed Apr 06, 2016 7:16 am
:? The v6.35rc45 was especially bugged...
rzirzi
Wed Apr 06, 2016 7:48 am
RC46 i VERY problematic after update...
After automatic update under "check for updates" at my RB493G (mipsbe-separate packages) - some packages gone, only "system" has upgraded to rc46, i have had to power unplug/plug to make it working, then put missing rc46 packages at winbox. VERY problematic is version RC46!
strods
Wed Apr 06, 2016 12:11 pm
Version 6.35rc47 has been released.
*) tile - fixed performance regression on switch chip (introduced in 6.33rc18);
*) tile - fixed l2mtu change (introduced in 6.35rc);
strods
Wed Apr 06, 2016 1:08 pm
Everyone who is still experiencing issues with upgrade/downgrade. In version 6.35rc46 we introduced fix:
This fixed reboot loop, but you have to remember that within upgrade you can not have rc43-rc45 version involved. For example, upgrade from rc45 to rc46 could still crash because you try to upgrade from problematic version which does not have this fix included.
Florian
Wed Apr 06, 2016 5:06 pm
So if we are in rc43-45, we have to downgrade first ?
mistry7
Wed Apr 06, 2016 5:42 pm
no, best way is to use netinstall
macgaiver
Wed Apr 06, 2016 6:09 pm
Correction, use regular update, but keep netinstall nearby.
I re-upgraded my 40 devices to the latest build and all of them were fine. (first time around there were few that needed Neinstall, but they were running 6.7-6.9). So might be NAND memory issue, that that fix is designed to solve (it periodically reads and re-writes sectors, to ensure data integrity, so we can assume there were devices that lost integrity already)
jondavy
Wed Apr 06, 2016 6:16 pm
please add CCQ column in caps-manager in registration-table,
I just need this vital information to be able to migrate all my sectors of my wisp to CAP
to be able to control the CCQ of customers quickly
strods
Wed Apr 06, 2016 6:48 pm
Version 6.35rc48 has been released.
*) address-list - fixed crash in low memory situations;
*) dhcp6-client - fixed wrong error message;
*) mipsbe - (excluding RB4xx and CRS series) fixed rare ethernet tx buffer corruption;
*) wireless-rep - fixed latency issues with Intel wireless clients;
ka4opi4a
Wed Apr 06, 2016 8:45 pm
Just broke my HAP AC after upgrade from previous rc version. I don't have much time, but I have no luck with net install. Also not discoverable over winbox. Please help...
jarda
Wed Apr 06, 2016 10:07 pm
When everyone who bricked a device by update would send it to mikrotik back for warranty repair, it would make mikrotik to think and test twice before releasing harmful versions to public.
ka4opi4a
Wed Apr 06, 2016 10:28 pm
Just manage to net install it somehow... And install 6.35rc48. It's working normall, but the wifi speed on the 5 ghz using intel 7260ac is just like on the current channel. With the previous rc the speed was really good ~ 400 mbps.
Siona
Wed Apr 06, 2016 11:52 pm
RB 433GL - not working when USB LTE modem connected - H3372 HiLink.
Florian
Thu Apr 07, 2016 12:30 am
Well I just upgraded the normal way from rc43, no problem on my ccr1009.
I'm lucky I guess.
notToNew
Re:
Thu Apr 07, 2016 9:25 am
I hope that they pay no cent for sending in a device which is bricked because you installed a nightly build.
Just stay at the current version unless you are willing to learn how to use netinstall.
mahury
Thu Apr 07, 2016 9:40 am
Thanks to all, that mikrotik made from 6.2 to 6.32 & 6.34.4 . There is some great impruvements of stability was made.
I also has problem with 6.35 rc44 or rc45 on my 951G with boot loop.
It was fixed with netinstall & some PXE server.
Now I am on 6.34.4 and do not shure to go back to RC.
