MUM Europe 2020
ivaaan
RB750P-PBr2 mAP_lite
Tue Feb 02, 2016 11:03 pm
Hello everyone!
At last I got mAP lite. And it is really the smallest AP a ever see! But I was surprised when found that power consumption is up to 3,5W. And original power supplier is 2000mA.
Initially I wanted to use 4 mAP lite with Mikrotik PowerBOX RB750P, but the PowerBOX is support no more then 1A per port and 2A in total. And it looks like powerbox becomes useless
Anybody have good experience with PoE and what cheap PoE supplier (multiport injector or switch) you can suggest?
PaulsMT
Re: RB750P-PBr2 mAP_lite
Wed Feb 03, 2016 11:25 am
PowerBox comes with 24v 2,5Amp power supply, which is completely fine to power four mAPL. While PowerBox output voltage is the same as input voltage (24V), one mAPL at max power consumption will require 0.145A
http://routerboard.com/RB750P-PBr2
ivaaan
Fri Feb 05, 2016 7:18 am
Thank you so much!
gammy69er
Wed Feb 24, 2016 6:58 am
Watts roughly *EDIT* Exactly *EDIT* equates to Amps x Volts
24v x 2a = 48w
3.5w / 24v = 0.146a - well below the 1 amp limit per port.
*EDIT* See what i did there :P Cheers Jarda - good info as usual
jarda
Wed Feb 24, 2016 7:10 am
Ohm law on dc is not rough but exact.
Users browsing this forum: ByteFax and 21 guests