Can be PXE server be integrated to netintall for easy recover? Or write some more in manual? For idiots.
abis
Thu Apr 07, 2016 9:55 am
Stay there until [stable] release :)
Image Image
Awax
Thu Apr 07, 2016 12:27 pm
Dear engineers of Mikrotik, it is possible to hope that you implement the work of "FastTrack" on RB750G :?:
jarda
Thu Apr 07, 2016 1:39 pm
I stay with bugfix only on productive devices considering the stable to be beta and rc to be alpha. Making tests in lab before any update and updating in vawes and only if really necessary. Using partitions on devices where it is possible to be able to boot the backup when whatever problem occurs after update. I don't remember any fatal accident due to update on productive devices I have ever made.
jondavy
Thu Apr 07, 2016 3:37 pm
if I change
/system logging action set 0 memory-lines=1000 name=memory target=memory
per
/system logging action set 0 memory-lines=10000 name=memory target=memory
the router works for a while, but after crashes, no more traffic goes by, so if I restart
the router hangs in all previous versions
tested RB2011UiAS
versions:
6.35rc42
6.34.4 (stable)
6.32.4 (bugfix)
edit:
after almost one days he again caught the traffic
when I open the terminal and try to ping a host appears (no buffer space available),
it seems that this was not
notToNew
Fri Apr 08, 2016 10:06 am
Did someone try to this new feature?
>> wireless background scan
I wanted to script a background scan for known Wifi-APs and if found, connect to it automatically.
The Microtik is in a car, and I know several Wifi along the road (while stopping the car!).
The Idea was: Scan for known ssid's (or MAC..) and if found one, set wlan2 to the known credentials.
macgaiver
Fri Apr 08, 2016 11:06 am
It IS supported on all RB7xx
nz_monkey
Fri Apr 08, 2016 12:13 pm
It works on our RB750GL but not on our RB750G
Awax
Fri Apr 08, 2016 1:47 pm
Yes, exactly so, 750 works 750G no
macgaiver
Fri Apr 08, 2016 3:10 pm
I found one :) on old board shelf, just betweer RB230 and RB532. :), Yes you are right, this board is using same CPU as RB4xx series, so fastpath is not supported. you need ar72xx CPU at least ar71xx doesn't have the support.
Awax
Fri Apr 08, 2016 3:46 pm
It turns out that it is possible not to hope that fasttrack will work at RB750G ? :( ЭХ Mikrotik... and I had hoped and believed...
derr12
Fri Apr 08, 2016 11:35 pm
Is there any word when/if ANI will get support in capsman?
yottabit
Sun Apr 10, 2016 11:18 pm
I'd really appreciate a working config that I can dig through to understand.
My other problem is finding a sequence of steps to get from the factory-default RBmAPL-n2D WISP AP configuration to one where the (only) Ethernet interface is on the LAN without losing Winbox connectability. (I can always use the magic button to restore the factory-default configuration, but then I'm right back where I started.) Once I'm controlling the router firmly through its Ethernet interface, I should be able to reconfigure the wlan interface without losing control.
Hi mccreigh. Sorry for the long wait, but I have finally completed the config and have it ready to share. Feel free to use and modify as-needed. Comments are written in the config that most should be able to understand with basic RouterOS and networking experience.
https://docs.google.com/document/d/1gdy ... YnDcLFv6aU
And here's the config for posterity's sake (but the Google Doc above allows Commenting and revisions, so check that if you would like to see if I've ever made any updates):
# RouterOS Hotel Setup
# Created 2016-04-10 by Jacob McDonald
# Revised n/a
# This config was built using a model RouterBOARD 962UiGS-5HacT2HnT (“hAP ac”).
# This router has 1x 2.4 GHz radio and 1x 5 GHz radio, but this configuration does not depend on two radios.
# This config uses the 2.4 GHz radio base interface in Station-Pseudobridge mode to connect to another Wi-Fi AP,
# and creates a Virtual AP virtual interface on top to serve 2.4 GHz stations. A 5 GHz AP is also configured, and
# the 5 GHz AP would provide better performance since the 2.4 GHz radio wouldn’t have to share air-time serving
# stations in AP mode and forwarding the traffic to the other AP in station mode.
# The split-mode radio configuration only works with RouterOS 6.35 (rc and higher), using the testing radio
# package “wireless-rep”. This package is not included in the main software package, but can be extracted from
# the extras package and installed a la carte.
# RotuerOS Software: http://www.mikrotik.com/download
# 1. Install the base package from System -> Packages, or by uploading the .npk to the root filesystem and reboot.
# 2. Extract the wireless-rep.npk package from the extras .zip archive, upload to the root filesystem, and reboot.
# 3. Third, upgrade the RouterBOARD firmware: System -> RouterBOARD -> Upgrade, and reboot.
# Change the wireless security profiles in “/interface wireless security-profiles” below:
#   default: set for your desired AP password (LAN)
#   wlan-WAN: set to the AP password for the Wi-Fi network you wish to use as WAN
#   none: this is a profile for using a Wi-Fi network as WAN with no authentication, typical in hotels
# Change between “wlan-WAN” and “none” security-profile as-needed by changing the setting in the
# “/interface wireless wlan1-WAN” config.
# Using the WebUI, Winbox, or CLI, perform Scan on the wlan-WAN interface, and select Connect to the AP you wish
# to use as WAN. This will adopt the frequency, bandwidth, and protocol settings automatically.
# This config will use the DHCP-supplied DNS servers from the WAN interface, which will be necessary to pass
# through the captive portal.
# apr/10/2016 20:31:47 by RouterOS 6.35rc48
# software id = XZFF-04CI
add name=bridge1
set [ find default-name=ether1 ] name=ether1-WAN
/interface wireless
set [ find default-name=wlan2 ] band=5ghz-a/n/ac disabled=no mode=ap-bridge name=wlan2-5G-LAN ssid="Magrathea 5G" wireless-protocol=802.11
/ip neighbor discovery
set ether1-WAN discover=no
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys supplicant-identity=MikroTik wpa2-pre-shared-key=h2g2h2g2
add authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys name=wlan-WAN supplicant-identity="" wpa-pre-shared-key=hdyfrc4la1 wpa2-pre-shared-key=hdyfrc4la1
add name=none
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n disabled=no distance=indoors frequency=2442 mode=station-pseudobridge name=wlan1-2G-WAN security-profile=wlan-WAN \
    ssid=skyconway_com-2231 wireless-protocol=802.11
add disabled=no keepalive-frames=disabled mac-address=E6:8D:8C:49:23:FA master-interface=wlan1-2G-WAN mode=ap-bridge multicast-buffering=disabled name=wlan3-2G-LAN ssid=Magrathea \
    wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
set wlan1-2G-WAN discover=no
/ip hotspot profile
add name=dhcp ranges=192.168.88.3-192.168.88.254
add address-pool=dhcp authoritative=yes disabled=no interface=bridge1 name=dhcp1
add bridge=bridge1 interface=sfp1
add bridge=bridge1 interface=wlan2-5G-LAN
add bridge=bridge1 interface=wlan3-2G-LAN
add address=192.168.88.1/24 interface=ether2 network=192.168.88.0
/ip dhcp-client
add default-route-distance=0 dhcp-options=hostname,clientid disabled=no interface=ether1-WAN
add default-route-distance=2 dhcp-options=hostname,clientid disabled=no interface=wlan1-2G-WAN
add address=192.168.88.0/24 gateway=192.168.88.1 netmask=24
set allow-remote-requests=yes
add chain=input protocol=icmp
add chain=input connection-state=established
add chain=input connection-state=related
add action=drop chain=input in-interface=ether1-WAN
add action=drop chain=input in-interface=wlan1-2G-WAN
add action=masquerade chain=srcnat out-interface=ether1-WAN
add action=masquerade chain=srcnat out-interface=wlan1-2G-WAN
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge1 type=internal
add interface=ether1-WAN type=external
add interface=wlan1-2G-WAN type=external
/system clock
set time-zone-name=UTC
/system identity
set name=rbtest
/system leds
set 1 interface=wlan2-5G-LAN
/system ntp client
# These are from us.pool.ntp.org
set enabled=yes primary-ntp=108.61.73.243 secondary-ntp=216.229.4.69
/tool mac-server
add interface=ether2
add interface=ether3
add interface=ether4
add interface=ether5
add interface=sfp1
add interface=wlan2-5G-LAN
add interface=wlan3-2G-LAN
/tool mac-server mac-winbox
add interface=sfp1
brwainer
Mon Apr 11, 2016 9:58 am
Although I have not tried any of the RC versions, I have been tracking the release notes and do want to echo this request. I opened a ticket about it on 3/2/15 (#2016030266001122) and was eventually told "We have though about it. We will see if not changing name/id is possible solution and if everything will run smoothly then soon enough we will release changes." on 3/7/15 - I am hoping this makes it into 6.35rc and then current. Specifically my request was to re-use the same wlanID # (and SNMP interface index #) every time the CAP reconnects to the manager.
Zorro
Long time Member
Long time Member
Mon Apr 11, 2016 10:23 pm
had weird issues with UPnP since 6.29 or later ~ in few online games, like BF4, Planetside 2(less frequent) and UT4.
without UPnP its works flawless.
not hard to reproduce, but time of issue after round - are vary/different/unpredictible.
(other customers report other games, especially PunkBuster-aware/supported, but i cannot reproduce their issues in same games. but few ones(like enumerated above) - had Very persistent disconnections in result)
fix:
conntrack issue, reported before - my error. impact of static ARP whitelisting/binding to netflow on mobile assets. resolved.
jondavy
Tue Apr 12, 2016 5:35 am
when I have many address-list enabled, more than 300, and on mangle one mark-routing them to, the router restarts after a few hours
tested on RB2011UiAS
edit:
in fact it does not restart, the traffic to, if I try to ping appears
no buffer space avaliable
I that activated the whatchdog that the address 127.0.0.1 so restarts,
and address-list are all IP blocks's large size /15 /17 /22
scampbell
Trainer
Trainer
Tue Apr 12, 2016 6:23 am
Why not use the existing wireless "connect list" feature ?
Simply set up a Connect List entry for each known ssid and associated security profile and leave the station SSID blank in the main screen. No scripting needed ?
Mikrotik will then try and connect to any AP that matches a Connect List entry.
MTCNA, MTCWE, MTCRE, MTCTCE, MTCSE, MTCINE, MTCEWE, Trainer
___________________
Mikrotik Distributor - New Zealand
http://www.campbell.co.nz
notToNew
Tue Apr 12, 2016 10:56 am
simply didn't understand this function! Thanks a lot for pointing me there, i will try it!!!
Siona
Tue Apr 12, 2016 11:20 am
RC48 - It seems that RX speed limit doesn't work on VAP rep package. TX limit works fine.
uldis
Tue Apr 12, 2016 12:48 pm
Version 6.35rc49 has been released.
Changes since previous version:
*) dhcpv6 client - fix ia expiration and lifetime validation;
*) dhcpv6 server - acquire binding on renew if it does not exist;
*) export - exclude default values from export in "/interface l2tp-server server" menu;
*) export - fixed rare situations when not whole config was exported;
*) leds - fixed AP-CAP led blinking after successful association to CAPsMAN;
*) lte - fixed crash on early initialization;
*) lte - use timer for modem info;
*) ntp - fixed ntp client hangs in reached state;
*) rb3011 - fixed sfp compatibility with CCR when using direct attached cables;
*) tunnels - fixed performance slowdown on any other tunnel disable/enable;
*) winbox - added "pw-type" to "/interface vpls bgp-vpls" menu;
*) winbox - added "use-control-word" and "pw-mtu" to "/interface vpls cisco-bgp-vpls" menu;
*) winbox - added mtu=auto support to eoipv6 tunnel;
*) wireless-rep - use full identity where possible;
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after crash.
Neilson
Tue Apr 12, 2016 12:55 pm
Hi uldis
can you please advise if this specific change is to address the reports that have come in over time with PPP concentrators experiencing packet loss when individual connections were disconnected?
If so this is a great improvement and I will look to people for testing on these larger concentrators (CCR's are particularly good for this).
If not, can you please advise what types of performance slowdown this does target?
Regards
Alexander
mrz
Tue Apr 12, 2016 12:57 pm
It is unrelated to ppp.
Problem appeared for example on GRE tunnels. Performance of one tunnel decreased after other gre tunnels were disabled/enabled.
Florian
Tue Apr 12, 2016 2:33 pm
I see a lot of works on dhcpv6 in recents RCs, which is a good thing.
Any timeline about adding options on the dhcpv6 client ? (like asked here : http://forum.mikrotik.com/viewtopic.php ... 81#p517695 ) ?
Thx.
MichaelTrip
Tue Apr 12, 2016 3:41 pm
how do i enable Fast Path on my PPPOE-client? I think it will give my RB2011 more throughput.
VagnerBecker
Tue Apr 12, 2016 4:10 pm
HI,
The Dude i can not upload images, .npk files, returns "invalid file"
Best regards,
Vagner Felipe Becker
jarda
Tue Apr 12, 2016 5:07 pm
Rc49 should contain correction for the [Ticket#2016031666000222] but nothing similar is mentioned in the release notes. Is it so or not?
ka4opi4a
Tue Apr 12, 2016 10:12 pm
Any news about fixing AC mode and Intel 7260 ?
florentrivoire
Tue Apr 12, 2016 10:33 pm
Thx.
I'm also interested in this new feature.
Thanks !
xuqianman
Wed Apr 13, 2016 9:13 am
in wireless-rep package,capsman could you add “bridge-mode” config support?
jarda
Wed Apr 13, 2016 11:01 am
When installed 6.35rc49 on RB941-2nd (nonTC), got this blue error in the log:
09:52:49 script,warning DefConf: Unable to find wireless interface(s)
There are no scripts at all. What does it mean? Why there should be running any default config script while the default config was long time ago fully wiped and everything was set manually?
mrz
Wed Apr 13, 2016 12:16 pm
Each time you upgrade, new defautl configuration file is generated, it doesn't matter if you wipe defconf or not.
uldis
Wed Apr 13, 2016 1:48 pm
This problem is already fixed in the latest rc wireless-rep package.
Are you still seeing some problems with it?
ka4opi4a
Wed Apr 13, 2016 1:51 pm
Can I use latest current release and latest rc wireless rep package ?
uldis
Wed Apr 13, 2016 2:22 pm
No, you need to switch the RouterOS to Release Candidate channel and upgrade to the latest RC which currently is rc49. And then install the wireless-rep package.
jarda
Wed Apr 13, 2016 3:07 pm
So it means there is an error in the script that expects some wlan adapter but it is not present... You should correct the default script then.
mrz
Wed Apr 13, 2016 3:30 pm
RB941 has one wireless interface, if during load it cannot find one there will be an error.
jarda
Wed Apr 13, 2016 3:54 pm
How it cannot find one when there is such adapter present?
docmarius
Wed Apr 13, 2016 3:58 pm
Do you have the latest ROS update and the latest firmware installed? :lol:
Did you do a reset to defaults? :lol: Did you try netinstall 8)
Aren't these the ultimate answers for everything? 42.
Torturing CCR1009-7G-1C-1S+, RB450G, RB750GL, RB951G-2HnD, RB960PGS, RB260GSP, OmniTIK 5HnD and NetMetal 922UAGS-5HPacD + R11e-5HnD in my home network.
jarda
Wed Apr 13, 2016 4:06 pm
Yes. This error line appears when latest rc is installed over the 6.34.4. I saw it repetitively on 4 devices. It's either the wrong defconf script or the script runs too early when drivers are not properly loaded yet. It was just to inform that it could signalised some other maybe more important problem. Otherwise I don't see any significant impact in my case so far.
mrz
Wed Apr 13, 2016 4:13 pm
Works perfectly fine on out of the box router. Generator has limited time of execution. Unless there is no heavy load on CPU during boot up that could cause drivers not to load in time you will be fine.
xuqianman
Wed Apr 13, 2016 4:49 pm
how to open then "bridge-mode" for capsman mode? thanks.
uldis
Wed Apr 13, 2016 4:58 pm
currently it is not possible and it will not be added in the near future as it isn't just simple settings, there are lot of things needed for supporting that feature. And for the regular indoor APs you don't need this function.
human1982
Wed Apr 13, 2016 10:32 pm
6.35rc49
NV2 qos works very good, ping in low, ap control capacity of the client well. Could u add a second Wieless Protocol nv2 (ex nv2-ptp, old named nv2-ptmp) for ptp only, with some special features to improove it? Ex lower the ping and more overhead control to stable the links? It could be the option in wireless-rep, we will test it.
regards
Mateusz
WirelessRudy
Thu Apr 14, 2016 2:00 am
6.35rc49
regards
Mateusz
"nv2-ptp", "nv2-ptmp"? I never heard of that. Only "NV2" then parameters are set for different type of link?
How did you measure the NV2 qos? Examples?
Show your appreciation of this post by giving me Karma! Thanks.
Rudy R. Puister
WISP operator based on MT routerboard & ROS.
human1982
Thu Apr 14, 2016 2:30 am
6.35rc49
regards
Mateusz
Nv2 gives time space, and other things, it is in the code, for ptmp it is working now very well as i wrote (in auto period size one station overhead ap much before, now it isn`t). I think for ptp the code could be rewrite and aded as a second choise in menu. In lte no matter what rate and speed u have, ping is always the same, this is for me good qos. It is work for a coders, i am a customer, they must do the job to beat airmax, not me ;) For me i rather be pleased to have 90mb and ping 0-1-2 ms on 240/240 802.11N than 130-140mb and ping 2-7-20ms, this is example. When noise apears radio should do the job and lower the speed to do 0-1-2ms, now u understand?
regards
Mateusz
andersonlich
Re: v6.35rc [release candidate] is released, new wireless package!
Thu Apr 14, 2016 10:41 am
v6.35rc49,
pppoe-client interface always up-down if it's doesn't get ipv6 dhcp-pd.
can it make not re-dial the pppoe if the ipv6 dhcp-pd not obtained ?
janisk
Thu Apr 14, 2016 11:04 am
regarding options for DHCPv6-client, DHCP-PD client (and also DHCP--PD server) as it currently stands - options will be available only with RouterOS 7.x release due to technical limitations for backporting the feature.
WirelessRudy
Thu Apr 14, 2016 11:55 am
6.35rc49
regards
Mateusz
regards
Mateusz
No, not a lot. Your english is a bit hard to understand.
Basically you mention that the 'auto' setting of NV2 time delay should be in two versions? One for PtMP and one for PtP?
I found 'auto' setting not always give best result anyway. We have AP with 30 clients and in changing 'auto' in 6ms we more than doubled the total throughput from AP (30 =>55Mb. Netbox5) while the ping time to client hardly changed.
I think 'auto' setting is always a compromise. If you really need to fine tune a link you have to do it manually.
But I can see your point in having 2 different default 'auto' scenarios. One for PtMP and one for PtP. That would make sense and give a better start for many of us...
To bring down a ping time by QoS is not very senseful. Your ping would be nice stable and fast, since QoS will take care of it, but your end goal is a good service level for your client's traffic. That is not ping but ordinary internet, voip, streaming TV etc. etc. If your ping is good due QoS that doesn't mean your network traffic is as good.
Rudy R. Puister
Florian
Thu Apr 14, 2016 1:45 pm
Thx for the update :)
The famous RouterOS7.x.... I'll have to wait I guess :)
- Sorry for my english -
notToNew
Thu Apr 14, 2016 4:53 pm
When using the wireless_rep- package and adding the wan1-Device to a bridge called "bridge-wan" *and* using "connect-list",
bridge-wan does not get an ip adress from dhcp. (as station)
Removing it from the bridge it recives the ip immediately.
Connection it to station without using "connect-list" works, even as bridge.
Can this be a configuration error or is this a bug?
CCR1036-12G-4S, several 952Ui-5ac2nD, ...
anuser
Thu Apr 14, 2016 9:29 pm
Is it possible to add more information about connected user to CAPSMAN view with wireless-rep package?
e.g. user name being used, auto-translation of vendor part of MAC (well it´s a gimmick)
juanvi
Thu Apr 14, 2016 10:29 pm
Where has gone the export compact by default with export command "only" in new terminal?????
¡vʞvdnX puv ···SOɹǝʇnoɹ ʞıʇoɹʞıW oʇ sʞuvHʇ
jondavy
Thu Apr 14, 2016 11:44 pm
on CapsMan channel width=10mhz not work
jondavy
Fri Apr 15, 2016 1:07 am
mANTBox 15 not work in 10mhz with manual frequency
scampbell
Trainer
Trainer
Fri Apr 15, 2016 3:42 am
If your were to create access lists based on the OUI info in this table http://standards-oui.ieee.org/oui.txt then each registration would have manufacturer listed next to it.
___________________
andriys
Fri Apr 15, 2016 11:06 am
It is not, perhaps, supposed to work. My understanding is CAPsMAN currently mainly targets indoors setups with only the standard 802.11 features supported.
uldis
Fri Apr 15, 2016 5:05 pm
We have released 6.35 (current) discussion topic here http://forum.mikrotik.com/viewtopic.php?f=1&t=107307 Thanks to your feedback we have found the issue randomly causing boards to fail on upgrade during the rc testing,m this fix is included in 6.35 (current),
to successfully upgrade to 6.35 from 6.35rc29-rc49, please do a /system reboot, and then on bootup make an upgrade straight away.
Users browsing this forum: rushlife and 19 guests
